 Monkey Wiring on the Ignition coil packs
Gariv95
Monkey Wiring on the Ignition coil packs Empty
PostSubject: Monkey Wiring on the Ignition coil packs   Monkey Wiring on the Ignition coil packs EmptyTue Jul 08, 2008 6:00 pm
I was digging around under the hood and noticed that someone had cut and spliced a wire on the ignition coil packs. This wire goes over to the fuse box; where the something for the ac as well as the 20 amp fuse for the horn which just so happens to be blown; resides. I being the ever anal retentive person that I'am disconnect it. shout The car refused to start until I reconnected it. any Ideas on what this is and How do I go about fixing it? The fuse I went to replace and as soon as the fuse hits the metal the horn starts going off. Is this part of the alarm system maybe?
PostSubject: Re: Monkey Wiring on the Ignition coil packs   Monkey Wiring on the Ignition coil packs EmptyTue Jul 08, 2008 6:04 pm
This might be one of those "non-start security systems" you find with swap meet stereo systems....
Gariv95
PostSubject: Re: Monkey Wiring on the Ignition coil packs   Monkey Wiring on the Ignition coil packs EmptyTue Jul 08, 2008 6:30 pm
disturbing but true
whit2285
whit2285
PostSubject: Re: Monkey Wiring on the Ignition coil packs   Monkey Wiring on the Ignition coil packs EmptyTue Jul 08, 2008 6:58 pm
what color is the wire thats its spliced to on the icm
Gariv95
PostSubject: Re: Monkey Wiring on the Ignition coil packs   Monkey Wiring on the Ignition coil packs EmptyTue Jul 08, 2008 10:35 pm
it is a red wire.
PostSubject: Re: Monkey Wiring on the Ignition coil packs   Monkey Wiring on the Ignition coil packs EmptyWed Jul 09, 2008 10:11 am
probably a kill for the alarm. Does it have a remote start?
Gariv95
PostSubject: Re: Monkey Wiring on the Ignition coil packs   Monkey Wiring on the Ignition coil packs EmptyThu Jul 10, 2008 4:14 pm
No sir It does not.
Merit : 153
PostSubject: Re: Monkey Wiring on the Ignition coil packs   Monkey Wiring on the Ignition coil packs EmptyThu Jul 10, 2008 9:01 pm
do you have access to factory manual/wiring diagrams? Point is - my guess is that if you did it would nto be too tough to figure out where to look to find the short in the factory wiring.
» Atco/Dynamark 11hp Lawn Tractor Project
» 11 " DD coil wiring conversion to Mono coil
» Tecumseh HH120 Won't Start
» Minelab DD and MONO coil plug pin wiring diagram
» coil id with out markings
