ewolfe0050 Aficionado
| Subject: Busted a rear shock mount today... Tue Jul 08, 2008 8:24 pm | |
| I was driving down I70 today and CLUNK.. bump, bump. bump... I initially thought it was the can of fix-a-flat punctured in the trunk so I drove a little more (carefully) until I could pull off in case it wasn't. I was hesitant about opening the trunk and having gluey crap spray out on me but it turns out I broke the rear passenger shock mount. It broke, not inside the trunk, but in the fenderwell. The tabs holding on the studs sheared off completely letting thre strut to fall into the fenderwell and knock against the top. I tied the shock up into the trunk with fishing line (that is all I had) hoping it wouldn't fall back down again but that lasted .03 sec (can't blane me for trying and I used a whole reel). Limped it home, got a new mount from NAPA within 30min at the warehouse (they came out with a new style- cross between a '95 and '97). I had it all put back together in 25min and works great. Keep in mind I have the Rancho's so I had to do a little modification for them to fit. Thanks to the writeups on the board- cut my repair time down when you can get proper socket sizes and such. I am starting to know this car inside and out...she's my baby. | |
| Subject: Re: Busted a rear shock mount today... Tue Jul 08, 2008 9:22 pm | |
| I'm impressed that you modded one of the new style shock mounts. I took one look at them and said "forget it." What did you grind them with? | |
| Subject: Re: Busted a rear shock mount today... Tue Jul 08, 2008 10:15 pm | |
| Don't worry about the bottom of the sleave... just grind the top down to fit. It is the first time I saw this mount and it is built well. It does not have the '97 nubs on the inside. More like the '95. It does have plenty of material on the top to be milled down so you have plently to work with rather than trying to get a flat grind on the bottom sleave.
But to answer your question... larger drill bit than the sleave drilled down to the bottom of the rubber. Grind the rubber down to fit the original '97 washer. I'll try to get some photos.
It looks like NAPA has a new style out from last time I did the mod. Maybe they are copying the '95's now. | |
| Subject: Re: Busted a rear shock mount today... | |
