 What's this dohickey for?
What's this dohickey for? Empty
PostSubject: What's this dohickey for?   What's this dohickey for? EmptyThu Jul 10, 2008 12:21 pm
Looks like an air sensor or something, it's just sitting there behind the gray lip, under the radiator. Looks like it should be attached to something frown
What's this dohickey for? 100_6424
PostSubject: Re: What's this dohickey for?   What's this dohickey for? EmptyThu Jul 10, 2008 12:31 pm
Ambient air temp sensor. It's broken off from its mount directly above. It still works, but remounting it would be ideal. It tells the AC what temp it is outside.
PostSubject: Re: What's this dohickey for?   What's this dohickey for? EmptyThu Jul 10, 2008 5:04 pm
Unplug it, you don't need it... its not that hot in NY anyway wink
Merit : 154
PostSubject: Re: What's this dohickey for?   What's this dohickey for? EmptyThu Jul 10, 2008 8:36 pm
Before you disconnect the thing - if you don't use the sensor but you use 'auto' setting on the HVAC control, the control assumes it's hot out (thermistor "open" default is a max temperature reading) and cycles the AC too often in summer (instead of using the vent when the vent would work).
Ilan - just use some double faced trim tape (the 3M gray stuff with the red peel-off backing), silicone caulk, Goop, hot glue or a zip tie to put the sensor back on the mount.
Travis - your sensor is still connnected, right. Or did you remove it? You're not 'talking through your hat,' are you?
scratch
PostSubject: Re: What's this dohickey for?   What's this dohickey for? EmptyThu Jul 10, 2008 9:40 pm
fuck you its not
PostSubject: Re: What's this dohickey for?   What's this dohickey for? EmptyThu Jul 10, 2008 10:05 pm
Haha, I'll just leave it for now. It's not going anywhere.
PostSubject: Re: What's this dohickey for?   What's this dohickey for? EmptyFri Jul 11, 2008 9:16 am
How accurate are those AAT's?
...I wonder if I could use to to tap into my FWI so I could read the Induction Temperature on my display....
PostSubject: Re: What's this dohickey for?   What's this dohickey for? EmptyFri Jul 11, 2008 9:21 am
In my experience, it's very accurate.
In theory, you could do that, but the climate control system wouldn't work very well in auto mode. When sitting idle, the AC would blow extra cold as IAT climbs.
Here's some info on IAT vs. ambient: http://rivperformance.editboard.com/series-ii-engine-transmission-f4/write-up-installing-fwi-filter-heat-shield-air-scoop-t1209.htm
PostSubject: Re: What's this dohickey for?   What's this dohickey for? EmptyFri Jul 11, 2008 10:06 am
Aaron, thanks…good read.
Not to hijack this thread, but using your pic, this is where I tapped the IAT into the fenderwell…I couldn’t tap into the “tube” because I’m using that Intense rubber tubing…
What's this dohickey for? Iatlocyp9
Will this give an accurate IAT reading?
Also
Where did you get this cover?
What's this dohickey for? Intaketop2
This thing is perfect! Do you remember the manufacture name and part number?
PostSubject: Re: What's this dohickey for?   What's this dohickey for? EmptyFri Jul 11, 2008 10:27 am
it's a roof flashing, available at a hardware store. you just have to cut it up to make it fit down in there.
What's this dohickey for? Dsc_0110
