 FAQ: What is the Black Box? (Series I SC)
gliderguy
FAQ: What is the Black Box? (Series I SC) Empty
PostSubject: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptySun Jul 13, 2008 10:50 pm
What is the little black box in the back of the engine on top of the motor? It has a vaccum hose going to it...
Thanx all, Lance
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptySun Jul 13, 2008 11:10 pm
I have no idea what youre talking about. lol
Is the car a 95 , or 96-99? supercharged or not? This info should be in your signature ideally. it helps a lot when asking a technical question ,as there are many variations of engine bay setups in our rivs.
That and posting a picture could help you get an answer much more quickly.
gliderguy
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptySun Jul 13, 2008 11:12 pm
Sorry its a 95sc and its right on top of the motor connected on the back of the firewall in the center....
Thanx, Lance
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptySun Jul 13, 2008 11:40 pm
sounds like the MAP sensor.
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyMon Jul 14, 2008 7:06 am
It's this thing, on the left of this picture. AA doesn't know what it is either. It's only in the '95s with the Series I motor. I have no idea what the hell it is either.
FAQ: What is the Black Box? (Series I SC) 100_6422
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyMon Jul 14, 2008 7:40 am
i think its a -non servicable - cabin filter.
gliderguy
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyMon Jul 14, 2008 9:08 am
I dunno eather but why only 1 vaccum hose going to it and I also dont think it goes into the cabin at all..And thanx for that great pic Ilan.....Hmmmmm, anyone else maby no what it could be? Thanks again guys or ladies,
Lance
jamie
jamie
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyMon Jul 14, 2008 11:30 am
I noticed that exact part yesterday and wondered what it was.
We're being tracked by buick through it.
... Actually, I just looked it up on Mitchell Repairmate, and I've found it to be simply a vacuum tank.
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyMon Jul 14, 2008 12:48 pm
Ok, makes sense since there's a hose leading to it from underneath.
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyMon Jul 14, 2008 12:56 pm
Sure looks like it would make changing the rear plugs a RPITA.
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyMon Jul 14, 2008 1:02 pm
Why yes, yes it does. confused
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyMon Jul 14, 2008 4:17 pm
PN...25603900
You are correct!
We talked about this vacuum tank and changing the plugs on the ‘95s from underneath on another thread ... sometime, somewhere?
gliderguy
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyMon Jul 14, 2008 5:52 pm
Thanks all, thats what i kinda thought..Is there a purpose for it?And I just did my plugs from underneath, it was easy....
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyTue Jul 15, 2008 10:27 pm
It's a vacuum reservoir. I think it is used to make sure that you have enough vacuum to run the brakes.
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyTue Jul 22, 2008 7:20 pm
looks like a cabin air filter to me i dont have it on my 97
http://www.Chitownracing.com
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyTue Jul 22, 2008 11:12 pm
No cabin air filters on the 95-99 Rivs.
lionfish
lionfish
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyWed Jul 23, 2008 12:10 pm
[quote="IBx1"]It's this thing, on the left of this picture. AA doesn't know what it is either. It's only in the '95s with the Series I motor. I have no idea what the hell it is either.
I have a 95 with a Series II N/A and the same vacuum reservoir.
gliderguy
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyThu Jul 24, 2008 9:14 am
OK I finally found out this mystrey!!! It is a vacume tank for the cruise control!!!!!! Aperently it holds extra vacume for it... And it was for the 95sc.. O and also it was discontinued on 11/05.........
Lance
Merit : 155
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyThu Jul 24, 2008 9:38 am
I was told once that SC cars don't have as much vacuum as N/A cars. I was also told that one key 'feature' of the Riv (and other luxury cars) is they're designed to hold speed on cruise control on interstate highways going uphill (I forget what the max interstate grade is, maybe 10%?).
Anyway, there are various ways to ensure that. One is to use a vacuum tank to help the vac-operated cruise hold speed up grades (when engine vacuum dips). Another - used on the later Rivs - is to use an electronic cruise control with an electric servo instead of a vac tank.
To find that servo just trace back the throttle cable that's not terminated at the accerator pedal.
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyThu Jul 24, 2008 11:26 am
I think they stopped using vac-operated cruise in the early 90s somewhere. I know my '94 Regal had a servo-based cruise.
Extra vacuum for the brake booster?
vendetta
vendetta
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyTue Oct 07, 2008 5:52 pm
My 95 SC has it....
but my cruise control doesnt work....
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyFri Oct 10, 2008 8:30 pm
vendetta wrote:
My 95 SC has it....
I had problems with my '95 cruise, unplugging and cleaning the connector under the hood fixed mine, might give it a try, you never know?!?
KillaKeninaRiv
KillaKeninaRiv
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptyMon Mar 30, 2009 12:03 pm
I have it on mine and I was told it is a vaccum tank, there also was one on my 1995 Series II as well
jeff thompson
PostSubject: i looked for the function of this rectangular black box ?   FAQ: What is the Black Box? (Series I SC) EmptySun Dec 13, 2009 4:59 pm
hello group, just looking under the hood of the old beast and saw a vacuum line not attached, finally saw that it went to the rectangular box bolted to the firewall - center top, is that a vacuum holding unit like the old ball i used to see? Thanks
Jeff
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) EmptySun Dec 13, 2009 6:09 pm
Welcome to the board, Jeff.
Please fill go into your Profile, Signature, and fill out some information about "the old beast", so we have some idea of what you are asking questions about... '95s for example have a LOT of things different from the '96-99s.
» WTB: blackrock tackle danny kadota series rod
» DIY sliding drawer system for Toyota Landcruiser 100 series
» Black Mountain Off Road Park, Evarts KY
