 FAQ: What is the Black Box? (Series I SC)
Go to page : Previous  1, 2
FAQ: What is the Black Box? (Series I SC) - Page 2 Empty
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) - Page 2 EmptySun Dec 13, 2009 6:24 pm
i am adamant in my stance that dabby doobers abound within the engine bay of the riv...there's nothing for it study
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) - Page 2 EmptySun Dec 13, 2009 6:36 pm
Well yeah, especially 'cuz you have a '95, before they started phasing out dabby doobers...
I have an all-electronic, non-dabby '97, but what he's describing sounds like a '95 cruise control line.
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) - Page 2 EmptySun Dec 13, 2009 9:00 pm
jeff thompson wrote:
is that a vacuum holding unit like the old ball i used to see? Thanks
Jeff
Yes it is a vacuum tank, '95 is the only year with it there laughat
sc3800
sc3800
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) - Page 2 EmptySat Feb 06, 2010 1:22 pm
Look at your emissions sticker on your radiator support... That box is for vacumm/and emissions use... You need it-make sure that vacumm line and all vacumm lines on that car are good--not cracked or broken
98inSFl
98inSFl
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) - Page 2 EmptySat Feb 06, 2010 7:39 pm
The box has nothing to do with the brake booster, too small vac hose to do any good for the brakes...
Merit : 154
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) - Page 2 EmptySat Feb 06, 2010 9:39 pm
Ummm.... really, need to either plug the line back in where it belongs or cap it.
A performance improvement should result when that (admittedly small) vac leak is fixed.
Merit : 17
PostSubject: What is this black box?   FAQ: What is the Black Box? (Series I SC) - Page 2 EmptyWed Jun 06, 2012 2:46 pm
I really have no idea what this thing is, and since it has a vacuum line running to it, will these cracks give me a vacuum leak?
FAQ: What is the Black Box? (Series I SC) - Page 2 Mmq83
FAQ: What is the Black Box? (Series I SC) - Page 2 R1di07
Merit : 122
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) - Page 2 EmptyWed Jun 06, 2012 3:24 pm
That would be your vacuum box. If it won't hold air then yes that would be a vac leak.
Merit : 154
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) - Page 2 EmptyWed Jun 06, 2012 7:22 pm
it's the vac reservoir for the cruise control. They *may* be discontinued but last I checked GM still had them as parts, you need to check monsterpartsonline.com, or your local dealer, OK. Others have said don't bother patching it.
Temporarily, black RTV over the cracks should get it to hols vac while you wait for the replacement. Another solution would be to get heavy duty aluminum foil and spray cement, spray the cement on the foil and apply it to the vac box cement-side-down. Seal the seams with RTV. Again, a temporary fix while you wait for the replacement to arrive, which if it is in Martinsburg (GM/vintage warehouse IIRC) it will take a couple weeks to get.
Merit : 17
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) - Page 2 EmptyWed Jun 06, 2012 8:55 pm
I think i may try to seal it with flex seal. I just removed the box out of curiosity and changed the vacuum line.
Pipes
Pipes
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) - Page 2 EmptyThu Jun 07, 2012 12:39 am
it is the vacuum for the cruise control i forget the exact name of it
Merit : 122
PostSubject: Re: FAQ: What is the Black Box? (Series I SC)   FAQ: What is the Black Box? (Series I SC) - Page 2 EmptyThu Jun 07, 2012 4:13 pm
If you can't get it to hold vaccum you could use most any kind of vaccum canister to replace it with. Even a bit of ABS pipe with end caps and the same volume would work. Just tap in a barb for the vaccum line.
» WTB: blackrock tackle danny kadota series rod
» DIY sliding drawer system for Toyota Landcruiser 100 series
» Black Mountain Off Road Park, Evarts KY
