| Air conditioner Question | |
+5whit2285 dreww albertj deekster_caddy SuperRiv07 9 posters |
SuperRiv07 Addict
Name : Nick Age : 39 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
| Subject: Air conditioner Question Mon Jul 21, 2008 6:45 pm | |
| So my A/c dont work and Im fine with that cause witht the windows down and sunroof open im just fine but the condesor spins and the fly whell grinds in ther cause its no good and trys to go on, so what I want to know is if i go under the hood and unplug the condensor will the pully still spin? and is that ok to do untill I can get an ac delete pulley? | |
| Subject: Re: Air conditioner Question Tue Jul 22, 2008 12:01 am | |
| You want to unplug the AC Compressor Clutch. The connector should be right at the front of the AC compressor, above the clutch. | |
SuperRiv07 Addict
| Subject: Re: Air conditioner Question Tue Jul 22, 2008 3:31 am | |
| i did that but the clutch still spins but doesnt engage, how difficult to remove ac and get a smaller serpintine belt so skip it? | |
| Subject: Re: Air conditioner Question Tue Jul 22, 2008 8:52 am | |
| ZZP sells an A/C 'delete', a pulley on a bracket that can go in place of the compressor. I think the way the belts are routed it's very difficult to bypass. | |
| Subject: Re: Air conditioner Question Tue Jul 22, 2008 9:39 am | |
| Compressors for the riv are not free, but not that expensive either. Did you consider getting a used one from Ed Morad (a used parts dealer in Ohio)? A number of list members have used Ed for all manner of parts; he's not real talkative but he knows these (Riviera, Grand Prix GT, Regal) cars pretty well. Use 'search' command to find Ed's contact info. Then all you need is a local mechanic who'll put it on for you if you can't do it yourself.
SuperRiv07 Addict
| Subject: Re: Air conditioner Question Tue Jul 22, 2008 11:48 am | |
| so if i Pull off the ac I can put an ac delete pulley in and that will be fine? | |
dreww Junkie
| Subject: Re: Air conditioner Question Fri Jul 25, 2008 12:43 pm | |
| - SuperRiv07 wrote:
- so if i Pull off the ac I can put an ac delete pulley in and that will be fine?
technically, it should work, but I dont know anyone who has done it on a riv. those ac deletes are made for w-body cars I believe. | |
whit2285 Enthusiast
Name : Mike Age : 49 Location : Illinois Joined : 2007-12-20 Post Count : 127 Merit : 3
| Subject: Re: Air conditioner Question Sat Jul 26, 2008 12:15 am | |
| i used the ac delete woked fine got it from 1aauto.com easy to install no problems. i got my ac fixed if you want to buy a used one ill sell for cheap .im near bridgeview let me know | |
Shintsu Expert
| Subject: Re: Air conditioner Question Sat Jul 26, 2008 1:17 am | |
| Christ, how could you drive around with no A/C? | |
SuperRiv07 Addict
| Subject: Re: Air conditioner Question Sat Jul 26, 2008 1:39 am | |
| windows down and drive fast lol, I dont think I could handle it here in memphis Im glad I live in chicago, its 111 here in memphis, Mike I will talk to you monday or tuesday, How much was your ac deletye? and how much do you want for your ac? | |
Shintsu Expert
| Subject: Re: Air conditioner Question Sat Jul 26, 2008 2:32 am | |
| Man, that eats your gas mileage up. Not to mention it's noisy as hell. I couldn't live without the Riv's ice cold AC and I can't see how people drive around with their windows down in this hot humid weather. Must be sweating like pigs... | |
whit2285 Enthusiast
| Subject: Re: Air conditioner Question Sat Jul 26, 2008 1:22 pm | |
| it was like 45.00 i believe . 20.00 its yours do you know your engine code mines a 1 | |
SuperRiv07 Addict
| Subject: Re: Air conditioner Question Sun Jul 27, 2008 9:08 pm | |
| I have No Idea, I will Find Out and let you know asap | |
whit2285 Enthusiast
| Subject: Re: Air conditioner Question Sun Jul 27, 2008 10:03 pm | |
'96reese Fanatic
| Subject: Re: Air conditioner Question Mon Jul 28, 2008 3:18 am | |
| superriv...if you car is supercharged then your 8th digit is 1 if not then it's k. judging from your signature it's a 1 code. | |
SuperRiv07 Addict
| Subject: Re: Air conditioner Question Mon Jul 28, 2008 3:28 pm | |
| Yeah Its supercharged, I couldnt look at the vin Cause Im in tn Repoing cars and my car is at home In Chicago | |
charlieRobinson Expert
| Subject: Re: Air conditioner Question Tue Jul 17, 2012 8:44 am | |
| Hey, guys. All of a sudden my Riv decided to start only blowing out hot air. WTF!?!?! My ice cold A/C is gone! I am sure i'm not the first person this has happened to. Any ideas what the problem might be? The top A/C vents are somewhat cooler than the bottom ones. All the vents below the dash blow super freakin hot air. And these 100 degree temps aren't helping!
| Subject: Re: Air conditioner Question Tue Jul 17, 2012 9:50 am | |
| Check your IAT value with your torque app. This is to make sure the sensor is still working. Next thing I'd do is check the AC clutch is engaging. You can visually verify this by looking at the pulley. If it's not turning on, try rigging a small test lamp to the connector to see of it's getting power. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Air conditioner Question Tue Jul 17, 2012 11:23 am | |
| Roger that. Will do and I will report back. Thanks, Aaron.
| Subject: Re: Air conditioner Question Fri Jul 20, 2012 7:55 pm | |
| IAT sensor seems to be working fine. How do I know which pulley is linked to the AC clutch? | |
| Subject: Re: Air conditioner Question Fri Jul 20, 2012 10:50 pm | |
| - charlieRobinson wrote:
- IAT sensor seems to be working fine. How do I know which pulley is linked to the AC clutch?
...trace the belt Albertj | |
| Subject: Re: Air conditioner Question | |
