 Homelink..
Homelink.. Empty
PostSubject: Homelink..   Homelink.. EmptySat Mar 10, 2007 12:36 pm
Hey..i have a homelink garage door opener built into mine..totally forgot about it...well i tried programmin it..and i did it right like the manual said...but i got nothin to show for it..has anyone had any issues with their newer garage door openin with their homelink..anyone have any help for me?
Scotty
SoCal Riv
SoCal Riv
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptySat Mar 10, 2007 1:58 pm
Follow these instructions by Homelink.
The site allows you to put in your year, and to printout instructions too.
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptySat Mar 10, 2007 4:32 pm
no luck...followed everything correctly...
just no luck
SoCal Riv
SoCal Riv
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptySat Mar 10, 2007 6:40 pm
I know they made some changes to the Homelink for the newer "rolling" codes. Yours might be one of the earlier models.
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptySat Mar 10, 2007 6:54 pm
i guess new garages and old garage door openers dont work well together..
SoCal Riv
SoCal Riv
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptySat Mar 10, 2007 8:43 pm
Well, I know my 1998 worked with the newer rolling codes, as I installed new garage door openers last year and the Riv worked fine. Try looking for a 1998 or 1999 Homelink Riv assembly on eBay.
SilverArrow102
SilverArrow102
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptySat Mar 10, 2007 9:16 pm
Just got a new door opener last weekend with the rolling code. Using the directions, I couldn't get the homelink remote to program. My 06 Buick Rainier instructions mentioned an added step to press the learn button on the opener then the appropriate button on the homelink within 30 seconds. Works like a charm.
http://home.kc.rr.com/mirage/
SoCal Riv
SoCal Riv
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptySat Mar 10, 2007 10:29 pm
Were you trying to sync off the remote, or the actual opener?
SilverArrow102
SilverArrow102
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptySat Mar 10, 2007 11:27 pm
Sync the homlink remote to the actual opener The opener has a purple "learn" button on the back of the unit.
SoCal Riv
SoCal Riv
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptySun Mar 11, 2007 5:10 pm
I put in these Chamberlain Belt Drive (with battery backup) units, and was able to sync up to them. I do know that if you have existing codes that you may have to reset the HomeLink on the Riv.
97rivsc
97rivsc
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptyFri Jan 09, 2009 4:10 pm
I have a 97 riviera and the homelink will not work with the rolling code garage door openers.
https://www.facebook.com/album.php?aid=2007661&id=1593150315#/pro
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptyFri Jan 09, 2009 4:30 pm
Who ever is opening and closing my garage door....KNOCK IT OFF!
SToP
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptyFri Jan 09, 2009 9:01 pm
Chicken, you slay me dude. smile
Hey, anyone know if there is such a thing as a USB homelink receiver or something like that? It would be cool if you could hook it up to a more powerful home automation system. I googled but all that comes up is a router Linksys has called a homelink.
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptySat Jan 10, 2009 6:10 pm
Have programmed 3 different garage doors and 3 different cars (2 Rivs and a Park Avenue) without any problems.
It could be that the homelink unit itself is bad. Do you get any of the blinking lights?
Sweepspear
Sweepspear
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptySat Jan 10, 2009 7:29 pm
Couldn't get the one in my '96 to work with my garage door opener, which is a Chamberlain that is about 3 years old.
I figured it was because the opener was so much newer than the car.
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptySat Jan 10, 2009 7:43 pm
I bought a Chamberlain about 6 months ago and my Homelink programmed without a problem.
97rivsc
97rivsc
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptySun Jan 11, 2009 1:48 pm
how much does a new homelink unit cost roughly?
Sweepspear
Sweepspear
Homelink.. Empty
PostSubject: Re: Homelink..   Homelink.. EmptyMon Jan 12, 2009 11:48 am
That pretty much does away with my theory as to why mine doesn't work.
Homelink.. Empty
Homelink..
» Custom Homelink Install
