 PCM reset??
BoattailBob
PostSubject: PCM reset??   Thu Jul 24, 2008 11:28 am
This morning I started my drive to work and got half a block and my gear indicator (lights that show the gears on the dash) started flashing. It looked the same as when I flash an new tune to my PCM via HPT. Didnt seem to affect anything and went right on running, but also has me a little worried. Anyone ever experience this? Im really getting tired of dumping money into this car...this may be the end if I need to replace the PCM.
BillBoost37
Merit : 25
PostSubject: Re: PCM reset??   Thu Jul 24, 2008 12:21 pm
Did the car possibly stutter once?
I saw a similar thing when the crank sensor was acting up on mine. When I looked for codes, I sometimes found one related to it starting n gear and once a crank sensor error. I let mine go for months to get something consistent enough to find it.
BoattailBob
PostSubject: Re: PCM reset??   Thu Jul 24, 2008 1:29 pm
It didn't stutter at all, didn't throw a code either. So..I guess I'll wait to see if it does happen again. Thanks!
PostSubject: Re: PCM reset??   Thu Jul 24, 2008 1:35 pm
PCMs are odd things. I have flashed mine with the ignition off before, and it stuck!
KillaKeninaRiv
PostSubject: Re: PCM reset??   Thu Jul 31, 2008 12:09 pm
mine does the same thing. when i start it and put it into drive it flashes i think 4 times
PostSubject: Re: PCM reset??   Fri Aug 01, 2008 3:47 pm
That happened to me too. I thought it was just coincidence but seeing as how it happened so someone else , maybe not.
KillaKeninaRiv
PostSubject: Re: PCM reset??   Fri Aug 01, 2008 8:00 pm
so i have to have my PCM reset as well?
PCM reset??
