 Write Up: Transmission Fluid & Filter Change
dtrumbo
Write Up: Transmission Fluid & Filter Change - Page 7 Empty
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySat Dec 03, 2011 10:58 pm
How much would it cost for a GM tech to actuate the solonoid for me? And is it possible to do a flush by myself?
dtrumbo
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptyFri Dec 30, 2011 6:24 pm
I have a friend at a GM dealership and he actuated the solenoid (to the best of his ability) I don't think he put it to full open, just turned it on and off. I read the screen on the TechII and it said something about 9% somewhere towards the top. But that didn't work, he said it would be 140 for the transmission flush and I am tempted to get it done.
rivierafrenchboy
PostSubject: transmission riviera 95 sc    Write Up: Transmission Fluid & Filter Change - Page 7 EmptyFri Jul 13, 2012 2:11 pm
hello
I made ​​more today emptying the filter of my transmission
how much oil I should allow for the return to his level?
thank you fans riviera
rivierafrenchboy
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptyFri Jul 13, 2012 2:12 pm
combien de litres je dois acheter pour ma transmission ? j'ai fait la vidange avec le filtre
merci
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptyFri Jul 13, 2012 3:05 pm
rivierafrenchboy wrote:
hello
Around 7-8 quarts.
rivierafrenchboy
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySat Jul 14, 2012 1:20 am
HELLO
  and thank you for this information
Merit : 154
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySat Jul 14, 2012 1:26 pm
merci
Le fluide est DEXRON III, si elles sont sèches la transmission détient 12,7 litres. Si la révision complète du liquide dans le convertisseur, puis de remplir d'utiliser 9,5 litres. Si tout ce que vous faire est de retirer le bac inférieur et le filtre de changement, la recharge a besoin de 7 litres.
Est-OK d'utiliser le fluide DEXRON VI.
Albert
rivierafrenchboy
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySat Jul 14, 2012 1:34 pm
Merci Albert , tu parles le français?
Merit : 154
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySat Jul 14, 2012 3:48 pm
Un peu.
Une fois de temps en temps je réponds en français, ce editboard a beaucoup de français membres canadiens et français. Cependant, il est important d'avoir un bon dossier de commentaires sur le conseil d'administration, de sorte que tous les débats qui est important doit être rédigé en anglais américain standard.
Meilleurs,
rivierafrenchboy
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySun Jul 15, 2012 2:35 am
Bonjour
ok ok merci Albert
La riviéra est une superbe voiture je prévois d'en acheter une deuxieme car celle que j'ai a été très mal entretenue elle a beaucoup souffert !
salutations
Lucien
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySat Apr 06, 2013 7:03 pm
Ordered Mobil One Synthetic ATF for $41.23 for 6 quarts after mail in rebate and I thought I would let you guys know. http://www.amazon.com/dp/B009IE2R0U/ As discussed in this thread you will need around 8 quarts for a pan drop. Another two quarts would cost around $20 to $30, so it isn't much more to get another case. I think I will try to use this pump from Harbor Freight http://www.harborfreight.com/multi-use-transfer-pump-66418.html and see if I can get most of the fluid out so I don't make as big of a mess.
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySat Apr 13, 2013 7:39 pm
Changed the filter and oil today. The hand pump from Harbor Freight worked well. It got most of the oil out of the transmission. Also bought this tool http://www.amazon.com/gp/product/B000IHJZD8/. Worked great to remove the seal in the transmission and also used it to help remove the old filter.
Tajis
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptyFri Apr 19, 2013 8:33 pm
I did a pan drop toward the end of last year and again today to help 'freshen' the fluid with some new. I've been putting her on Dex VI and running some Lubeguard Red along with it. I think, however, that if I drop the pan again I'm going to just go ahead and get one of the ZZP pans with the cooling fins and a drain plug. If I go the cheap route I might just add a drain plug to my existing pan.
IFallsRon
PostSubject: Transmission pan drop and drain   Write Up: Transmission Fluid & Filter Change - Page 7 EmptyThu Aug 08, 2013 7:30 pm
How much ATF can I expect to pump out or drain on a '97? I've read writeups and threads that claim capacity from 7 to 13+ quarts.
I'll hand pump out as much as I can before dropping the pan. Like to know that I have enough pan available before the ATF hits the fan.
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptyThu Aug 08, 2013 7:37 pm
Drain and Refill ................................................................. 6 quarts (5.6 L)
Complete Overhaul ............................................................. 10 quarts (9.5 L)
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptyThu Aug 08, 2013 9:55 pm
I believe mine took just a hair under 6 quarts, but I have a 96 (4T60E) versus your 97 (4T65E-HD).
IFallsRon
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptyFri Aug 09, 2013 8:59 pm
If 10, where are the other 4? Finished my drain and re-gasket. I'd say less than a quart of pan spillage after hand-pumping. On a difficulty scale of 1-10, I'd call the job a 3.
96_Juggernaut
96_Juggernaut
Name : Todd Balestrini
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySat Nov 02, 2013 10:32 am
Finally getting a chance to get this done today, however my Duralast filter from Autozone did not include the little O'ring. Is changing that a must? I understand that if the filter goes on to easy then I might have a problem.
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySat Nov 02, 2013 10:33 am
The O-ring....are you referring to the metal ring gasket that the filter snaps in to? If so, as long as the one that's in the car isn't blown out, there really isn't a need to change it.
96_Juggernaut
96_Juggernaut
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySat Nov 02, 2013 10:44 am
Oh so its a metal ring?? from reading the write-up I was under the impression it was a O'ring. My kit sure did come with the metal ring. thanks.
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySat Nov 02, 2013 11:34 am
Yep. It's a metal hat looking thing with cork on the inside. It certainly isn't a bad idea to replace it. Getting the old one out can be a bit of a task though. You have to smash the edges in to pull it out. Careful not to mar up the tranny though. It's just like installing an axle seal or something of that nature. Not hard to do, but carelessness can cause a mess.
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySat Nov 02, 2013 3:13 pm
Using this tool http://www.amazon.com/gp/product/B000IHJZD8/ makes removing the old one a lot easier.
96_Juggernaut
96_Juggernaut
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySat Nov 02, 2013 5:37 pm
Just got it finished. you guys weren't kidding, that damn metal seal is a PITA ! either way its out with just a few little dings in the housing. new filter snapped in and refilled with almost 7 quarts of Dex VI. Just driving around the block everything feels good, positive smooth shifts, no leaks.
KenBluder
KenBluder
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptySun Jan 11, 2015 3:05 pm
My 97 SC is put away for the winter and I want to order a new trans pan with a drain plug. I see two models available: one with 6mm bolts and one with 8mm bolts. Appears to be the same shape and pattern but different size holes. Anyone know which I have? Thanks!
moestippich
moestippich
PostSubject: Re: Write Up: Transmission Fluid & Filter Change   Write Up: Transmission Fluid & Filter Change - Page 7 EmptyTue Apr 12, 2016 3:06 am
Question. I am ready to change the filter in my trans, and the local chain stores only have filters for the 4T65E marked as an exact fit for my 97 Riviera. Would the filter be the same for the 4T65E and 4T65E-HD ?
Page 7 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
» Can you use Automatic Transmission Fluid in your transaxle?
» Afermarket Fuel Pump Replacement for the KQ 700 & 750
» 1970s Simplicity 5008 transmission fluid???
» Oil Change Kit price?
» Oil change for fox shocks
