 FAQ: Upgrading Serpentine Belts & Pulleys?
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Sat Jul 04, 2009 7:07 pm
alright. yeah went by auto zone picked up a 3.5 pulley 4 the s.c tensioner and it fixed my problem max boost is back up 2 10 psi!
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Sat Jul 04, 2009 7:19 pm
Alright. Glad that fixed it.
Can't wait to get my 3.4" MPS on and increase boost.
Gotta do the rockers and springs first though.
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Sun Jul 19, 2009 8:14 am
but my belts r rubbing and u can smell the ruber under wot.
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Sun Jul 19, 2009 8:18 am
just tried using a 1/2 inch shorter belt it dosen"t rub but know i think it sliping agian!
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Sun Jul 19, 2009 9:21 am
I use a 1" shorter than stock belt and haven't had to change any idler sizes. It works perfectly with my 3.4 and 3.2 pullies.
Do you have any of the larger idlers?
Does your tensioner arm move smoothly and freely with the belt off? If it's binding or rough in it's travel you can have the belt loosen up on you.
Merit : 239
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Sun Jul 19, 2009 1:41 pm
Why do you think it's slipping?
'98 SC Riviera • 280k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30
^^^ RIV IS FOR SALE! ^^^
'05 GTO • 49k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26
'95 Celica • 150k miles • 0-60: yes
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Sun Jul 19, 2009 3:29 pm
s.c belt i have a lost in boost when i 1st put the 3.5 tensioner pully i was seeing 10psi with my 3.4 sc pulley but under wot the belt rubed and you could smell the burning ruber. started seeing a decrease in my boost. so i took the belt back off and it actually shaved the groves on the belt down it was rubbing so bad. so i tried a 1/2 inch shorter belt with the stock tensioner pulley 2 see if it would slip like the stock size belt did and if i can get more clearance. i got plenty of clearnce but was only seeing about 7psi of boost like with the stock belt. i just got done a bit ago instaling a 1inch shorter belt it barley fit haven't taking a test drive yet. could it be slipping that bad 2 loose 3psi or does my problem lie elsewhere?
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Sun Jul 19, 2009 3:32 pm
Test drive and see.!!!!
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Sun Jul 19, 2009 5:44 pm
How was it figuring out your 1" shorter belt? Still have the Part Number? What kind of belt did you get and where from?
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Tue Jul 21, 2009 11:27 am
wierd im still not getting boost with the 3.4 as what i did with the 3.5 i did go 2 a 3inch shorty DP with a 3inch pipe in place of the cat. but still im seeing stock boost #s with a 3.4. wonder if my boost gauge is messed up? it is a cheap 1 and i brought it used from a friend.
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Tue Jul 21, 2009 11:32 am
im gonna try again this weekend with the 3.5 tensioner pulley and the stock belt maybe my belt was a little stretched causing it 2 rub the 1st time i tried gonna get a new stock size belt. oh and i just ordered a front plog from zzp!!!
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Tue Jul 21, 2009 12:30 pm
Josh,
Try using some punctuation when you write. It get's a little difficult reading your post's sometimes.
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Tue Jul 21, 2009 12:37 pm
lol my bad
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Tue Jul 21, 2009 12:52 pm
I'm guessing you don't have a belt slip issue, it sounds like there might be something else going on. Can you take a picture of your belt tensioner, idler and supercharger pulleys? I'd like to compare them to what I see on mine. Typically people don't have belt slip until they get to very small pulleys.
I agree with Rick about the punctuation you are not using - it is very difficult to interperet what you are saying.
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Tue Jul 21, 2009 12:56 pm
Yeah i can take some pics. But it have 2 wait until tomorrow. I'm about to leave for work soon. that was another thing I was thinking, is maybe my tensioner is going bad.
Merit : 49
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Tue Apr 09, 2013 8:26 am
Fragged a belt on the way to school today. I just had the stupid thing replaced too.
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Tue Apr 09, 2013 9:10 am
Check your idler pullies and tensioners. Make sure the tensioner pulley is in line with the other pullies (I've seen the tensioner arm pull away from it's base before). Serp belts are very durable.
Merit : 49
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Tue Apr 09, 2013 10:26 am
Will do. If they need replaced, any suggestions? Any way I could get smaller ones that would put out more power?
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Tue Apr 09, 2013 7:20 pm
Smaller idler pulleys would need a shorter belt. Besides, they wouldn't make a difference in power. There are larger water pump and alternator pulleys to slow those both down, but then you would need a larger belt. Not worth it IMHO. Don't you have enough power with a 3.5" SC pulley?
Merit : 49
PostSubject: temp   Tue Apr 09, 2013 8:48 pm
NO. Enough is never enough. Thanks for the advice though, I won't bother with other pulleys.
Well there's your problem. We dislodged the old belt because it got stuck behind the crankshaft pulley. We then discovered that the 3" idler pulley bearing had failed. Ran to AutoZone 10 minutes before the were closing, talked the hopeless employee through what we needed, and replaced the pulley in a dark park n ride lot with just the light of phones, a streetlamp, and the headlights from the truck. I babied it home on the old belt with dad following in the truck. Going to have to leave it parked until Saturday when we can put the new belt on among other things.
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Tue Apr 09, 2013 11:52 pm
matt what year is your riv? mines a 97 and i found a few shortcuts on the belt to do with the year may work on other years too
Merit : 49
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Wed Apr 10, 2013 11:23 am
Mine's a 96. Should be the same layout as yours.
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Wed Apr 10, 2013 8:11 pm
when you get the engine supported and take off the mount drop the engine down enough untill you have a straight shot at the bolt into the bracket. once its out and you drop the spacer the belt change is easy. when putting it back in grind the opisite sides of the spacer at angle to make sliding it in easier and then your all done
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Thu Apr 11, 2013 12:35 pm
Even easier is if you cut the spacer right in half. Then in the future you don't need to lower the engine so the bolt can come all the way out - the bolt only needs to come out far enough to drop half the spacer out, then you can slide the belt through that space.
PostSubject: Re: FAQ: Upgrading Serpentine Belts & Pulleys?   Sat Jul 13, 2013 3:03 am
Alright, im thinking i need to pick up a bigger idler pulley... The pulley i have is a 3.2, and i think i ought to be able to run it, but i need a bigger idler, is http://www.oreillyauto.com/site/c/detail/GATE/38019.oap?pt=02733&ppt=C0328 what i need?
Just to clarify, i am putting the motor in the car right now and this issue arose.
I dont know if this is the proper place for this or not... I hope so!
Page 4 of 5Go to page : Previous  1, 2, 3, 4, 5  Next
» FAQ: Upgrading Serpentine Belts & Pulleys?
» FAQ: Serpentine Belts - Brands and Types
» Write-Up: Replacing Belts and Pulleys
» Taperlock Pulleys
» Serpentine belts were shredding
