 Small engine vibration at idle
jdbell2004
PostSubject: Small engine vibration at idle   Tue Jul 29, 2008 11:38 am
1997 NA with 103K. I noticed when I got the car that the engine vibrates enough I can feel it while in the drivers seat. A friend of mine told me it seems like its missing a little. I don't feel it under load. Should I start by changing plugs? What brand and gap?
-Jon
PostSubject: Re: Small engine vibration at idle   Tue Jul 29, 2008 12:37 pm
That sounds like a good start. Maybe replace the ignition wires, too. Any brand plug should work. Gap = .060"
PostSubject: Re: Small engine vibration at idle   Tue Jul 29, 2008 1:16 pm
My car used to 'spit' a little at idle. I had some bad injectors. Put 'new' (cleaned and flow tested) injectors in and idle cleared right up.
After, of course, everything else is in proper tune.
PostSubject: Re: Small engine vibration at idle   Tue Jul 29, 2008 1:18 pm
Maybe try some injector cleaner before changing them out, but deekster is right - could be injectors acting up.
PostSubject: Re: Small engine vibration at idle   Tue Jul 29, 2008 6:35 pm
cleaning the MAF and changing the fuel filter are some more things you may want to try after the plugs and wires.
manofmany
Seafoam FTW
jdbell2004
PostSubject: Re: Small engine vibration at idle   Sat Aug 02, 2008 2:47 pm
I checked the service records, the plugs and wires were just changed 20K miles ago. I just filled up with premium and things seem to be running better. I suppose I could check, but what octane rating gasoline should I use? How do these cars run on gas with ethanol? Regular gasoline here has ethanol in it.
jdbell2004
PostSubject: Re: Small engine vibration at idle   Sat Aug 02, 2008 2:48 pm
manofmany wrote:
Seafoam FTW
My gas gage reads incorrectly and I heard it's because the float starts to rust. If I run seafoam, will it break this rust up and clog the injectors or filter?
PostSubject: Re: Small engine vibration at idle   Sat Aug 02, 2008 3:02 pm
Although it may have seemed to help, using premium shouldn't make any difference with the N/A 3800. Shell's "V-Power" is supposed to have extra cleaning agents in their premium that could make a difference, but otherwise I wouldn't waste the money. Use 87 octane.
Regular gas only has a small % of ethanol. Using E85 will not result in less power output, and it will clean out your tank and fuel lines, which could result in clogged filter or other problems. I wouldn't use straight ethanol in your car.
I think you'd have to out a lot of seafoam in the tank to break the rust up that much, but changing the filter is rather easy, so why not?
jdbell2004
PostSubject: Re: Small engine vibration at idle   Sat Aug 02, 2008 11:55 pm
I'm going to take a video from inside the car to show you how the rpm's bounce a little. I'll shift through the gears as well.
jdbell2004
PostSubject: Re: Small engine vibration at idle   Sun Aug 03, 2008 2:51 am
Is this normal? The car was already warm. It seems like it idles high. I shifted from park to reverse to drive then back to park. It wasn't really idling rough during the video. It seems to be intermittent.
96RIVMANN
PostSubject: Re: Small engine vibration at idle   Sun Aug 03, 2008 9:49 am
I had the same problem on my '96 so I decided to pull the throttle body off and clean the MAF and up inside the super charger.
http://rivperformance.editboard.com/series-i-engine-transmission-f13/mass-air-flow-t2149.htm
