 Cooling fan
afatboy
Cooling fan Empty
PostSubject: Cooling fan   Cooling fan EmptySun Mar 11, 2007 5:39 pm
I started to have trouble with my cooling fans staying on after I turned off the riv, it came to the point where they were draining the battery. So i did my research and most places said it is either the cooling fan relay, or the coolant temperature switch. Well i replaced both of them and the fan still runs after i turn the riv off, any ideas on what the problem could still be?
Cooling fan Empty
PostSubject: Re: Cooling fan   Cooling fan EmptySun Mar 11, 2007 5:57 pm
Does it happen all of the time? How long do they run after the car is shut off? How hot is your coolant temps when they run with car off?
Cooling fan Empty
PostSubject: Re: Cooling fan   Cooling fan EmptySun Mar 11, 2007 6:19 pm
did you replace all the fan relays? i think there are 3 of them.
Cooling fan Dsc_0110
afatboy
Cooling fan Empty
PostSubject: Re: Cooling fan   Cooling fan EmptySun Mar 11, 2007 6:59 pm
it happens all the time now, the riv isnt overheated when i shut it off.
wait there is a third? i found two relays and the fuse on the passenger side in that black box thing but not a third. where is the third?
Cooling fan Empty
PostSubject: Re: Cooling fan   Cooling fan EmptySun Mar 11, 2007 7:16 pm
in the black box it says cooling fan # 2 and # 3. (relays) and then there is a cooling fan (no #) but it looks like a fuse. page 6-61 in the owners man is my reference.
also # 20 fuse in the fuse box on in the door jam says cooling fan. you might as well just run the multi to all the fuses you can find lol
you problem sounds like a realay and not a fuse. did you say both fan continue to run? do they run while the car is on w/AC off?
Cooling fan Empty
PostSubject: Re: Cooling fan   Cooling fan EmptySun Mar 11, 2007 7:27 pm
quote: "do they run while the car is on w/AC off?"
Why would AC on/off have anything do with it?
Cooling fan Empty
PostSubject: Re: Cooling fan   Cooling fan EmptySun Mar 11, 2007 7:59 pm
when my ac is on, both of my fans run. if its off they are off. i didnt know if his turned off or just ran constant no matter what.
Cooling fan Empty
PostSubject: Re: Cooling fan   Cooling fan EmptySun Mar 11, 2007 8:01 pm
Huh. I didn't know that.
Cooling fan Empty
PostSubject: Re: Cooling fan   Cooling fan EmptySun Mar 11, 2007 8:03 pm
are the 98's set up differently?
Cooling fan Empty
PostSubject: Re: Cooling fan   Cooling fan EmptySun Mar 11, 2007 8:05 pm
Don't know. will have to check it out. I don't remember the fans ever coming on until I reprogrammed the PCM.
afatboy
Cooling fan Empty
PostSubject: Re: Cooling fan   Cooling fan EmptySun Mar 11, 2007 8:21 pm
my AC is almost always off, i ride with windows down cruising since the riv is so badass afro but the fan keeps running non stop. in the black box i have replaced both cooling fan relays and it still runs, but when i take out cooling fan #2 the fans are turn off
both fans are running all the time also
Cooling fan Empty
PostSubject: Re: Cooling fan   Cooling fan EmptySun Mar 11, 2007 8:23 pm
On my 98 with the A/C and heating off, the fans don't come on until 210-215 degrees. They will then shut off around 195-200 degrees.
Cooling fan Empty
Cooling fan
» Cooling Aids For Runners
» inoperable Elect.Cooling Fan?
» KEEPING YOUR FRIDGE(S) COOL...
» Tecumseh engine
» New Cab Heater
