 FAQ: Which tires work best?
Go to page : 1, 2, 3 ... 10, 11, 12  Next
FAQ: Which tires work best? Empty
PostSubject: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyMon Jan 15, 2007 8:52 pm
Why are good tires important? You'll accelerate more quickly and reach higher speeds with good performance tires. Performance tires also allow for better road holding in the corners.
With FWD, tires become more than a handling mod. They are essential in transferring power to the ground. Making extra engine power is of little use if you can't keep the wheels from spinning when you accelerate. Also, better tires often come with higher speed ratings. If you ever choose to disable the speed governor and go flat out, you'd better have at least a set of H-rated tires. A modified Riv can easily exceed the safety margin of most average tires.
The brand of tire you choose is up to you, but generally tires with large, flat patches of rubber (like the BF Goodrich g-force Traction T/As) tend to grip the pavement very well. This will help during launching, an important area of concern with drag racing the Riviera.
The caveat with tires designed for high performance is their dependence on ideal road conditions. Many tires that work well on dry surfaces may exhibit problems in rainy situations, and may be totally dysfunctional in mud or snow. Research tires extensively before you buy. Make sure you are getting something that will work to your needs. Unless you live in the south, this typically means running one set of tires for summer and switching to another set for winter. The Tire Rack is a great resource to learn about and purchase good tires.
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptySat Jan 20, 2007 11:02 am
Other things to consider when buying tires;
Try not to stray from the 225/60/16 size tires that are recomended for the 16" factory rims on the riviera. changing the ratio of the tires could give misreads on the spedo and clearance issues.
The compound of the tire makes a difference in traction and cornering. A hard compound tire will last longer, but the grip will not be as good. On the other hand, a soft tire will have "sticky" launches and corner better, but will not last very long. try to find a happy medium if you drive them daily but sometimes go to the track. there are plenty of great tires that will give good track results and last years*.
(* depends on if you burn the tires at the track smile )
Since the riviera is a luxury automobile it is important to find a tire that rides nice on the highway and is quiet. If you have ever been in a jeep on the highway using off road tires, then you know what causes noise. happy The more air that gets traped in the notches of the tire the more noise it will produce. When looking at tires, try to find one that offsets the tread. Take a look at enconomy tires, the tread is in a straight row all the way around the tire and the pattern is almost unchanged across the width of the patch. A quality touring tire will have a specificly engineered design to keep road noise to a minimum.
If you plan on going to the track with your Riviera, do not buy larger wheels. Stay with 16's or 17's at most. The more rim, the harder it becomes to accelerate. It puts more stress on the steering and tranny components and you will not get good track times.
Also, if you have a 95 or 96 rivera (or any without the HD tranny) do not use drag slicks! you might think its cool running slicks, but it puts too much stress on the diff. durring a launch. Even the HD diffs in the "newer" rivs may not hold up under the stress of a super sticky tire in a launch.
FAQ: Which tires work best? Dsc_0110
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyMon Jan 22, 2007 4:52 pm
I have Michelin HydroEdge tires. They work great in the rain, snow, and dry pavement. All around a better tire then stock.
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyMon Jan 22, 2007 5:57 pm
I'm on my 2nd set of Firestone FireHawk Wide Ovals. Great cornering, decent straight-line accel, and excellent traction on wet roads. And even though they are a summer-only performance tire, not too bad in snow as I found out yesterday!
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptySat Feb 10, 2007 11:43 pm
HAHA well i have the FUSION HRI's they are very good for hard lauches..... but my old tires i could just ignite them !!!!! but now no i can only spin them for 25 feet compareds to easily over 50 feet (prolly depends on tar to!!!!!)
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptySun Feb 11, 2007 10:32 am
quote: "(prolly depends on tar to!!!!!)"
The road surface is a big factor, probably just as important as the tires themselves.
PostSubject: GOT SOME new tread   FAQ: Which tires work best? EmptyMon Jun 18, 2007 6:58 pm
http://www.performanceplustire.com/products/tires/searchType/searchByBrand/manufacturerID/107/productID_/2874#prodAnchor
General Grabber UHP 275/45R20 by General Tire
yess they are truck tires AND obviouslly i got 16's
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyThu Jun 21, 2007 1:07 am
What made you go with those?
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyThu Jun 21, 2007 1:09 am
UMM i gota VERY good deal.... and there sooooo MEATY...... that sounds gay but realy 3/4 inch of tread.
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyTue Jun 26, 2007 9:55 am
FAQ: Which tires work best? 06-19-07_1101
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyTue Jun 26, 2007 11:14 am
are they noisy? looks like they would be good in the rain and off road smile
have you tested them to see how they are? ride quality, traction, grip, road feel, response?
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyTue Jun 26, 2007 11:44 am
not noisy...... GREAT In THE RAIn......... i can spin em on dry tar for more than 3 feet......and they are made for SVT lightings and SRT10 trucks....... GREAT i would DEF buy again
pwmin
pwmin
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyFri Jun 29, 2007 2:10 am
time for some 4-wheelin smile
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyFri Jun 29, 2007 2:32 am
Mud Bogger SS By Buick
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyFri Jun 29, 2007 3:32 am
uumm FOR UR info it is now not an SS anymore..... someone JACKED the badges 6@$†@®d
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyFri Jun 29, 2007 3:50 am
it was a buick fan, they knew damn well those decals didn't belong there
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyFri Jun 29, 2007 6:58 am
pirate lmao
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyFri Jun 29, 2007 10:12 am
umm no it was some kid in a caprice......... i found out like 45 min ago....... he put them on uspide down and the trong way SO LMFAO at him hahhaha................. and i stole em' back and $h!† CANNED EM;.............. for all the haters fµ©k YOU.............jk i see whre ur comin from
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyFri Jun 29, 2007 10:40 am
Hmm. I've never had anyone bother my car, and I don't have any stickers on it... coincidence?
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyFri Jun 29, 2007 10:42 am
HAHAHAHAHA prolly...... lol finger finger finger finger finger
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyFri Jun 29, 2007 7:14 pm
Hah owned
Merit : 135
PostSubject: FAQ: What Tire Does Everyone Run?   FAQ: Which tires work best? EmptyWed Aug 15, 2007 12:11 am
On those 19" wheels im getting tomorrow night are a set of Nitto NT555 series tires. I'm certainly no tire expert but I know the basics. I went to their website and it appears these are a high performance street tire. They feel stickier than my current tires, thats for sure.
Performance rating : "w"
Tread wear : "300"
Traction : "A"
the rim size is 8" wide instead of our stock 7" so I would imagine a handling improvement is not out of the question. Can anyone enlighten me on the grip benefit of these tires.
http://www.nittotire.com/#index%2Etire%2Ent555
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyWed Aug 15, 2007 12:22 am
You'll probably notice a firmer ride, and better cornering just because they are lower profile and wider. Better straight line traction, but harder to accelerate. How much do the wheels & tires weigh compared to stock?
Merit : 135
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyWed Aug 15, 2007 12:26 am
I have no idea what the stock weighs.. When I change it, I can arm it and see but i think they were about the same from when i switched the one before
PostSubject: Re: FAQ: Which tires work best?   FAQ: Which tires work best? EmptyWed Aug 15, 2007 8:58 pm
w = sustained speeds of 168mph. good luck getting the riv up there wink
tread wear of 300 doesnt really mean much since each co uses different test to determine their base line tread rating. but im guessing you will probably get ~25k miles out of them if you stay off the track.
you would think the traction would be better than A for a high performance tire, but they look pretty aggressive and will do well in the rain. hope you have another set for snow weather though.
Page 1 of 12Go to page : 1, 2, 3 ... 10, 11, 12  Next
» ***PRICE REDUCED $2500 +shipping **** FS/FT Work Emitz 18x11(-1) 18x12(-6) no tires
» 2 sets of stock rzr wheels and tires
» FS: Authentic Work VS-KF 20x9.5+4 20x10.5+0 (clears BBK) w/ tires
» Work CR Ultimate (kiwami) 18"
» Work Rezax Wheels with fresh tires!!!!!!!!!!!!!!!!!!!!
