| HUD display in Riviera? | |
+20sburch23 97rivsc curious riv Rickw SuperRiv07 SToP Buickman104 deekster_caddy Mr.Riviera 1998 Riv BillBoost37 stan BoattailBob Supercharged Chicken IBx1 albertj oldsman105 Andysdorm KillaKeninaRiv 24 posters |
oldsman105 Junkie
| Subject: Re: HUD display in Riviera? Wed Aug 27, 2008 11:57 am | |
| - BillBoost37 wrote:
- Anyone know how close the Riv dash shape is compared to the Regal/GP. I'm thinking if the trim panel fits or can fit then I'd share the info about adding a hud.
What Riv owner wouldn't want a hud? \ OH OH OH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! What kind if pics do you need. and the riv dash is flat on top. | |
BillBoost37 Junkie
| Subject: Re: HUD display in Riviera? Wed Aug 27, 2008 12:16 pm | |
| Send me all the pics you can. Heck.instead of worrying if the whole panel fits.....we could always come up with a small raised area.
The biggest thing is if there's enough room under the dash by the window and I can't imagine there wouldn't be.
I understand about the Riv standing out. What other Buicks in that era had HUD? | |
| Subject: Re: HUD display in Riviera? Wed Aug 27, 2008 12:25 pm | |
Buickman104 Enthusiast
Age : 38 Location : New York City Joined : 2007-11-29 Post Count : 156 Merit : 0
| Subject: Re: HUD display in Riviera? Wed Aug 27, 2008 5:18 pm | |
| Yup! It was an option in the Park Avenue Ultra! | |
KillaKeninaRiv Addict
Name : Kenneth Age : 41 Location : Roseville, MI Joined : 2008-05-17 Post Count : 709 Merit : 6
| Subject: Re: HUD display in Riviera? Thu Aug 28, 2008 8:54 pm | |
| damn and the retarded thing is that my friend had a hot Park Avenue Ultra in a garage and I didnt get it out of there in time | |
| Subject: Re: HUD display in Riviera? Thu Aug 28, 2008 10:28 pm | |
| i am extremely interested in this HUD thing,but it can be hard to install/fit. | |
| Subject: Re: HUD display in Riviera? Sat Aug 30, 2008 3:57 am | |
| Hey Bill! Oldsman volunteers to be the first Riv Test mule!
Just be warned Olds does not do good write ups! LOL | |
oldsman105 Junkie
| Subject: Re: HUD display in Riviera? Sun Aug 31, 2008 9:00 pm | |
| i checked a junkyard saturday..no luck. two grand prixs no HUD so ill check monday then at the other one across town. they had two rivieras in there a few weeks ago | |
SToP Enthusiast
Name : Rob Location : SK, Canada Joined : 2008-10-27 Post Count : 100 Merit : 2
| Subject: Re: HUD display in Riviera? Sun Nov 02, 2008 4:12 pm | |
| I was looking to do the same thing and came across this thread. Looking at the diagrams for a '98 GP, there's a few trick points. Pin A7 is the speedo input at 4K PPM. Pin 55 on the '98 Riv blue PCM connector provides 4K PPM to the IPC, Magnasteer, BCM and cruise modules. The Riv's coolant hot, low voltage and low fuel lights look to be lit via the IPC circuitry itself but you could tap into the ckt for the light itself. I need to check the polarity first but most GM stuff is switched on ground where the Riv's lights are switched on voltage. Might just need some relays to switch polarity. The low oil light can be tapped into the wire at the IPC connector and then just tap into the signals and headlights for the rest. I still need to double-check some polarities but after that the only question left is will it fit? Wasn't there a thread somewhere in here where someone was reupholstering their dash pad? | |
SuperRiv07 Addict
Name : Nick Age : 39 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
| Subject: Re: HUD display in Riviera? Sun Nov 02, 2008 4:21 pm | |
| What about the Hud From a 2004 buick lesabre Would that work ? | |
| Subject: Re: HUD display in Riviera? Sun Nov 02, 2008 4:23 pm | |
| "New Riv owner" Page 2 For dashboard recovering. | |
| Subject: Re: HUD display in Riviera? Sun Nov 02, 2008 4:30 pm | |
SToP Enthusiast
| Subject: Re: HUD display in Riviera? Sun Nov 02, 2008 4:32 pm | |
| RickW - that was the thread, thanks! I was hoping to see some shots of how much room was in there, but never saw the right angle.
SuperRiv07, I'm looking at the HUD diagram for the LeSabre right now. Looks like a lot of the data is fed via class II serial data. I don't think the Riv PCM can provide that if it wasn't programmed for it. Signal lights and speed look easy though. | |
SuperRiv07 Addict
| Subject: Re: HUD display in Riviera? Sun Nov 02, 2008 4:44 pm | |
| well dam I kinda want this hud what will work then | |
curious riv Addict
Name : Chris Age : 44 Location : C'view FL Joined : 2008-10-20 Post Count : 521 Merit : 3
| Subject: Re: HUD display in Riviera? Sun Nov 02, 2008 8:05 pm | |
| - Chicken wrote:
- man, you bastards are a tough crowd...
nobody noticed I spelled Riviera wrong....hahaahaha I almost pissed myself laughin...(thanks ckickin) that was great | |
97rivsc Fanatic
Name : mike Age : 34 Location : appleton wisconsin Joined : 2008-09-28 Post Count : 437 Merit : 0
| Subject: Re: HUD display in Riviera? Mon Nov 03, 2008 1:09 am | |
| this is an awesome idea. the riv needs the hud it would look so good. has anyone had any success with it yet? or in the process of attempting it? | |
| Subject: Re: HUD display in Riviera? Mon Nov 03, 2008 10:32 am | |
| Hey SToP, It appears you have more knowledge than I on the various communication / electronics protocols used on these vehicles. Maybe you could do a write up or attach some links to some elementary information about the various protocols used and how to better understand them. I worked on Transport Category Aircraft for a number of years and understood most of those systems, but I did not design or engineer any of it, so it still left me without detailed knowledge. Thanks for any input you may have on the subject. I also have a spare PCM I could send you if that would help in figuring out the HUD Mod. | |
SToP Enthusiast
| Subject: Re: HUD display in Riviera? Mon Nov 03, 2008 12:26 pm | |
| I wouldn't say that, RickW. This new stuff is really complicated, plus the fact that the OBD-II "standard" has so many different flavors.. I barely know enough to get by these days! I based my comment that "a lot of the data is fed via class II serial data" on the pinouts of the HUD connector schematic. There weren't a lot of the connections I would expect (hot, voltage, etc.) but there was one pin labeled "Class II Serial Data". I made an ASSumption. The next thing to do in the HUD project is to find out if it will physically fit under the top dash pad. We'll have to cut a hole in the pad but nothing a yard of vinyl can't cover. After that, track down a HUD from ebay or something and then start wiring it up. Hopefully I can find myself a Riviera soon! | |
| Subject: Re: HUD display in Riviera? Mon Nov 03, 2008 2:09 pm | |
| If I am not mistaken ther is room for HUD guts under the dash pad but there was some reason a HUD was not offered (this cam up in a casual conversation with someone in GM's R&D organization). I do not remember if it was a problem with the optics (if you look at it, actually there is not much vertical height to the Riv windscreen), glare (which is why you Never Armor-All Your Dash, natch), or a design decision based on the Riv cockpit being a sort of modern interpretation of that of the original riv (hence the large round speedo, and lack of other instrumentation; also lack of a driver info center although the sensors and stuff are all there like on the Aurora.
Think fast - it would not have been that big a deal to use about the same dash for the Riv as was put in the Aurora...
To get an idea what I mean, take a 3x5 or 4x6 index card and put it on the dash when you're out in the daytime. Put it over the middle (between tach and speedo over the fuel/amps gauges) instument panel gauge cluster, on top of the dash pad,with the edge nearest the windshield about 3/4 the way down the pad. . Notice how much space the glare from that card claims in the field of view. The place where the card *is not* is the remaining unobstructed field of view.
Kind of a lot of real estate.
| Subject: Re: HUD display in Riviera? Mon Nov 03, 2008 4:59 pm | |
| SToP, Where are you getting the schematic's that your able to refer to ? Online somewhere, or do you have paper copies?
Albert has a good point about the glare off these Riv dashboards, I hadn't thought of that although every time I drive in the sun I do. These are terrible for windshield glare. As Deekster mentioned sometime back you need to wear polarized sunglasses all the time while driving, sometimes even on cloudy days. Maybe it's just the color of my interior but from what I've been reading I think it's all of them. | |
SToP Enthusiast
| Subject: Re: HUD display in Riviera? Mon Nov 03, 2008 6:51 pm | |
| Good points, Albert! Something to definately keep in mind. I have not seen the '97+ GP HUD yet but I have retrofitted a pre-97 GP HUD into another project and only needed a 2x2 inch hole cut in the dash. Reatta dash, GP HUD, LeSabre drivetrain and ECM, Riviera BCM... Whew, what a project! Rick, schematics are printed from my local library's subscription to alldata online. | |
sburch23 Addict
| Subject: Re: HUD display in Riviera? Mon Nov 03, 2008 9:40 pm | |
| Other donor cars are Buick Park Avenue ULTRAs and Pontiac Bonnevilles. | |
SToP Enthusiast
| Subject: Re: HUD display in Riviera? Tue Nov 04, 2008 9:37 am | |
| True, sburch23.. Anyone have pics of what the HUDs in these cars look like? | |
| Subject: Re: HUD display in Riviera? Sat Nov 08, 2008 9:39 pm | |
| In the PA or the GP? I have a pic of the Grand Prixs and ZZPerformance sells the units for $50 | |
| Subject: Re: HUD display in Riviera? | |
