| Looking for someone with scanner | |
SuperRiv07 Addict
Name : Nick Age : 39 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
| Subject: Looking for someone with scanner Tue Sep 02, 2008 3:44 pm | |
| ok well im going to be installing intense 3.4 pulley when i get it here, and I am installing a 4in FWI right now and the 180 thermostat and A 3in down pipe So What I need is someone in the area to scan my car and set it right for lets say a case of beer I dont know so let me know asap | |
| Subject: Re: Looking for someone with scanner Thu Sep 25, 2008 12:04 am | |
| You're in IL? How far is ZZP in Michigan? Call them up, make an appt and they'll tune it for you. I'd be there if I was fairly close. | |
SuperRiv07 Addict
| Subject: Re: Looking for someone with scanner Thu Sep 25, 2008 10:25 am | |
T Riley Guru
| Subject: Re: Looking for someone with scanner Thu Sep 25, 2008 2:01 pm | |
nothincame2mind Aficionado
Name : Ryan Age : 38 Location : Columbia, Missouri Joined : 2007-01-19 Post Count : 1182 Merit : 20
| Subject: Re: Looking for someone with scanner Thu Sep 25, 2008 4:22 pm | |
| ZZP is in Grand Rapids, about 3 hours from Chicago. They were on South Division, but they've moved and I'm not sure where. How far are you from Canton (Northeastern), MO? | |
SuperRiv07 Addict
| Subject: Re: Looking for someone with scanner Thu Sep 25, 2008 5:20 pm | |
| pretty far I think Im In chicago so Mo is like 6 hours awaydoing the speed limit, I just need some one that dont mind tuneing to run right with the 3.4 on there i know you cant tune it in one try so I know we will have to mess with it but I will suplly lunch and beer for whoever wants to make a weekend of dicking with cars? | |
| Subject: Re: Looking for someone with scanner Thu Sep 25, 2008 5:29 pm | |
| When you do the DP, you'll need to adjust your tune again, so maybe wait until you have everything installed before you do the PCM. Just throwing that out there... I i were planning both DP and 3.4", I'd do the DP first, probably wait on the pulley. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
SuperRiv07 Addict
| Subject: Re: Looking for someone with scanner Thu Sep 25, 2008 5:42 pm | |
1wickedninja Addict
Name : Josh Age : 35 Location : port saint lucie, Fl Joined : 2008-07-30 Post Count : 647 Merit : 5
| Subject: Re: Looking for someone with scanner Thu Sep 25, 2008 6:32 pm | |
| I am also looking for someone with a scanner in my area since I don't have a laptop it would be pointless for me to buy one. But I am looking into getting a aeroforce scangauge in a couple of months. | |
SuperRiv07 Addict
| Subject: Re: Looking for someone with scanner Thu Sep 25, 2008 7:12 pm | |
| i also am looking into the aeroforce scan gauge | |
| Subject: Re: Looking for someone with scanner Thu Sep 25, 2008 8:38 pm | |
| - 1wickedninja wrote:
- I am also looking for someone with a scanner in my area since I don't have a laptop it would be pointless for me to buy one. .....
A SCANNER does not require you to have a laptop. A tuner does, if that's what you meant. | |
| Subject: Re: Looking for someone with scanner | |
