 FAQ: Which tires work best?
Go to page : Previous  1, 2, 3 ... 10, 11, 12
Merit : 49
PostSubject: Re: FAQ: Which tires work best?   Wed Feb 11, 2015 10:31 pm
It will probably mess up the balance if you do them yourself. They probably don't mount them inside the rim because of all of the gunk buildup that they would have to clean to get the adhesive on the weights to stick.
Merit : 171
PostSubject: Re: FAQ: Which tires work best?   Thu Feb 12, 2015 8:35 am
You absolutely cannot balance the tire yourself. There's a significant weight difference between the bang-on and stick-on weights as far as centrifugal force is concerned. You're moving the location of the weight closer to the center of the wheel in all directions. Doing so requires more weight to keep the same balance.
Firestone guys didn't do it wrong by putting bang-on weights on the wheels. The car came factory with them, so that's what they used. We do the same thing unless otherwise requested by the customer. So, the wheel weights are only supposed to go where they were originally. On most applications where the wheel has a lip, there's a weight that fits it. I don't usually go around defending tire shops (most of us know they suck ass), but in this situation, unless asked to use sticky weights, they did nothing wrong.
Merit : 83
PostSubject: Re: FAQ: Which tires work best?   Thu Feb 12, 2015 9:18 am
O.K., learn something new every day. I can't say I'm happy seeing the wheel weights on the outside, but maybe I can tune them out. I've spent enough time waiting for tires.
Merit : 49
PostSubject: Re: FAQ: Which tires work best?   Thu Feb 12, 2015 11:19 am
Has anyone tried a 235/50R16 on the stock wheels?
Merit : 83
PostSubject: Re: FAQ: Which tires work best?   Thu Feb 12, 2015 3:48 pm
Is there any reason why I can't retorque my lug nuts on the ground (I'm assuming they were torqued too high with an air wrench)? I'm thinking the rim may end up off center some tiny fraction of a millimeter, but I could be worried about nothing.
KnottyEagle
PostSubject: Re: FAQ: Which tires work best?   Thu Feb 12, 2015 4:00 pm
You can retroque them. Just take the tire off and torque it till' your little heart desires. happy
You can't torque to 100 ft-lbs and expect it to be 100 ft-lbs if the shop tightened them higher with the impact gun. It doesn't magically "torque down" if that makes sense.
Merit : 171
PostSubject: Re: FAQ: Which tires work best?   Thu Feb 12, 2015 4:13 pm
Assuming they used a Torque Stick for the 19mm lug nut, which torques them down to 100 ft/lbs, I wouldn't worry about it. However if you feel the need to do so, just leave the car on the ground, and do 1 lug nut at a time. No need to lift the car up. Just loosen a lug, then torque it down, repeat.
Merit : 83
PostSubject: Re: FAQ: Which tires work best?   Thu Feb 12, 2015 5:41 pm
I have no idea what they did. The lugs could be torqued perfectly, but if they're overtorqued and the rotors warp it'll be my fault for not making sure.
Merit : 49
PostSubject: Re: FAQ: Which tires work best?   Thu Jun 11, 2015 4:18 pm
Anyone have experience in buying autocross oriented tires? Looking for something cheap.....
PostSubject: Re: FAQ: Which tires work best?   Thu Jun 11, 2015 4:40 pm
Look for "Summer performance tires" in your size. Get MPSS if you can afford them, because they are totally awesome. But otherwise, see what's in your budget. Read tirerack reviews, look specifically for agressive drivers or track related commentary in the reviews.
Are these for the Riv?
Merit : 171
PostSubject: Re: FAQ: Which tires work best?   Thu Jun 11, 2015 5:25 pm
http://www.tirerack.com/tires/tires.jsp?tireMake=Hankook&tireModel=Ventus+Z214&sidewall=Blackwall&partnum=24ZR8Z214C71OLD&tab=Sizes
You'd better jump on this now, dude. They have fewer than 7 available. 245/40/ZR18 track tires
Merit : 49
PostSubject: Re: FAQ: Which tires work best?   Thu Jun 11, 2015 5:38 pm
Daaaaaaang.....
PostSubject: Re: FAQ: Which tires work best?   Thu Jun 11, 2015 8:34 pm
yeah, for real. DANG!
Page 12 of 12Go to page : Previous  1, 2, 3 ... 10, 11, 12
