 Did I screw up my spark plug wires?
Did I screw up my spark plug wires? Empty
PostSubject: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptyTue Mar 13, 2007 7:29 pm
So, I'm in the process of changing my spark plugs to 605's. When I pulled the plug wires off, two of the metal ends (of the plug wires) stayed on the old spark plugs. I had to get pliers to pull them off the plugs. I pushed the metal ends back up in the SP end, but I don't know if I got it far enough in. Dumb question: OK, two questions...Did I screw up my plug wires? Is that center core (whatever you want to call it) supposed to be attached to the metal thing or just make contact with it? dunce
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptyTue Mar 13, 2007 7:36 pm
How old are wires, and what kind are they?
Most likely you'll need a new set.
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptyTue Mar 13, 2007 7:53 pm
Year and a half old. They are aftermarket, O'Rielly's lifetime warrenty. I think I paid $60 for them. They should replace them for free.
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptyWed Mar 14, 2007 7:17 am
Ok I lied, I found the invoice...$30. I guess I'm goin to take off work and change the plug wires this morning since you're not telling me what I want to hear. rolleyes Never fails, I try to do something simple and it turns into a cluster fµ©️k. headshot At least it's goin to be 80 degrees today!
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptyWed Mar 14, 2007 5:33 pm
She runs MUCH better now. I just can't decide if it runs better because I changed the plugs and wires or if it's because I cleaned and waxed her? wink
I know it's total bs, but does anyone else think their car runs better when it's clean??burnout
NO 4 EVR
NO 4 EVR
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptyWed Mar 14, 2007 6:41 pm
Not really when it is clean as much as when I do some simple maintenence or repair to it. Even some simple light bulb replacement or such. I haven't cleanded the riv in a while so I will have to test that out.
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptyWed Mar 14, 2007 11:24 pm
Taking stuff out of the car adds about 20 hp. wink
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptySun Mar 25, 2007 6:47 pm
the wax gives better air flow over the paint so you have less drag wink thats like 3 seconds off your 1/4 miles time happy
bs but i notice it runs better when clean too
Did I screw up my spark plug wires? Dsc_0110
Blowin95
Blowin95
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptyWed Mar 28, 2007 3:09 am
Wow Jack, this happened to me yesterday when I was checking a plug that is known to be laden with ash. All of my 104s are fine but my car is running like shiznit!! Whenever I accelerate too hard I get severe bucks....like fuel insn't being delieverd fast enough bucks, not tranny bucks..haha Grrr. I really think its the wires...back to Napa I go for a replacement.....
http://myspace.com/rumblinriv
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptyWed Mar 28, 2007 9:02 am
It's your wires, 95% certain. OEM are the best, Imo. They'll often last 100k miles.
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptyWed Mar 28, 2007 10:11 am
could be a dirty maf. they can cause wierd problems at mid throttle+. if wires dont fix it then buy a $3 can of intake/maf cleaner and spray it down, at the very least you'll have a clean intake and get proper readings from the maf.
NO 4 EVR
NO 4 EVR
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptyWed Mar 28, 2007 11:48 am
Or my problem with coil packs sounded similar. Make sure they are good.
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptyWed Mar 28, 2007 12:10 pm
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptyWed Mar 28, 2007 5:03 pm
My bet is on the plug wires!wink
Blowin95
Blowin95
PostSubject: Re: Did I screw up my spark plug wires?   Did I screw up my spark plug wires? EmptySun Apr 01, 2007 5:30 am
Update: It was the wires....good thing I bought the Beldens, lifetime guarantee. I went to Napa and replaced the set...no cost wink
» NGK Spark Plug Finder...
» briggs and stratton v-twin spark plug (confused)
» Common Spark Plug Conditions
» How do I check if I'm getting spark?
» Spark for Hinomoto MB 1500
