| | Write-Up: Exterior Mirror Disassembly | |
+12flyineagle96 DEMonte1997 LARRY70GS detroiter91 GMFreak8 Eldo BMD sqrivi Rickw palermocorey90 captshiner 99Rivman 16 posters | |
| Subject: Re: Write-Up: Exterior Mirror Disassembly Wed May 04, 2011 4:51 pm | |
| - BMD wrote:
- Looks great Larry, nice find. If you don't want the added thickness, another option is too swipe a mirror from an Aurora with the correct backing plate to pop it into the original housing on the RIv.
I'll definitely keep that in mind. The Burco mirror is very thin. You really don't notice the added thickness unless you look closely for it. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | Tajis Amateur
Name : Tajis Age : 38 Joined : 2012-08-24 Post Count : 28 Merit : 3
| Subject: Re: Write-Up: Exterior Mirror Disassembly Mon Sep 17, 2012 6:26 am | |
| Hey, I may have sourced a mirror assembly to replace mine. It's a pull from 1995 Olds Aurora with the heated glass, but no tinting. It's the entire assembly, though, and I can get it for $50. Will this work with my 99 Riv? | |
| | | llamalor2112 Junkie
Name : Evan Age : 31 Location : Granite Falls, WA Joined : 2012-07-13 Post Count : 852 Merit : 13
| Subject: temp Mon Sep 17, 2012 4:14 pm | |
| | | Z-type Aficionado
| Subject: temp Wed Oct 03, 2012 9:14 pm | |
| I changed my driver's side mirror today finally. Had a little change of plans though. I never used the mirror I so tediously painted from the Aurora. The wiring harness was just way too different. I ended up swapping the glass from the Aurora onto my original mirror/motor casing. It's nice to finally have a mirror I can see in, but no autodim for now . Evidently this Aurora didn't have that feature, just the heating. That's ok though. As long as my interior rearview works, I'm happy! | |
| | | EyeDoc1 Enthusiast
Name : Christen Location : Vancouver, WA Joined : 2016-03-30 Post Count : 125 Merit : 5
| Subject: Re: Write-Up: Exterior Mirror Disassembly Tue Aug 23, 2022 3:45 pm | |
| Here's a question. My son not only broke the light sensitive mirror (heated-non memory) on his '98, but actually broke some of the internal mount points where the mirror screws in. While I can get a replacement mirror (easy part), apparently the powers that be "changed" something between '95-'97 and the '98-'99 assemblies. Question. Can you take the housing from a '96 (in the junkyard NOW) and graft what is currently in the '98 to the older '96 housing. Likely there are plastic tabs inside the housing, but who know, GM may have moved them or came up with something different. Take a look about 4 pictures up and you'll see the "innards" of a mirror housing. I just wanna know if this will work on a '98, because that's all I got in the junkyard at present...August, 2022. (Pick 'n Pull-Portland OR) | |
| | | Sponsored content
| Subject: Re: Write-Up: Exterior Mirror Disassembly | |
Similar topics | |
