| MAP failure | |
Karma Aficionado
| Subject: MAP failure Wed Aug 27, 2008 12:16 pm | |
| so, quick question, what's it mean if after a 6 min drive or so, and the scan tool picks up 4-5 MAP failures? _________________ | |
| Subject: Re: MAP failure Wed Aug 27, 2008 12:32 pm | |
| Either a plug or vacuum line is probably disconnected or loose.
? more info? | |
Karma Aficionado
| Subject: Re: MAP failure Fri Sep 05, 2008 12:59 pm | |
| does it make sense that 3 MAP failures shows up as soon as the car is started? Even with clearing the scantool? No matter if the trip is 3 min, or 2 hours, the tool reads 3 MAP failures.... _________________ | |
'96reese Fanatic
| Subject: Re: MAP failure Fri Sep 05, 2008 7:43 pm | |
| yap...this happen to me a couple of times. i had to disconnect the map sensor and hook my multimeter and jumper wire up to read the voltage. i would suggest replacing the map sensor. what is the p code number? | |
| Subject: Re: MAP failure Fri Sep 05, 2008 10:28 pm | |
Karma Aficionado
| Subject: Re: MAP failure Sat Sep 06, 2008 12:48 pm | |
| yeah, see thats the thing, its not throwing a code.... _________________ | |
'96reese Fanatic
| Subject: Re: MAP failure Sat Sep 06, 2008 3:13 pm | |
| looking on alldata and its not showing a map sensor for your 95 sc riv | |
| Subject: Re: MAP failure Sat Sep 06, 2008 3:42 pm | |
| OK, what's a "MAP FAILURE" if it's not throwing a code then? Sorry, I'm not that familiar with OBDI. | |
Chicken Aficionado
Name : Mark Age : 57 Location : Montana Joined : 2008-06-13 Post Count : 1296 Merit : 8
| Subject: Re: MAP failure Sat Sep 06, 2008 3:49 pm | |
| - deekster_caddy wrote:
- OK, what's a "MAP FAILURE" if it's not throwing a code then? Sorry, I'm not that familiar with OBDI.
Let go, Deek..... | |
| Subject: Re: MAP failure Sat Sep 06, 2008 4:39 pm | |
| My eyes were closed when I typed that. Hence the typo, Of course I meant to type OBI 1 but since I wasn't looking it came out OBDI. The hardest part was clicking the Send button with the force... | |
Karma Aficionado
| Subject: Re: MAP failure Sun Sep 07, 2008 7:37 pm | |
| yeah, i believe there is not a MAP sensor for the series 1... i was just looking at the data lists on the scan tool, shows all the things, and each time i drive 3 MAP failures shows up in the second section of car data. No codes. I dunno, maybe its nothing... _________________ | |
| Subject: Re: MAP failure Sun Sep 07, 2008 9:31 pm | |
| There should be a MAP sensor. It's a sensor that's been around for years. That's how they measure Vacuum. Look for a vacuum line and wire going to the same sensor.
Anyone have a pic of where it lies on an SI? | |
ricos20002 Member
Name : Robert Age : 40 Location : Copperas Cove, Texas Joined : 2008-10-22 Post Count : 84 Merit : 1
| Subject: Re: MAP failure Thu Apr 02, 2009 7:07 pm | |
| I've looked everywhere and can't find one on mine, so I dont know | |
| Subject: Re: MAP failure | |
| MAP failure | |
