| Scrunch sound on front right when going over bumps | |
DEMonte1997 Aficionado
| Subject: Scrunch sound on front right when going over bumps Mon Oct 26, 2009 10:49 pm | |
| I'm guessing this is a bad strut mount but not 100% sure. A better description is that it makes a scrunch sound when it hits a speed bump and then makes the noise again after it goes over it. Really annoying. Anyone else have this problem?
Last edited by DEMonte1997 on Mon Oct 26, 2009 10:51 pm; edited 1 time in total | |
T Riley Guru
| Subject: Re: Scrunch sound on front right when going over bumps Mon Oct 26, 2009 10:51 pm | |
| - DEMonte1997 wrote:
- I'm guessing this is a bad strut mount but not 100% sure. A better description is that it makes a scrunch sound when it hits a speed bump and then makes the noise again after it goes over it. Really annoying. Anyone else have this problem?
Yes.. turned out to be my strut mounts.. Easy fix if you have done struts before | |
| Subject: Re: Scrunch sound on front right when going over bumps Mon Oct 26, 2009 10:52 pm | |
| You need a spring compressor tool to do them, right? I might get a set of them from rockauto and take care of them by the end of the week. | |
T Riley Guru
| Subject: Re: Scrunch sound on front right when going over bumps Mon Oct 26, 2009 10:55 pm | |
- You need a spring compressor tool to do them, right? I might get a set of them from rockauto and take care of them by the end of the week.
Ya your best bet would be to get some KYB GR2's.. and some strut mounts.. rent the tool from Autozone or oreileys... good luck.. | |
| Subject: Re: Scrunch sound on front right when going over bumps Mon Oct 26, 2009 11:23 pm | |
| Check out your anti-sway bar bushings, too. If they've been replaced with poly, they'll make this noise after about 6 months. One way to be sure is to disconnect sway bar links and test (less work than replacing struts and finding out it's the bushings). _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Scrunch sound on front right when going over bumps Mon Oct 26, 2009 11:39 pm | |
| That's a great call Aaron. I put in poly endlinks a few months ago. Makes me wonder if that is making the noise. Hmmmmm | |
| Subject: Re: Scrunch sound on front right when going over bumps Mon Oct 26, 2009 11:44 pm | |
| Put some grease on them and see if it helps. I used to grease my poly bushings twice a year, but I used hard rubber links. I replaced them with Energy Suspension hard rubber w/grease fittings - no more noise. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Sweepspear Fanatic
| Subject: Re: Scrunch sound on front right when going over bumps Tue Oct 27, 2009 10:46 am | |
| In replacing my front control arm bushings, I replaced the sway bar links with new AC Delco links. They have blue bushings which I assume are poly? I think that is the source of the scrunching sound I now have. | |
| Subject: Re: Scrunch sound on front right when going over bumps Tue Oct 27, 2009 11:14 am | |
| I've seen blue, black, and red rubber link bushings before. I thought AC Delcos were rubber. You can tell a rubber bushing by its soft material. Poly bushings are a harder plastic. They won't flex as much under load. You can tell the difference just by touching them. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Scrunch sound on front right when going over bumps Tue Oct 27, 2009 12:31 pm | |
| Also check your sway bar end links - sometimes they break and can make some noise. | |
Sweepspear Fanatic
| Subject: Re: Scrunch sound on front right when going over bumps Tue Oct 27, 2009 1:46 pm | |
- I've seen blue, black, and red rubber link bushings before. I thought AC Delcos were rubber. You can tell a rubber bushing by its soft material. Poly bushings are a harder plastic. They won't flex as much under load. You can tell the difference just by touching them.
I'm not sure what they are made of quite frankly. They seem harder than what I know of the black rubber bushings. Not sure why they would be blue to begin with. I do know they are noisy. I had first tightened them by feel, then after finding they were noisy went back and torqued them to the spec in the book which was 18 ft lbs IIRC. That was just a waste of time. The other day when driving in the rain I went over a speed bump I go over everyday and they didn't make noise. I imagine they were lubed by rain water. I've never had a set of these that I have replaced over the years make noise when they were black rubber. | |
| Subject: Re: Scrunch sound on front right when going over bumps Tue Oct 27, 2009 2:16 pm | |
| Are the anti-sway bar bushings made of rubber?
What if you remove the links and try driving - does the noise go away? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Sweepspear Fanatic
| Subject: Re: Scrunch sound on front right when going over bumps Tue Oct 27, 2009 2:36 pm | |
- Are the anti-sway bar bushings made of rubber?
What if you remove the links and try driving - does the noise go away? I don't know for sure what they are made out of. Not rubber as I know it. Maybe a synthetic rubber. Nylon? They have a glossy smooth finish. This is the part #. AC Delco Part #45G0000 I don't know that I want to take the time to remove them and drive the car. Then put them back in. I'm 100% positive they are what is making the noise. It's only over speed bumps that I hear it. If it was noisy during normal driving I would have more of an issue with it. | |
| Subject: Re: Scrunch sound on front right when going over bumps Tue Oct 27, 2009 10:31 pm | |
| So it rained today and the sound was completely gone. Dried up tonight and the sound came back. We still on the swaybar bushing trail? That's what I'm guessing. What would you guys grease endlinks with, bearing grease? It's going to be a PITA to get between those pieces so I guess I'll be taking all that apart and putting it back together. Wonder why it's only on one side and not the other... | |
| Subject: Re: Scrunch sound on front right when going over bumps Tue Oct 27, 2009 10:39 pm | |
| I'm kinda thinking dried out strut mount, or a bad strut, but it's really hard to just keep guessing... | |
| Subject: Re: Scrunch sound on front right when going over bumps Wed Oct 28, 2009 9:15 am | |
| If you disconnect the and links on both sides, the bar will not move as the car rides. If the noise goes away you've narrowed it down to to something on the anti-sway bar. If the noise continues, you know it's not related to the ant-sway bar. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Scrunch sound on front right when going over bumps | |
