 FAQ: Aeroforce Interceptor Scan Gauge
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Fri Jan 04, 2013 8:57 am
Evan, no sorry only OBDII cars ('96+).
Charlie, the main difference is the Aeroforce is a gauge, so it's smaller and can be mounted as part of your dash, rather than using a smart phone type device. It can display more than two parameters, just not more than two at one time. However it can monitor ALL parameters, triggering alarms, so you really don't need to see so many. Also, 2 or 3 gauges can be used together to display 4 or 6 parameters in about the same space needed for a smartphone or mini tablet.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Mon Apr 15, 2013 6:30 pm
Is there anyway to 'split' the OBD-II interface to use multiple I/O devices?
PostSubject: temp   Mon Apr 15, 2013 6:32 pm
Yes. I believe Aeroforce sells the splitter adapters for running multiple gauges: http://aeroforcetech.com/accessories.html
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 1:04 pm
Installed aeroforce interceptor gauge, one issue though, it doesnt turn on when i turn the car on, i have to unplug it then plug it in while the cr is running. All i get when i turn on the car is those two red lighta blinking, anyone have experiencewith these?
Merit : 127
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 1:33 pm
What year riv? If it's 96-97, you gotta hook up that extra switch lead and remove the jumper.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 2:35 pm
Hi, mine is a 98, damn i keep forgetting.to put that in my sig
PostSubject: temp   Thu Sep 19, 2013 3:39 pm
Mine works fine in my '98 just hooked up to OBDII port. I didn't need to wire the extra hot lead.
EDIT: correction, I used the red lead!
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 3:47 pm
Eesh, idk what to do then lol
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 4:23 pm
Sorry, I think I led you wrong. Looking at pics of my install, there is a 3rd wire, I think it goes to accessory power. Make sure you have a good connection at the fuse box.
From Aeroforce user manual:
"5. Connect 3 wire mini connector power. If required*, connect separate red
power wire, which exits the middle of the 3 wire mini cable as shown in figure 1,
to a switched 12v line or circuit in the vehicle. These circuits are commonly
known as “accessory” circuits because they are only “hot” when the ignition is
turned on. A recommended way of doing this step is to use a product called an
“Add a Circuit”, made by Littelfuse, available at most car parts outlets. These
kits, which sell for under $10, allow you to easily use an existing circuit in the
fuse block to power an add-on accessory such as the Interceptor without the need 4
to cut or splice any wires. The use of this kit is highly recommended, as most of
the problems with the gauge can be traced to a poor selection of a 12v wire, or
poor connection. If the gauge randomly turns off and on while driving, 90% of
the time it is a poor connection to 12v or an improper circuit was tapped into,
such as a signal wire to the instrument panel.
*This power wire is not needed on all vehicles, if your cable has this separate red
wire in the center of the 3 wire mini connector it needs to be connected as
described above. Most GM vehicles made through 2006 require this connection."
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 5:08 pm
Do you have a right up for your install ?
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 5:15 pm
I posted some pics, but not much on the wiring - just fabrication of the pod:
http://rivperformance.editboard.com/t189p225-write-up-installing-boost-gauge
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 5:27 pm
Alright better question, where did you connect the red wire? Cig lighter? I guess where and how are wjat im i am looking.for.lol
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 5:32 pm
I think cig lighter is on all the time - no good. I'd route it to the fuse box and tap into a switched accessory - anything that comes on when you turn the key to "on".
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 5:36 pm
Thats a whole nother planet for.me, wiring, wouldnt.know where to start lol
Looking at the fuses on drivers side. Looking at that radio fuse. Im guessing.id have to wire it to wherever that fuse is connected
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 5:43 pm
It's not really that bad. Open your driver door, carefully pop open the fuse panel cover at the end of the dash. You'll see a map with each fuse's location. Pick RADIO and use one of these to tap in.
LittleFuse Add-A-Circuit:
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 5:48 pm
I always do this lol, i just saw that too, or the bussman one lol, sometimes i scare myself thanks
Ok so i got the littelfuse, ran some wire to the gauge, i got that extra 3 wire thing that im supposed to use the red wire to connect right? So, instructions say when using another power source to remove the red connection from the back of the gauge... what the hell is supposed to go there?!??
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 9:58 pm
Ok all i need to know is where everyone hooked up their 12v switch for their gauge, other wise im gonna say f it. I hate wiring
Merit : 127
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 10:05 pm
Any switched + wire so it goes on with ignition. I wanna say mines on my radio circuit
Merit : 62
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 10:07 pm
Hey Daryl,
I used that Add-a-Circuit thing that Aaron posted, and I used my radio fuse location as he also stated. Works great for me!
And as for the connection you remove from the back of the gauge, I think you mean the jumper? When using an external power source like we all have to, that jumper is just removed and nothing goes in it's place. The new fuse and wiring you added takes the place of it, just in another location.
Hope that helps a little smile
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 10:18 pm
It does alot thanks, so thats all i would have to do? I have a tendency to make easy things harder and harder things way to simple
Merit : 62
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 10:20 pm
Fortunately, this is a very easy thing. Though to be fair, my particular directions I got with my Aeroforce were slightly confusing too. But yes, that's all you have to do! Enjoy the gauge, it's really handy.
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Thu Sep 19, 2013 11:49 pm
I really dig those gauges but I'm still holding out for some really cool analog gauges like these
http://www.speedwaymotors.com/Stewart-Warner-82229-Wings-Five-Gauge-Set-Electric-Black-Face,7798.html
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Fri Sep 20, 2013 2:21 pm
Those are awesome
Name : Going Nowhere Fast
PostSubject: Re: FAQ: Aeroforce Interceptor Scan Gauge   Tue Oct 08, 2013 10:27 pm
Im stuck what do I have to do to get this afsg to come on and off with the car???? Please
Fromano
PostSubject: guages   Tue Oct 29, 2013 1:51 pm
aeroforce guage I just got mine installed it in my 97 riv it comes on and then turns off not real happy frown  with a 250 dollar guage can somebody tell me what iam doing wrong . or call me at 814-935 6197 I just don't have any luck .every thing I do to this car seems to be a problem .any help will work .thank you .Fromano
Page 5 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
