 Looking for someone with scanner
PostSubject: Looking for someone with scanner   Tue Sep 02, 2008 3:44 pm
ok well im going to be installing intense 3.4 pulley when i get it here, and I am installing a 4in FWI right now and the 180 thermostat and A 3in down pipe So What I need is someone in the area to scan my car and set it right for lets say a case of beer I dont know so let me know asap
http://www.Chitownracing.com
PostSubject: Re: Looking for someone with scanner   Thu Sep 25, 2008 12:04 am
You're in IL? How far is ZZP in Michigan? Call them up, make an appt and they'll tune it for you. I'd be there if I was fairly close.
PostSubject: Re: Looking for someone with scanner   Thu Sep 25, 2008 10:25 am
I dont know
PostSubject: Re: Looking for someone with scanner   Thu Sep 25, 2008 2:01 pm
I'm In Minnesota
Merit : 20
PostSubject: Re: Looking for someone with scanner   Thu Sep 25, 2008 4:22 pm
ZZP is in Grand Rapids, about 3 hours from Chicago. They were on South Division, but they've moved and I'm not sure where. How far are you from Canton (Northeastern), MO?
PostSubject: Re: Looking for someone with scanner   Thu Sep 25, 2008 5:20 pm
pretty far I think Im In chicago so Mo is like 6 hours awaydoing the speed limit, I just need some one that dont mind tuneing to run right with the 3.4 on there i know you cant tune it in one try so I know we will have to mess with it but I will suplly lunch and beer for whoever wants to make a weekend of dicking with cars?
PostSubject: Re: Looking for someone with scanner   Thu Sep 25, 2008 5:29 pm
When you do the DP, you'll need to adjust your tune again, so maybe wait until you have everything installed before you do the PCM. Just throwing that out there... I i were planning both DP and 3.4", I'd do the DP first, probably wait on the pulley.
PostSubject: Re: Looking for someone with scanner   Thu Sep 25, 2008 5:42 pm
okay kool
PostSubject: Re: Looking for someone with scanner   Thu Sep 25, 2008 6:32 pm
I am also looking for someone with a scanner in my area since I don't have a laptop it would be pointless for me to buy one. But I am looking into getting a aeroforce scangauge in a couple of months.
PostSubject: Re: Looking for someone with scanner   Thu Sep 25, 2008 7:12 pm
i also am looking into the aeroforce scan gauge
PostSubject: Re: Looking for someone with scanner   Thu Sep 25, 2008 8:38 pm
1wickedninja wrote:
I am also looking for someone with a scanner in my area since I don't have a laptop it would be pointless for me to buy one. .....
A SCANNER does not require you to have a laptop. A tuner does, if that's what you meant.
