| Vehichle speed sensor location? | |
NO 4 EVR Addict
| Subject: Vehichle speed sensor location? Tue Sep 02, 2008 5:06 pm | |
| Hey long time no see everyone!
Got some issues with the Riv and I need a quick answer.
The speedo does not work and the riv won't shift out of what seems like 2nd gear.
It's not the TPS, I just replaced that. Next up is the VSS and I think I have the right part but I have no clue where it is. Any help would be great. | |
| Subject: Re: Vehichle speed sensor location? Tue Sep 02, 2008 5:28 pm | |
| Isn't it built into the hub assy? | |
'96reese Fanatic
| Subject: Re: Vehichle speed sensor location? Tue Sep 02, 2008 7:21 pm | |
| it sits on the right side of the transmission, where the half shaft goes in the transmission. shoot me your email address and i'll send you a picture of the diagram. dont know how to load it up on here | |
| Subject: Re: Vehichle speed sensor location? Tue Sep 02, 2008 11:09 pm | |
| There's the man with the answer... | |
NO 4 EVR Addict
| Subject: Re: Vehichle speed sensor location? Wed Sep 03, 2008 12:29 am | |
| - '96reese wrote:
- it sits on the right side of the transmission, where the half shaft goes in the transmission. shoot me your email address and i'll send you a picture of the diagram. dont know how to load it up on here
PM sent - 1998 Riv wrote:
- Isn't it built into the hub assy?
I believe you are thinking of the Wheel Speed Sensor which is in the hub if I'm not mistaken | |
| Subject: Re: Vehichle speed sensor location? Wed Sep 03, 2008 9:29 am | |
BillBoost37 Junkie
| Subject: Re: Vehichle speed sensor location? Wed Sep 03, 2008 10:00 am | |
| Please scan for codes before shotgunning parts. Many of the trans codes take 2-3 faults to illuminate a MIL | |
NO 4 EVR Addict
| Subject: Re: Vehichle speed sensor location? Wed Sep 03, 2008 5:43 pm | |
| Well I found the VSS based on your instructions Resse, thanks! Replaced it and everything is A OK. Gotta admit it was a little PITA - BillBoost37 wrote:
- Please scan for codes before shotgunning parts. Many of the trans codes take 2-3 faults to illuminate a MIL
Yeah I'm with you 100 procent on that one. However I have a couple of reasons why I chose this method. 1. My roomate of 5 years has a scan tool, however he moved to Florida recently and I didn't have one on hand. 2. I'm trying to replace all cheap sensors and components now that the riv is getting old. | |
| Subject: Re: Vehichle speed sensor location? Wed Sep 03, 2008 9:58 pm | |
| What makes you think the VSS is a 'cheap sensor'? I've never heard of one going bad. | |
'96reese Fanatic
| Subject: Re: Vehichle speed sensor location? Wed Sep 03, 2008 10:02 pm | |
| no prob man. i have acess to alldatapro so any future question jus holla. | |
NO 4 EVR Addict
| Subject: Re: Vehichle speed sensor location? Thu Sep 04, 2008 12:49 am | |
| - deekster_caddy wrote:
- What makes you think the VSS is a 'cheap sensor'? I've never heard of one going bad.
Umm... Because I just bought one and installed it? Not sure where you're going w/ this one... http://www.obd-codes.com/p0500 The absence of evidence is not the evidence of absence | |
| Subject: Re: Vehichle speed sensor location? Thu Sep 04, 2008 12:40 pm | |
The absence of evidence is not the evidence of absence Oh, I thought you meant 'cheap' as in a crappy OEM one that fails, like the cam position sensor... I wondered why you would replace a sensor that has no problem and no history of failure, that's all. Edit: Sorry, hadn't been paying attention to this thread. It sounded like you were just replacing sensors for the fun of it. NM. This threw me off: - NO 4 EVR wrote:
- 2. I'm trying to replace all cheap sensors and components now that the riv is getting old.
| Subject: Re: Vehichle speed sensor location? | |
