Write-Up: 1996-1997 Front Control Arm/Bushing Replacement 5 5 7
Goto page : 1, 2, 3, 4  Next
Location: Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE
Merit: 0
PostSubject: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Sun Sep 07, 2008 12:47 pm
Write up: http://rivperformance.editboard.com/brakes-suspension-f6/write-up-front-control-arm-bushing-t4034.htm#51539
IS there a write up on how to replace the lower front control arm busshing, Mine is going out and I dont want to pay a shop 100 bucks an hour to replace a 15 dollar bushing
http://www.Chitownracing.com
manofmany
Merit: 5
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Fri Sep 12, 2008 8:51 am
I've never done it on a riv before but I would imagine you could pull the control arm, buy the bushing, and take it to a machine shop and have them press the old one out and the new one in for $5 or $10
Merit: 0
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Fri Sep 12, 2008 10:08 am
yeah I know its cheap to have it pressed and the bushing is only 12 bucks I just dont know how to do the control arm
'96reese
Merit: 4
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Fri Sep 12, 2008 11:22 pm
removing the control arm is very easy. jack the riv up set jack stands under the riv.
1. remove the tire on the side you will be working on
2. remove the pin that goes thru the castle nut on the lower ball joint
3. remove the ball joint castle nut
4. grab a big azz hammer and a pickle fork. wedge the pickle fork in between the lower ball joint and the steering knuckle.
5. bang the hell out of the fork till the control arm drops down.
6. remove the front bolt of the control arm
7. remove the rear bolt of the control arm
8. if you have a bushing press or a ball joint press then you can remove the bushings yourself. if not take it to a machine shop.
9. follow reverse to install.
now i did not tell you socket sizes, because on my '96 its a torx bit for my front bolt. if you have an air compressor then that will help out, if not make sure you are using 1/2 inch sockets with a good breaker bar.
good luck
Merit: 0
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Sat Sep 13, 2008 11:10 am
thank you
TType_Riviera
Merit: 0
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Sun Sep 14, 2008 9:14 am
Ive done this on my 96'... problems you may run into... the metal sleeve the bolt goes through inside the rubber bushing,, may or may not be rusted to the bolt.. which means its going to suck!!!!!!! i would suggest dousing everything in penetrant.. I had to use a cutting torch and carefully cut down the side of the sleeve.. I hope all goes well for you!!!
Merit: 30
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Sun Sep 14, 2008 10:08 am
PB Blaster is great for this type of problem. joy
Bert tavis
Merit: 0
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Sun Sep 14, 2008 10:20 am
well when ever it stops fucking raining i will attempt
TType_Riviera
Merit: 0
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Sun Sep 14, 2008 11:02 am
Bert tavis
doesnt always work my friend... read
Merit: 30
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Sun Sep 14, 2008 11:44 am
doesnt always work my friend... read[/quote]
Its a very good penetrating oil, but will not work miracles or do the work of a cutting torch. poke
Bert tavis
'96reese
Merit: 4
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Sun Sep 14, 2008 9:05 pm
no problem. i do agree though, before you attemp this(especially if you don't have acess to air) spray the nuts and bolts of everything that you have to remove and spray them with pb blaster. if you are going to do this on a weekend then spraying the parts everyday throughout the week will help you grately.
Merit: 0
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Mon Sep 15, 2008 10:16 am
kool thanks for the tips
Sweepspear
Merit: 11
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Sun Apr 12, 2009 6:13 pm
What size Torx bit is required for that front bolt?
I have an assortment, but want to know ahead of time if I will have to buy one.
T-50? T-55?
arttu80
Apprentice
Merit: 4
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Wed Apr 15, 2009 9:51 am
T55 in my 1997
Sweepspear
Merit: 11
PostSubject: Re: Write-Up: 1996-1997 Front Control Arm/Bushing Replacement   Wed Apr 15, 2009 2:20 pm
arttu80 wrote:
T55 in my 1997
Thank you! I do believe I have a T55.
cheers
Page 1 of 4Goto page : 1, 2, 3, 4  Next
» I need some front fork bushes..
» CONTACT FRONT Airsoft
» Independant Front Suspension
» EVO UPGRADED BRAKE KIT FRONT - USE WITH 17x8J ET25 TOMBINOS
» Write-Up: 1996-1997 Front Control Arm/Bushing Replacement
