 "NEW" Riv owner,new to the site...PROBS..Help
Whatleece
Whatleece
"NEW" Riv owner,new to the site...PROBS..Help Empty
PostSubject: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyThu Sep 18, 2008 12:58 pm
Hi..I welcome all your expertise....bein a girl and Jimmie Johnson fan...My 'New' 95 Supercharged Code 1 is givin me probs.
Upon driving (not at low speeds or initial acceleration) when I am at ~45 to 60 mph and kinda coasting & then I need to accelerate to maintain my speed, my engine majorly 'Bucks'. If I 'Gas' it, I can alleviate the Buck about 70%. Engine light is intermitent.
I have vacuumed out & replaced the air filter....
Figure its got somethin to do with the Fuel filter, pump, injectors....Does anyone have any advice? "For a Novice"!!!!!!!
Where can I get a general manual??Havin trouble finding one.
Also, any tricks to reaching those back 3 plugs? Front 3 look like firing fine
PostSubject: Re: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyThu Sep 18, 2008 1:03 pm
Im A big guy and them back plugs were a bitch for me I went from the top passenger side good luck
http://www.Chitownracing.com
Merit : 152
PostSubject: Re: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyThu Sep 18, 2008 1:11 pm
On the Series I supposedly the plugs are not too tough to reach from underneath. Put car on ramps, reach past exhaust manifold. Engine cold (hot manifold does not tickle). You will need a short (like 1-1/2") wobble extension for your spark plug socket. There's a spark plug thread somewhere on this board where we discussed this at length and posted instructions for the Series I and Series II engines. Please use search function to find it.
PostSubject: Re: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyThu Sep 18, 2008 1:35 pm
I bet you need a big cereal!
"NEW" Riv owner,new to the site...PROBS..Help 666647925_2d9ccff560
Merit : 122
PostSubject: Re: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyThu Sep 18, 2008 1:56 pm
+1 on rear plugs from under. Also the "bucking" sounds like wires to me. Had the same prob....
PostSubject: Re: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyThu Sep 18, 2008 2:22 pm
albertj wrote:
On the Series I supposedly the plugs are not too tough to reach form underneath. Put car on ramps, reach past exhaust manifold. Engine cold (hot manifold does not tickle). You will need a short (like 1-1/2") wobble extension for your spark plug socket.
I use a long extension and a swivel, that way I only have to reach in to remove and replace the wire. thumbsup
PostSubject: Re: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyThu Sep 18, 2008 2:23 pm
Oh yea, and…
Welcome to the Forum thumbsup
'96reese
PostSubject: Re: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyThu Sep 18, 2008 6:09 pm
whatleece...you will never find a manuel on the rivs, only if you come across a gm shop manuel. i've looked online and all the parts stores. now what you could do is get a genral gm 3.8 series one engine manuel at the parts stores. but hey you found this site so ask us and will be able to help you. i know personally i have a mitchell on demand disk for our coars and i have access to all data thur my job.
ask for as the bucking goes before you guess at what you need to change i would get the car scanned. now some 95's have obd2, but the majority are obd1. try going to your local parts store and see they can scan your car and write down the code and post it on here. that will help us out alot to diagnois your problem. because bucking could be that you need a tune up, or it could have sumthing to do with your air fuel metering system(o2 sensor, maf, map..). guessing though plugs and wires would be a good start but have your car scanned.
PostSubject: Re: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyThu Sep 18, 2008 6:37 pm
wellcome and good luck with your new riv!
PostSubject: Re: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyThu Sep 18, 2008 7:03 pm
Wires or possible fuel filter
PostSubject: Re: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyFri Sep 19, 2008 4:27 pm
Plugs and Wires!!
Welcome to the site and good luck!
-Derek
PostSubject: Re: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyFri Sep 19, 2008 5:27 pm
Welcome to the Forum, Whatleese cheers
mdhall1
mdhall1
PostSubject: Re: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyMon Sep 29, 2008 12:28 am
I battled the same problem for a few months just figured it out with help from these guys. My problem ended up being a bad coil (brand new auto zone POS) the way I found out isn't pretty but it worked. With the car running I pulled each plug wire off the coil packs. You will get a small shock if it is a good coil and it should run like crap when unpluged. My middle coil pack one side was working one side wasn't.
To get to the back plugs I take the alternator off and the vaccum box (Black rectangle shape not sure what it's called) at the firewall off. This gives me plenty of room to lay across the motor and reach
behind.
Good luck,
djlorenzana
djlorenzana
PostSubject: Re: "NEW" Riv owner,new to the site...PROBS..Help   "NEW" Riv owner,new to the site...PROBS..Help EmptyWed Oct 01, 2008 6:11 pm
I would agree with what has been posted I have seen "bucking" with all of the above the hardest one for me to diagnose was the MAF sensor... plugs and wires could do it, fuel pump and or clogged filter does this, plugged up injectors as well... so getting your car scanned is a great first step and the easy stuff (not so easy on the riv) plugs and wires is always good...
» I believe Al "Ratface" Strachan has been fired by the CBC (again)
» 1st Day results from "Griffins" Cassic Jan.29
» Finally some "love" our way -- 67's jersey ranked #1!
» UPDATE: Return of the Quebec Nordiques? "Possible", say RDS, Corus Sports, other sources
» A Turtle "Doing" A Small Lioness
