| Going a different direction, for now | |
+4Jack the R SuperRiv07 T Riley 1998 Riv 8 posters |
| Subject: Going a different direction, for now Fri Sep 26, 2008 3:14 pm | |
| Most of you know I've been running #1 of Rob's 3 custom built stainless 3.5" FW intakes this year. Pretty darn cool, changing from the stock airbox. However, yesterday I made the decision to switch to an underhood 4" short tube with the new 4" K&N filter I have, that no one seems to want to buy.
First off, I'd rather not keep yanking the splash shield for future servicing of the filters. The fasteners are crappy enough already. And the filters don't seem to stay very clean in my FW. I bought a rubber 3.5" id x 4" id TB adapter at Menards, and they had thin-wall sewer pipe fittings that Home Depot does not have. So I got a thin wall 4" 90deg street elbow at Menards for my tube. The female end is about 4 1/4" od going to the TB adapter, and the male end is a 4"od(3 3/4 id) going into my new K&N. It's a very good fit in the space available, and I don't know if a 45deg would allow for the K&N cone to fit. Maybe with a straight style K&N, but not my cone. I doubt my single 4" 90deg on a very short intake tube is much of a restriction, certainly not as much as the smaller and much longer SS intake it replaced.
I had picked up a new oem IAT sensor a while back, and put it to use. I used a 1/2" drill bit to put a mounting hole in the underside of the tube, and manuevered it around to enlarge it enough to fit the BODY of the sensor in the hole. But the sensor has 2 retaining prongs on opposite sides. They will work with this thin-wall fitting. Just used a small drill bit against the sides of the larger hole to create slots to slip those prongs thru. You push it in hard enough then turn the sensor 90 degrees and the prongs hold it WELL. I'm not even going to glue it in. The stock sensor cable reaches just fine.
I didn't take any pics yet, but will if anyone wants to see it. I left the elbow white so far, maybe I'll paint it next spring. Or just wrap it in heat reflective tape, like I did with the SS intake tube. Speaking of which, I need to decide if I should sell it, or maybe run it in the summer for slightly cooler intake temps. | |
T Riley Guru
| Subject: Re: Going a different direction, for now Fri Sep 26, 2008 3:18 pm | |
| Subject: Re: Going a different direction, for now Fri Sep 26, 2008 3:43 pm | |
| Subject: Re: Going a different direction, for now Fri Sep 26, 2008 3:44 pm | |
SuperRiv07 Addict
Name : Nick Age : 39 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
| Subject: Re: Going a different direction, for now Fri Sep 26, 2008 5:26 pm | |
T Riley Guru
| Subject: Re: Going a different direction, for now Fri Sep 26, 2008 5:47 pm | |
| nice i had one similar to that but changed it to a chrome stainless 4 inch one | |
| Subject: Re: Going a different direction, for now Fri Sep 26, 2008 7:55 pm | |
| Kinda works with the body color of the car.
Seems like you'd be pulling in tons of hot air. | |
SuperRiv07 Addict
| Subject: Re: Going a different direction, for now Fri Sep 26, 2008 8:04 pm | |
| Subject: Re: Going a different direction, for now Sat Sep 27, 2008 5:18 pm | |
| DUDES, there's NO hot air in ND from Oct to April... 60's today. Next spring I'll probably just run the gutted airbox with drop-in K&N. I had been tempted to find a shop to cut off the smaller opening at the end of the SS tube, and weld on a 3.5 to 4 adapter in order to use my 4" K&N instead. Not gonna happen though, since I've decided not to screw around with the fenderwell anymore.
I'm thinking about backing off a bit on my mods, but haven't made any firm decisions yet. This stuff is taking too much of my little free time away from my Real Toy, the 68 GS. | |
ibmoses Aficionado
| Subject: Re: Going a different direction, for now Sat Sep 27, 2008 5:33 pm | |
| - 1998 Riv wrote:
- DUDES, there's NO hot air in ND from Oct to April... 60's today. Next spring I'll probably just run the gutted airbox with drop-in K&N. I had been tempted to find a shop to cut off the smaller opening at the end of the SS tube, and weld on a 3.5 to 4 adapter in order to use my 4" K&N instead. Not gonna happen though, since I've decided not to screw around with the fenderwell anymore.
I'm thinking about backing off a bit on my mods, but haven't made any firm decisions yet. This stuff is taking too much of my little free time away from my Real Toy, the 68 GS. Good point about the cold air in SD. Thats why I got rid of my 87GN, I did not have time for it and the GS455 and the rest of the fleet and the yard and the yaddayaddayada... I figure eventually I will end up with the Riv and then I might mod it up... Bert Bert | |
98riv Moderator
| Subject: Re: Going a different direction, for now Sat Sep 27, 2008 5:37 pm | |
| That looks similar to mine. If you cut part of the end off the pipe by the throttle body and maybe extend the pipe a little bit, you should be able to get the filter tucked back into the stock location. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| Might be a cool experiment to record IAT values at say 50F, then build an enclosure around that filter, like a custom cold air box in the spring. That would isolate the intake from heat, and would keep it clean. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Going a different direction, for now Sat Sep 27, 2008 5:52 pm | |
| I'm actually quite happy with it as-is, a simple one piece elbow. Not really enough material there to shorten the TB end. I really wanted to try a 45deg elbow, but couldn't find one in the thin-wall fittings.
My IAT's yesterday seemed to run about 10deg higher than the FWI. | |
Chicken Aficionado
| Subject: Re: Going a different direction, for now Sun Sep 28, 2008 1:03 pm | |
| Could someone ask Dave if that really is an Intense STB? | |
| Subject: Re: Going a different direction, for now Sun Sep 28, 2008 1:15 pm | |
| Yes, it's pretty damn INTENSE! lol And my quarter glasses and tail lights are made by ZZP... | |
| Subject: Re: Going a different direction, for now | |
