| MORE NOISES! | |
+2deekster_caddy lyonsperformance 6 posters |
lyonsperformance Enthusiast
Name : Michael Age : 40 Location : Buffalo N.Y. Joined : 2008-08-02 Post Count : 178 Merit : 0
| Subject: MORE NOISES! Tue Sep 30, 2008 4:54 pm | |
| I was driving at night about a week ago with thye windows down and the stereo off and noticed a weird rubbing noise that seemed to originate from the driverside wheel well. i got home and jacked it up, removed the front wheel, put it in neutral, and started to spin the axle by turning the rotor. im unsure if its the wheel berring, or the inner CV, or worst case scenario the TRANS. any ideas on what it could be. | |
| Subject: Re: MORE NOISES! Tue Sep 30, 2008 4:59 pm | |
| Most likely the wheel bearing, but usually the wheel speed sensor gets wiped out before the bearing fails. CV joint would only make noise on accel/decel/turn.
Hard to say without witnessing the noise... Video? | |
| Subject: Re: MORE NOISES! Tue Sep 30, 2008 5:01 pm | |
| ill see what i can do for a video by tommorow, and it does only happen when i accel/decel its through turns both ways. | |
| Subject: Re: MORE NOISES! Tue Sep 30, 2008 8:51 pm | |
| scraping noise through turns sounds like CV joint.
BillBoost37 Junkie
| Subject: Re: MORE NOISES! Wed Oct 01, 2008 7:19 am | |
| It could be many things.
Inspect the pads and wear indicator for possible issues/rubbing. Look for possible caliper sticking.
CV joint will typically manifest itself on turns and sound like a clicking as the joint moves in the pivot.
Wheel bearings normally will hum and increase vibration/hum with speed.
Trans....is tough to say. | |
TonySmooth89 Aficionado
| Subject: Re: MORE NOISES! Wed Oct 01, 2008 11:37 am | |
| Maybe a stupid question , but did you check to make sure your filter isn't pushing out and causing the liner on the fenderwell to push in causing it to rub against the tire? I know i had that problem for a while and thats what it was. | |
| Subject: Re: MORE NOISES! Wed Oct 01, 2008 11:56 am | |
| Yeah the filters clear, im going to post the video today and mabey it will help | |
Chicken Aficionado
| Subject: Re: MORE NOISES! Wed Oct 01, 2008 2:17 pm | |
| LOUD NOISES!!!! | |
| Subject: Re: MORE NOISES! | |
| MORE NOISES! | |
