| fuel line leak - great | |
+8Shintsu jimmytullip 1996RIV CALI BillBoost37 TonySmooth89 AA 98riv 96rivgirlla 12 posters |
96rivgirlla Amateur
Name : magen Age : 37 Location : los angeles Joined : 2008-08-14 Post Count : 23 Merit : 0
| Subject: fuel line leak - great Tue Sep 30, 2008 10:39 pm | |
| so i tried to start the 96 sc riv today (w/ oil in it) to see if we could diagnose exact problem by the noise. as soon as i tried to start it, a small spray of fuel starting coming out of the fuel line right where it connects to the metal piece (are those the fuel injectors?) at the engine. I think im gonna get a rubber goodyear hose and clamps for now, but wanted to ask what you guys thought about rubber hoses and if there is a certain lenth and diameter i need... also, are there any write ups on how to replace those? do you need any special tools for the job? I just don't want to blow up | |
98riv Moderator
| Subject: Re: fuel line leak - great Tue Sep 30, 2008 11:25 pm | |
| Can you post a picture on exactly where the fuel is coming out? It may be as simple as changing the O-rings or you might need a new fuel line or fuel rail. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| Subject: Re: fuel line leak - great Tue Sep 30, 2008 11:42 pm | |
| don't try to fix this yourself. Take the car in to a mechanic. DO NOT DRIVE THE CAR! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
TonySmooth89 Aficionado
| Subject: Re: fuel line leak - great Wed Oct 01, 2008 12:36 am | |
- don't try to fix this yourself. Take the car in to a mechanic. DO NOT DRIVE THE CAR!
Don't take chances with things like that , unless you have plenty of experience. If you plan on doing extreme modding it might not be a bad time to upgrade to fuel rails with stainless lines , or even stainless lines if you like the look. Otherwise just take it to a mechanic and get the o-ring replaced. Personally i got whole new OEM lines when i got mine done as after 12 years and 80k miles i figured it would be decent insurance. | |
BillBoost37 Junkie
| Subject: Re: fuel line leak - great Wed Oct 01, 2008 7:16 am | |
96rivgirlla Amateur
| Subject: Re: fuel line leak - great Wed Oct 01, 2008 10:15 am | |
| car doesnt work anyway, so i will not be driving. and don't have a digital cam to post a pic of where it is..... in billboost's write up on braided fuel lines it is the second pic of the black curved fuel line - right before the metal pc. connects to the plastic line is where it is leaking from. I'm not sure i want the mechanic to do it because i would have to have it towed and all that... i think the write up will help, ill just be using either rubber or oem lines instead of the stainless steel. they do look nice, but im not ready for that mod yet | |
BillBoost37 Junkie
| Subject: Re: fuel line leak - great Thu Oct 02, 2008 10:32 am | |
| On a Regal I picked up it was leaking. Got 4 fuel injection clamps and about 3 feet of fuel injection line. Worked fine. Make sure you leave some slack somewhere for engine flex/movement and you should be all set. | |
96rivgirlla Amateur
| Subject: Re: fuel line leak - great Thu Oct 02, 2008 2:05 pm | |
| Thanks! is there a website where i can get all that from, or would they have it at autozone or pepboys? | |
1996RIV CALI Amateur
Age : 43 Location : Oakland CA Joined : 2008-07-22 Post Count : 42 Merit : 0
| Subject: Re: fuel line leak - great Thu Oct 02, 2008 2:27 pm | |
| My 96 riv was leaking just under the engine cover , i think it was right were the fuel lines went into the motor. went to the shop and mechanic said there is kit you can buy to fix it, got my at PEP BOYS for like twenty or thrity buck, it work just fine. I have it checked every time i get my oil changed. | |
jimmytullip Amateur
Name : James Age : 46 Location : Warren, MI Joined : 2007-06-07 Post Count : 30 Merit : 0
| Subject: Re: fuel line leak - great Tue Dec 02, 2008 5:16 pm | |
| I know what this problem is, its the pipe ASM-fuel line. Its a dealer part so head on over. One side snaps on but the other side is a mystery to me. If anybody knows how to remove the other side please post because I have the same problem.[/img] | |
Shintsu Expert
| Subject: Re: fuel line leak - great Tue Dec 02, 2008 5:37 pm | |
| Hmm, if this is the same fuel line I had to replace the part was about $95. We popped the old one off and put the car up on stands and fed it down inbetween the motor. It's metal all the length of the car and plastic at the end under the hood. The plastic had a tiny hole in it and started spraying gas under the hood - easy to tell because there was a very strong gasoline smell. We had to be careful not to bend it but after some shimmying around we got it under there and it's been on the car for I don't know, probably a year and a half to two years now - maybe longer. If this is what you're having a problem with, as long as you've got someone to help you it shouldn't be a problem. Not worth the high labor costs ($250 if I recall correctly). | |
| Subject: Re: fuel line leak - great Tue Dec 02, 2008 6:32 pm | |
| Yep - the replacement line form the dealer is the way to go - unless you have some time on your hands; you could replace the lines with stainless steel braided. Search theis editboard, there is a post that lists the parts you need to pull this off.
jimmytullip Amateur
| Subject: Re: fuel line leak - great Tue Dec 02, 2008 7:14 pm | |
| Alright I just fixed the problem and I needed a fuel line disconnect tool, got it at auto zone for only $3.49. The Pipe ASM part # is 25604896 list price is $70.00 but I got it on sale for $53.00 from the dealer. This job took me 2 hours but if anyone reads this before hand it should take you no more than 15 minutes. Hope this helped everyone. Enjoy
Jimmytullip | |
| Subject: Re: fuel line leak - great Tue Dec 02, 2008 7:56 pm | |
| Thanks for the info James. | |
rodrivi Rookie
Name : Rodg Age : 33 Location : Maryland Joined : 2013-11-13 Post Count : 18 Merit : 0
| Subject: Re: fuel line leak - great Fri Nov 15, 2013 8:04 am | |
| Ok I have the same problem. I have the connector attach to the line above the supercharger but how do I get the nylon hose to go over the steel fuel line thats by the firewall? anybody | |
IFallsRon Fanatic
Name : R.L. Joined : 2012-11-23 Post Count : 268 Merit : 2
| Subject: Re: fuel line leak - great Sun Nov 17, 2013 12:12 pm | |
| Mine had a small break at the firewall in the dead of winter. I got two feet of injector rated rubber hose at the part store as a temp fix. I think I cut it off at 18 inches and clamped both ends. The Dorman replacements run $15-20 on Amazon and at most parts stores. | |
rodrivi Rookie
| Subject: Re: fuel line leak - great Sun Nov 17, 2013 8:25 pm | |
| Thanks. I used the injector line too and connected it to the dorman replacement. Fixed it yesterday. Thinking I might change it to ss lines at the beginning of spring. | |
| Subject: Re: fuel line leak - great | |
