 New Member 1996 Riv with nitrous
mrod7510
New Member 1996 Riv with nitrous Empty
PostSubject: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptySat Oct 11, 2008 10:59 pm
Hello, I know wires hanging out, I took these photos of my car before my Unit was complete but the car was clean so. The Nitrous is hooked up and all sexy now runs awsome. My mods include the simple cheezy ones like 180 t-stat, 104 Autolites, FWI 4 inch with 6 inch K&N, then 3.4 pulley which i should of went 3.25 because the car is pig rich at 10.40 air fuel, spraying 75 HP with a 117000 miles on the car? one week and two bottles later all is well with my air fuels on the nitrous still rich at 10.90s or so. Next problem TRACTION to which i have none. soon a 97 PCM swap so i can use HP tuners to do all the cool stuff plus go over 106MPH hahah Should have done the last two first A? Please coment and give suggestions Thanks
New Member 1996 Riv with nitrous S5007542
New Member 1996 Riv with nitrous S5007540
New Member 1996 Riv with nitrous S5007535
New Member 1996 Riv with nitrous S5007536
New Member 1996 Riv with nitrous S5007529
New Member 1996 Riv with nitrous TheRiv012
New Member 1996 Riv with nitrous TheRiv003
New Member 1996 Riv with nitrous S5007532
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptySat Oct 11, 2008 11:36 pm
Looks great! Nice and clean.
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptySun Oct 12, 2008 2:32 am
GREAT
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptySun Oct 12, 2008 2:52 am
wow
very beautyful and clean.
Black color makes car look more expencive wink
Just...truy not to blow your engine happy
Supercharged
Supercharged
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptySun Oct 12, 2008 10:17 am
would you have a video of the NITROUS being used
Supercharged
Supercharged
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptySun Oct 12, 2008 10:19 am
also the ride looks great
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptySun Oct 12, 2008 11:02 am
Welcome! Nice setup! Are you injecting Nitrous and Fuel before the supercharger? I've heard of that causing issues with the seals on the spuercharger vanes.
Rich: How's your WOT fuel pressure? I'd look to that for your rich problems. Where are you taking fuel from for the N20 setup? Is it taken from the fuel rail? Can you change fuel/nitrous jets independently, or your N20 fuel pressure? We were having a similar problem on a different motor, had the engine dialed in exactly for A/F without nitrous, but was pig rich while Nitrous was on. Eventually figured out that we had too small of a nitrous jet installed, rookie mistake frown
What kind of Nitrous kit is that?
-Derek
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptySun Oct 12, 2008 2:24 pm
Looks great! I am glad someone else put nitrous on a Riv. I am dying to put a kit in my Riv.
How did you run the line from the tank to the ehgine bay?
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptySun Oct 12, 2008 3:21 pm
he is injecting into the throttle body woot
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptySun Oct 12, 2008 6:20 pm
Thats Nice As Hell Man Really like it
http://www.Chitownracing.com
mrod7510
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptySun Oct 12, 2008 10:35 pm
well to answer a few questions, yes I will be posting a video of the car on nitrous. like I said before its just a big time tire spinner now frown but pulls hard in second. I put the purge on it to scare off the weak, haha. I hijacked my steering wheel controls to purge and spray the car so not to use big nasty looking switches. as for the unit and what brand its a coldfusion LS engine wet kit. leperformance.com. my fuel pressure stays right around 45lbs. the kit receives fuel from the fuel rail with the shrader valve removed. this kit is adjustable from 50 to 200 HP to which I have a 75 shot. 41 nos jet 23 fuel jet. the only thing I have to be careful of is letting off the spray during shifts because with stock shift points it wants to hit the limiter which I did once already not a good noise. my advice buy tires before nitrous. the car is probably slower now with all the tire spin. haha. im gonna try slicks before the track closes for the winter. think the transmission will hold? thanks for your comments
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptySun Oct 12, 2008 11:56 pm
The transmissions are known weak points in these cars. Only use the nitrous while positively in gear and away from the shifts... and it might last a little while.?
Good luck! I have enough trouble with traction, can't imagine what it's like when you push that button!! How's the torque steer? wink
Timbo2Rivs
Timbo2Rivs
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptyMon Oct 13, 2008 12:08 am
Very nice ride, Now I know what the underside of the hood looks like without the insulation, kinda cool. Do you know what tires you are going to go with?
mrod7510
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptyMon Oct 13, 2008 1:29 am
torque steer? wish I had more ha that would mean im getting traction!! have not made my mind up on brand or specs on tires yet. I work at a automotive machine shop so im dying to do up a set of heads but why stop there? my point, I better just enjoy what I have now for a while, as you guys know its almost an endless process.
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptyMon Oct 13, 2008 2:23 am
Question: how much knock are you seeing with N2O on? and off? You need to know this before you drop to a 3.25" SC pulley. How are you measuring A/F ratio? Better to command less fuel when rich then to raise boost, imo.
Is this your actual fuel rail pressure? Should be around 70 PSI stock at WOT. If not, I don't know how you're running rich.
Nice car. Any track times yet?
ericde
ericde
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptyMon Oct 13, 2008 2:27 am
let us know what she runs at the track
mrod7510
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptyMon Oct 13, 2008 11:05 am
well because I use hp tuners at my shop I cannot scan my car to measure knock. as far as air fuels I throw it on the dyno and use a wide band o2 where my cat used to be. my car it pretty quite so you could here if in trouble . cannot make full pull because of the speed governor.will post numbers soon. thanks for the comment on my fuel pressure only checked it at idle and 2500 or so. smart right, ill drive it tomorrow with the gauge hooked up and see where im at WOT. to much stuff I want to do. for now my priorities are tune, and tires ,!
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptyMon Oct 13, 2008 11:18 am
I agree, tuning for about 11-11.5 A/F is where you want to be for optimum power, just be careful dropping the pulley, even if A/F looks ideal. You can still get some knock without being lean, depending on timing advance. In my case, I saw zero KR on the dyno with 11.5 A/F, but on the street I saw quite a bit of knock with the extra load to the wheels. Imo, you want to advance timing as far as possible, while keeping A/F at optimum power, and KR at zero... in a perfect world.
If you could somehow automate the N2O to activate automatically with throttle, you could use it as a knock suppressant, and tune for more power. But with manual use, I would be afraid to be at WOT without the N2O on. Could be knock city.
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptyMon Oct 13, 2008 12:00 pm
I was pretty sure HP Tuners can record/measure knock, and remove the speed governor. Can it not do those things?
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptyMon Oct 13, 2008 4:36 pm
nice riv man I love how riv looks in black with the chrome rims!
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptyMon Oct 13, 2008 4:49 pm
That Black Riv is one badass sinister looking ride.. When you get your traction issue solved, I pity anyone thinking it's just a big old folks boat... Bah-bye........................ 3gears wow
Merit : 135
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptyMon Oct 13, 2008 7:16 pm
RAW
mrod7510
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptyMon Oct 13, 2008 9:31 pm
thank you all, HP tuners does not support 96 rivs when I plug it in it just says cannot communicate with vehicle. so that's where my 97 PCM comes into play. my hope is all will work well.
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptyMon Oct 13, 2008 10:29 pm
Ah, didn't realize it was a '96. Sorry.
It would be helpful if you put some basic information (year, mods) in your sig for us.
rivman96
rivman96
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous EmptyTue Oct 14, 2008 11:32 am
Badass riv man. I have the same wood grain interrior in mine.
» Can you put Nitrous on a tractor?
» looking for SSG member
» for sale 1996 timberwolf 4x4
» Welcome our newest member Brian-n-VA
» Repair Difficulty - 1996 Polaris 300
