 New Member 1996 Riv with nitrous
ericde
Timbo2Rivs
Supercharged
mrod7510
18 posters
Go to page : Previous  1, 2
New Member 1996 Riv with nitrous - Page 2 Empty
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous - Page 2 EmptyTue Oct 14, 2008 12:18 pm
If i were you , i wouldn't spray until second gear, First , until you get tires you won't hook up much anyway , second you should already have plenty of power down low with that 3.4 , and lastly , its harder on the trans put a lot of power down in lower gears than it is in higher ones.
Also you probably wanna get rid of those stock manifolds too.
Cool setup though.
mrod7510
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous - Page 2 EmptyWed Oct 15, 2008 12:00 am
good advice mr Tony , your right it already spins in first anyway. I do use it in second. will post a video this weekend.
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous - Page 2 EmptySat Nov 27, 2010 5:04 pm
Can you flick on and off the arm switch without problems while you drive and do pulls? In other words, is there any time lag in the system arming that would cause a problem while flicking it on a little after the shift to 2nd gear? I know you have a different base kit than I would but I'm trying to get an idea of how it behaves for my to-be setup.
PostSubject: Re: New Member 1996 Riv with nitrous   New Member 1996 Riv with nitrous - Page 2 EmptySun Nov 28, 2010 6:31 pm
Check your left front center cap. In the second pic it appears as if the tabs are not aligned correctly. If you push it more as is, you will break a tab on the cap. The chrome with gold R for 12 spokes are virtually unobtainable.
» I'm exhausted...time for some pics
» nitrous plus a series 1?
» NOSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
» 1996
» my new 1996 Riv
