riviera2454 Enthusiast
| Subject: Tire Size Question Tue Oct 14, 2008 6:43 pm | |
| Not riv related but I am wondering if I have 285s/75/r15s on my truck was size is it when changed in to like 30x9.5? | |
T Riley Guru
| Subject: Re: Tire Size Question Tue Oct 14, 2008 7:08 pm | |
| - riviera2454 wrote:
- Not riv related but I am wondering if I have 285s/75/r15s on my truck was size is it when changed in to like 30x9.5?
idk we had like 315/75?/16's on our 3/4 ton suburban and those were like 31 inches tall or so when i measured them | |
| Subject: Re: Tire Size Question Tue Oct 14, 2008 7:59 pm | |
| 285's are around 11". not saying the rim is that big, it depend on how much it is bulging over. 285/75/15 works out to be 31.83 in diameter, and about a 8.5-9" rim width. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
vendetta Enthusiast
Name : Nick Age : 114 Location : Shakopee, MN Joined : 2008-09-26 Post Count : 219 Merit : 0
| Subject: Re: Tire Size Question Tue Oct 14, 2008 8:15 pm | |
| I have 275/35/18's on my firebird.... | |
ewolfe0050 Aficionado
| Subject: Re: Tire Size Question Tue Oct 14, 2008 8:20 pm | |
| - Quote :
My buddy is running 275/65/17 on his trunk and the tires are 31" in di. I think the 275/65 referres to sidewall to footprint ratio so a 275/35 would be different height than the 275/65. I would check some of the tire websites to find out exactly how to measure. BTY... I just put 33x12.5x15s on my Bronco today. HUGE improvement! Looks and stability... | |
| Subject: Re: Tire Size Question Tue Oct 14, 2008 8:43 pm | |
| first # - width of tire tread in mm second # - percentage of the first # that determines the sidewall height last #- the rim total diameter
if you want 30in total diameter then convert back to mm. (762mm) then subtract the wheel size (15in=381mm). take 1/2 of that you get 190.5mm. that is the sidewall size you need. now depending on how wide you want the tire to be you could have a 275/70R15 or 285/65R15 or 295/65R15. (295*65%=191mm)
all of those will change the total diam. to ~30in. which would mess up your speedo if the factory tire/rim combo has a different diameter.
hope that helps, i see i didnt really answer your question earlier b/c i didnt fully understand what you were asking for. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Tire Size Question | |
