 ecm/code 26 qdm? no spark!
grrizzlybear1
ecm/code 26 qdm? no spark! Empty
PostSubject: ecm/code 26 qdm? no spark!   ecm/code 26 qdm? no spark! EmptyWed Oct 15, 2008 7:59 pm
hi i have a 1990 riv. 3.8 and have a no start problem i read the forum and replaced the crank sensor btw 190000+ miles and the coil it looked burned by the yellow wire connection still no spark i did not have a alignment tool as recomended by the repair book no one has one so i gaped it at 0.30 like the instruction's said too, anyway i had the module tested it was bad,replaced it and the car started
i drove it around for 2 hrs and then let it run for another 3 i pulled the following code's 28,27,26,24, 42. i then shut it off and let it set for 1 hour then tried to restart and nothing no spark again i checked all fuses and grounds i cleaned all connections (grounds and power block) prior to replacing the module
does anyone know were the ecm is located? i pulled a box out from behind the glove box( there is another box just under it above the kick panel but i cannot get it out,)
# on it from delphi delco svc#01228786 went to delphi's web site no match is this the bcm? the "chip" that i need to keep and put in the new ecm (i can get one from a junkyard but i really want it from checker auto parts for $89.99 )is not the same there are two of them and won't come out
btw the sticker on the box says remanufactured so it has been changed before?
would a bad ecm cause the no start problem? any suggestion's would be helpful! thx,
PostSubject: Re: ecm/code 26 qdm? no spark!   ecm/code 26 qdm? no spark! EmptyWed Oct 15, 2008 8:05 pm
I had similar issues on our old '86. We had replaced the module and it ended up needing to be replaced again. Is this the module that has a flat metal heatsink that required the thermal grease? That could be part of the problem... ??
grrizzlybear1
PostSubject: thermal grease   ecm/code 26 qdm? no spark! EmptyWed Oct 15, 2008 8:19 pm
thx for reply no it did not require the grease it is the flat metal box that mounts just beside/under the alt.
» How do I check if I'm getting spark?
» Glossary of RAF mission code names
» Pre-Season Ticket Code
» CombatSportSupply.com Coupon Code
» NGK Spark Plug Finder...
