 i'm new
curious riv
curious riv
i'm new Empty
PostSubject: i'm new   i'm new EmptyMon Oct 20, 2008 11:36 am
Just wanted t introduce myself. Bought a 98 Riv couple month's ago. Want t say THANKS to every one for sharing your knowlege. It is pricless!!!
My Rivs in good shape to have 223k miles on it. Runs strong w no problems. SES light is on but the only code i get is the generic code for the evap/fuelcap.
I haven't had t ask any ?'s. But if i do i know you guys are here!!!
Thanks again. y'all r priceless
curious riv
curious riv
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyMon Oct 20, 2008 11:37 am
oh yeah..... i'll post pics soon as i can
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyMon Oct 20, 2008 11:43 am
Welcome Aboard! Don't be afraid to ask questions if you need to.
Supercharged
Supercharged
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyMon Oct 20, 2008 12:50 pm
welcome along, what color is your riv?
also dont forget to put your cars details in your signature
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyMon Oct 20, 2008 1:10 pm
Welcome!
curious riv
curious riv
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyMon Oct 20, 2008 1:27 pm
It's just a stock buick dk green, i guess. body's in great condition- considering the miles and age. It has been taken care of, will continue to be smile
curious riv
curious riv
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyMon Oct 20, 2008 1:28 pm
still workin on sig... will figure out in a minute
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyMon Oct 20, 2008 5:09 pm
Welcome And Anything you need dont be afraid to ask
http://www.Chitownracing.com
Merit : 148
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyMon Oct 20, 2008 5:19 pm
You might try replacing that fuel cap. Auto parts store will have them but maybe not with the tether. I've replaced mine several times - every so many years, usually for a broken tether.
If fuel cap does not fix the code, look for a busted hose on the EVAP system. Start at the fuel filler pipe and work your way around.
curious riv
curious riv
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyTue Oct 21, 2008 10:24 am
Thanks, Albertj...
that was the first thing I did....
i unplugged the batt for a couple minutes and it didn't work.(reset the code)
I've read that a hole .02" in any evap line could throw that code...
But I'm still gunna look like you said.... worse comes to worse- i'll take it to the dealer or just replace the lines(all of 'em) whichever is cheaper...
curious riv
curious riv
i'm new Empty
still can't figure out the sig...
i'm over looking something
curious riv
curious riv
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyTue Oct 21, 2008 10:27 am
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyTue Oct 21, 2008 3:14 pm
Welcome and good luck with your new riv!
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyTue Oct 21, 2008 3:41 pm
Welcome to the forum Chris...
My second Riv (96 dark green ) had a leaking evap causing a SES light, and my current 98 pearl white Riv had a recent SES light due to gas cap.These two problems seem to cause that a lot. Pretty easy fix and at least not life threatening.
Post some pics when you can. cheers
Supercharged
Supercharged
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyTue Oct 21, 2008 4:10 pm
go to profile, and go to up at the right top corner there will be avatar, signature, etc.. etc..
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyTue Oct 21, 2008 4:59 pm
Wow, is it that common? Should I be proud I'm still on my original gas cap? happy
Merit : 148
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyTue Oct 21, 2008 5:53 pm
No, it just 'is' - eventually I quit hangin' it on the cutout in the latch on the gas door. It (the cutout) had a sharp edge, was cutting the tether (slowly).
Duh.
Merit : 148
i'm new Empty
PostSubject: Re: i'm new   i'm new EmptyTue Oct 21, 2008 5:57 pm
...and by the way, the gas cap eventually wears out - maybe you should just replace yours - again, you can get from dealer or auto parts store, should end up around same price.
i'm new Empty
i'm new
