| Quick Question | |
SuperRiv07 Addict
Name : Nick Age : 39 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
| Subject: Quick Question Mon Oct 20, 2008 7:21 pm | |
| I have A 1996 SC RIVIERA And I think its my wheel bearings are bad casue I here humming while Im driving, And My anti lock lite is on and so is my traction lite is also on, So My Question is What do I replace?
Do I repolace The Hub Bearing? IDK
Intense Has this Will this fix the Problem And get rid of the annoying lights On in my Dash Board? http://intense-racing.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IR&Product_Code=UNC-FHB&Category_Code=BS | |
| Subject: Re: Quick Question Mon Oct 20, 2008 9:43 pm | |
| Sounds like the hub/bearing assy, yes. That is what Intense has pictured there, but I don't know if that is correct for your 96 Riv. Check our parts listings on the forum, no doubt you will find the correct parts listed. | |
SuperRiv07 Addict
| Subject: Re: Quick Question Mon Oct 20, 2008 11:56 pm | |
| Where Do I look For that At? | |
SuperRiv07 Addict
| Subject: Re: Quick Question Tue Oct 21, 2008 12:02 am | |
| And Whats The Difference between the one At Intense An this one At ZZP http://www.zzperformance.com/grand_prix/products1.php?id=837&catid=138 | |
SuperRiv07 Addict
| Subject: Re: Quick Question Tue Oct 21, 2008 12:11 am | |
| ND wHAT bOUT THIS oNE oN eBAY? I need to replace driver and passenger side on my 1996 Riviera SC
This one Says its For A 92-96 then there is a different one for 81-91
http://cgi.ebay.com/ebaymotors/92-96-Buick-Park-Avenue-Riviera-front-wheel-bearing-hub_W0QQcmdZViewItemQQ_trksidZp1713Q2em153Q2el1262QQcategoryZ42614QQihZ012QQitemZ220079521474QQtcZphoto | |
| Subject: Re: Quick Question Tue Oct 21, 2008 6:46 am | |
| I've had issues in the past with flaky wheel speed sensors in aftermarket hub/bearing assys. I'd recommend getting a GM one from monsterpartsonline or gmpartsdirect. Other GM discounters have been mentioned in the parts suppliers thread. | |
rivparadise Fanatic
Name : Samuel Age : 51 Location : Niagara Co. Joined : 2007-06-10 Post Count : 381 Merit : 11
| Subject: Re: Quick Question Tue Oct 21, 2008 7:08 am | |
| I went with Timkens. They were a little more but well worth it. | |
| Subject: Re: Quick Question Tue Oct 21, 2008 8:30 am | |
| I agree with rivparadise. I worked with some of the Timken R&D people in an industry association. They really care deeply about quality, down to the metallurgy and coating technology. IMHO you can't go wrong with a Timken bearing. Timken OEMs many (not all) of the bearings for GM. SKF is another top bearing supplier.
Try gmpartsdirect or NAPA. If the NAPA store has theri value line and top line hub assemblies in,a sk the counter guy to let you see both. You will probably see somewhat of a difference. The difference is in materials - can't really see that - but that's reflected in how they parts are fit and finished.
SuperRiv07 Addict
| Subject: Re: Quick Question Tue Oct 21, 2008 5:22 pm | |
| OK Kool Guys, Im Gonna Go to Napa In the Morning | |
| Subject: Re: Quick Question | |
| Quick Question | |
