| Center Console Armrest will not behave. | |
sburch23 Addict
Name : Scott Location : Alpharetta, GA Joined : 2007-04-02 Post Count : 547 Merit : 14
 | Subject: Center Console Armrest will not behave. Wed Oct 22, 2008 7:21 pm | |
| It will barely stay down. The slightest bump will cause it to come unlatched if my arm is not on it. The hook mechanism looks OK and what I can see of the latch in the center console itself looks ok. There are no obvious front to back adjustment places that I can see.
Ideas? |
L67 Aficionado
 | Subject: Re: Center Console Armrest will not behave. Wed Oct 22, 2008 7:56 pm | |
| mines broken my ghetto fix: velcro  |
ibmoses Aficionado
 | Subject: Re: Center Console Armrest will not behave. Wed Oct 22, 2008 8:41 pm | |
| Mine was doing the same thing. Upon close inspection I found that the plastic arm that protrudes from the lid was broken and just barely hanging on... Take the lid off where you can inpect it closely and see if that is the problem. Gorrila Glue solved my problem. Bert  |
Jeremy Amateur
Name : Jeremy Age : 31 Location : Hattiesburg, MS Joined : 2008-03-25 Post Count : 48 Merit : 0
 | Subject: Re: Center Console Armrest will not behave. Wed Oct 22, 2008 9:01 pm | |
| Does it have alot of slack in it? like can you move the lid from side to side? |
sburch23 Addict
 | Subject: Re: Center Console Armrest will not behave. Thu Oct 23, 2008 10:29 pm | |
| No slack in cover when it is down.
Hook that is attached to the lid looks OK. However it is probably some type of broken plastic thingy somewhere.
Not a problem when cruising down the interstate and my arm is on it. But when I driving through downtown Atlanta, pretending to be Jeff Gordon at Talledega and it pops up, it is dangerously distracting. |
sburch23 Addict
 | Subject: Re: Center Console Armrest will not behave. Wed Nov 05, 2008 8:31 pm | |
| The L67 "ghetto fix" worked with some velcro from Auto Zone |
ibmoses Aficionado
 | Subject: Re: Center Console Armrest will not behave. Wed Nov 05, 2008 8:34 pm | |
| - sburch23 wrote:
- No slack in cover when it is down.
A couple of years ago at Talladega one of the NASCAR drivers(I think it was Stewart) said that I-20 between Atlanta and Birmingham scared him worse than racing at Talladega. Bert  |
sburch23 Addict
 | Subject: Re: Center Console Armrest will not behave. Wed Nov 05, 2008 8:42 pm | |
| I put over 100,000 miles on my car between Atlanta and Meridian, MS. I-20 goes right by Talladega. The people on the track are mostly professionals, going virtually the same speed and they are not holding a cell phone to their ear. On I-20 you get all of that plus construction crews, animals, Ma & Pa Kettle driving 52mph in a Rambler, semi's pulling out in front of you going 15 mph slower, the list is endless. |
96riv Fanatic
Name : Dennis Location : Phoenix Joined : 2007-03-08 Post Count : 378 Merit : 7
 | Subject: Re: Center Console Armrest will not behave. Wed Nov 05, 2008 11:31 pm | |
curious riv Addict
Name : Chris Age : 38 Location : C'view FL Joined : 2008-10-20 Post Count : 521 Merit : 3
 | Subject: Re: Center Console Armrest will not behave. Thu Nov 06, 2008 8:45 am | |
| The plastic that holds one end of the spring is broken on mine. It stays down. If I want it up i just pick it up... The damn thing does wiggle more than i want tho, feels like it might break off one day |
albertj Guru
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 6868 Merit : 131
 | Subject: Re: Center Console Armrest will not behave. Thu Nov 06, 2008 9:45 am | |
| Ed Morad seemed to have a lot of rivs show up all of a sudden. Maybe contact him, may get a replacement for less than you think.
Albertj |
sburch23 Addict
 | Subject: Re: Center Console Armrest will not behave. Thu Nov 06, 2008 11:35 pm | |
| Thanks for the additional ideas. Today the velcro adhesive proved to be weaker than the velcro and it pulled it off. |
dreww Junkie
 | Subject: Re: Center Console Armrest will not behave. Thu Nov 13, 2008 9:18 pm | |
| - sburch23 wrote:
- Thanks for the additional ideas. Today the velcro adhesive proved to be weaker than the velcro and it pulled it off.
probably cause the adhesion surface isn't completely smooth. either try sanding it down smooth, clean with alcohol first and then apply, or both. |
curious riv Addict
 | Subject: Re: Center Console Armrest will not behave. Thu Nov 13, 2008 10:33 pm | |
| i saw some new(i guess new) plastic kinda velcro. both sides are plastic. might work better. idk where to get it though... |
Name : Derek Age : 46 Location : Reading, MA Joined : 2007-01-31 Post Count : 7717 Merit : 109
 | Subject: Re: Center Console Armrest will not behave. Thu Nov 13, 2008 10:48 pm | |
| I don't know of any adhesive velcro that has withstood the test of time without a little crazy glue added to the adhesive side... |
curious riv Addict
 | Subject: Re: Center Console Armrest will not behave. Thu Nov 13, 2008 11:01 pm | |
| if you wanna get crazy with the crazy glue- try lexel. its a little expensive but cross silicone caulk with crazy glue and lexel is whatu get. if you want something to stick for good, use that. it's in the caulking aisle at most hardware stores |
EASHER Member
Name : ERIK M. ASHER Age : 49 Location : BLOUNTSTOWN, FL Joined : 2008-10-24 Post Count : 85 Merit : 0
 | Subject: Re: Center Console Armrest will not behave. Thu Dec 04, 2008 8:09 am | |
| - 96riv wrote:
- Take the spring out.
X2 That's what I did on my car. It works and no cost  |
