| 2002 Century Help. Anti-lock and Traction off lights | |
manofmany Addict
| Subject: 2002 Century Help. Anti-lock and Traction off lights Thu Oct 23, 2008 6:43 pm | |
| Hey guys, my grandarents have a 2002 Century with 74k on it. Years back with only 10k they had to have a passenger side hub replaced.
Now they are getting Anti-lock and Trac off lights on here and there. Happens more times than not. I jacked up the drivers side and there is a good amount of side to side play, but no up and down.
All the boots look great and the tie rod still seems stiff. Sway bar links and control arms are in good shape. Car is always garaged. To me, it would almost have to be the hub, but at $130 for a timken replacement, I can't be wrong.
What do you guys think? | |
Jason Aficionado
| Subject: Re: 2002 Century Help. Anti-lock and Traction off lights Thu Oct 23, 2008 6:47 pm | |
| I'd say it's the VSS sensor in the wheel hub. It's pretty common.
You can confirm by scanning the car. It will tell you which side to change. | |
manofmany Addict
| Subject: Re: 2002 Century Help. Anti-lock and Traction off lights Thu Oct 23, 2008 6:51 pm | |
| Doesn't it need to be taken to a garage with a certain scanner to be certain? I need the same done on my Riviera unfortunately. but don't care about traction or abs. Also, does the whole hub need replaced? ABS Speed sensor? Is this what your talking about: | |
Jason Aficionado
| Subject: Re: 2002 Century Help. Anti-lock and Traction off lights Thu Oct 23, 2008 7:07 pm | |
| Just an obd2 scanner. I think Autozone in the USA does it for free? Yes, the whole hub has to be changed since the wheel speed sensor is built into it. Sorry. Unless you can repair the faulty wire. Don't go for the cheap-o hubs. Go for the Timken or SKF. I think they are the only two still made in America, though some have reported getting Chinese made versions of those. Check the box. When my gf's regal had the same problem, just cleaning the contacts on the connector bought her like 4 months. | |
manofmany Addict
| Subject: Re: 2002 Century Help. Anti-lock and Traction off lights Thu Oct 23, 2008 7:36 pm | |
| Cool thanks a bunch Jason, you were a big help.
Oh, side by side = bearings, correct? | |
| Subject: Re: 2002 Century Help. Anti-lock and Traction off lights Thu Oct 23, 2008 7:53 pm | |
| Could be; or tie rod ends worn, play in any of the steering linkage. Have someone look at all joints with flashlight while you move the wheel side to side. Sometimes a little play in each joint can add up. | |
| Subject: Re: 2002 Century Help. Anti-lock and Traction off lights Thu Oct 23, 2008 10:47 pm | |
| The scanners they have at AZ do not read ABS codes. A good modern mechanic or a brake shop should be able to read the codes for you. Don't know if they'll do it for free, but they should be able to read it.
I had to pay a shop $30 (minimum charge) to read my ABS code so I could find out which hub to replace. | |
| Subject: Re: 2002 Century Help. Anti-lock and Traction off lights Fri Oct 24, 2008 1:13 am | |
| I took my car in to a shop last week. The mechanic could tell which hub was bad just by pushing on the wheel. He diagnosed the tie rod ends using a similar technique. Any good front end man should be able to tell you what's wrong without plugging into the OBD system.
MOVED TO: BRAKES & SUSPENSION _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
manofmany Addict
| Subject: Re: 2002 Century Help. Anti-lock and Traction off lights Fri Oct 24, 2008 11:13 am | |
- I took my car in to a shop last week. The mechanic could tell which hub was bad just by pushing on the wheel. He diagnosed the tie rod ends using a similar technique. Any good front end man should be able to tell you what's wrong without plugging into the OBD system.
MOVED TO: BRAKES & SUSPENSION Thanks AA. The tie rods did not seem culprit at all. Did he get alot of side to side play? Also, I know a tie rod would not be a cause of those lights. | |
| Subject: Re: 2002 Century Help. Anti-lock and Traction off lights Fri Oct 24, 2008 1:06 pm | |
| I think tie rods are side to side, bearing is up & down. I don't know exactly how he does it, but he's almost always right. Comes from doing it for 30+ years, I guess. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: 2002 Century Help. Anti-lock and Traction off lights | |
