 Supercharger oil (Series I SC)
allfalldown
allfalldown
Supercharger oil (Series I SC) Empty
PostSubject: Swapped SC Oil in my 1995 Riviera   Supercharger oil (Series I SC) EmptyWed Jul 25, 2007 5:37 am
Not a tough job but I replaced the SC oil in the rig. Took 1.5 of the original 2 GM Supercharger Oil bottles.
The old stuff was dirty, gritty and smelled terrible. I have no idea how old it was but I figured better save than sorry.
I used a soap pump to get the old stuff out.
I doubt there is any more power or mileage but I feel it is nice an fresh with good new lubrication.
http://www.chevyorange.com
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptyWed Jul 25, 2007 9:19 am
quote: "...and smelled terrible."
lol Normal, but you're right... it's some nasty stuff! Stay clear!!!
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptyWed Jul 25, 2007 6:13 pm
I thought you couldn't change the SC oil in the 95 model? Where do you change it from?
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptyThu Jul 26, 2007 12:29 am
Jack, I read a discussion on this in the last month or so, don't recall where, here maybe? Anyway, I think it is just that the fill plug is in a less obvious location than the M90. Search around thoroughly, I'll bet you find it.
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptyWed Nov 21, 2007 5:04 pm
i changed mine today i took the SC and turned it upside down and just dumped all the crap our, it was black and felt terrible
ricos20002
PostSubject: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptySat Oct 25, 2008 12:58 am
Do you have to put GM's s/c oil in? I've changed my oil out and put SYNCHROMESH oil inabout a week ago headbutt My dumass didnt search first. Will it hurt anything???
Merit : 122
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptySat Oct 25, 2008 1:54 pm
for the m62 in your 95, in a pinch you can use 5w 30 synthetic, usually better with 50/50 with lucas oil stab., but really you should stick with GM SC oil. If the SYNCHROMESH is not dedicated SC oil, better get it out and some real stuff in ASAP.
ricos20002
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptySat Oct 25, 2008 4:39 pm
Well its not s/c oil but its for standerd tranys, it should work ok right?
Merit : 122
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptySat Oct 25, 2008 4:42 pm
I'd switch it out if I were you. Take 5w30 syn and lucas at 50/50, or GM SC fulid, other stuff plays havoc with our superchargers...
ricos20002
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptySat Oct 25, 2008 5:23 pm
what can it do to it? Its just 2 gears, and the oil im useing is syn oil. BTW thank you for all your help
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptySat Oct 25, 2008 5:45 pm
GM s/c oil is a specialty oil made exactly for that one application. i would never use anything other than that oil in the s/c. i cant tell you what may happen, but worse case scenario is the oil overheats, breaks down, and your rotors seize up.
another good thing about the gm stuff is it will last a long time. (i think it is 100k mile service interval)
the dealer will charge you close to $15 for 4oz's of the stuff, but the online vendors sell it for less.
what happens if you put olive oil in the crankcase? i dont know, but i'm not about to find out.
Supercharger oil (Series I SC) Dsc_0110
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptySat Oct 25, 2008 11:09 pm
I believe the 95 service manual actually LISTS an alternative to GM sc fluid. Besides that alternative, I'd recommend using only GM or the fluid available from ZZP and/or Intense.
los1968
PostSubject: how often do i need to cheange the oil in the superchager 95   Supercharger oil (Series I SC) EmptyWed Apr 14, 2010 2:53 am
how often do i need to change the oil in the supercharger of my 95 rivi
Merit : 122
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptyWed Apr 14, 2010 11:18 am
In theory, Eaton lists the blowers as "sealed for life". However, if its never been done, many of us see smoother operation by giving it a change. Also sometimes, oil can leak out the snout seal, so its a good idea to check it now and then. So, if its never been done, than I would do it. If its been done since you've owned the car, just check to be sure the level is correct. When cold, the fluid should come just to the bottom of the threads of the fill port.
The m62 can use synthetic 5w30, sometimes mixed 50% with lucas oil stabilizer. Or you can get the proper supercharger oil from the dealer(its cheap). Old oil can be taken out with a narrow turkey baster, or with a syringe and tube.
rchargrove
PostSubject: super charger oil change   Supercharger oil (Series I SC) EmptyThu Sep 08, 2011 1:48 pm
I have a 1995 supercharged and I cannot find the supercharger oil change port. I have cleaned the snout and there is no port visible. Did they make a supercharger without the port?
Merit : 122
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptyThu Sep 08, 2011 4:02 pm
nope. They all have it. Yours is right where this syringe is sticking:
Supercharger oil (Series I SC) IMG_2136
jbeganny
PostSubject: SC fluid   Supercharger oil (Series I SC) EmptySat Apr 07, 2012 12:47 am
I'm sure it's on here somewhere but if the supercharger unit needs fluid is there a safe substitute if none is available?
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptySat Apr 07, 2012 12:51 am
what year is your Riv?
jbeganny
PostSubject: fluid   Supercharger oil (Series I SC) EmptySat Apr 07, 2012 12:56 am
95sc
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptySat Apr 07, 2012 12:59 am
For the 95s,we have a choice of oils if you go by the FSM.That choice either to use the GM S/C oil or a 50/50 mix of 5W30 & Lucas oil stabilizer.
I have been using the Mix for quite some time and am happy to report that my nose thanks me.
jbeganny
PostSubject: sc fluid   Supercharger oil (Series I SC) EmptySat Apr 07, 2012 1:10 am
thanks!
pbrktrt
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptySat Apr 07, 2012 8:34 am
I've been using Ester 100 compressor oil and it seems happy.
nvsteve
nvsteve
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptySat Apr 07, 2012 8:42 pm
Summit racing has GM supercharger oil, $9 per bottle plus shipping. Got mine yesterday in preparation for doing the "rattling coupler" repair.
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptySat Apr 07, 2012 10:51 pm
the 95 S/C can use 5w30 syn oil.why waste money?
sniperdude
sniperdude
Merit : 18
PostSubject: Re: Supercharger oil (Series I SC)   Supercharger oil (Series I SC) EmptyTue Jun 12, 2012 6:16 pm
Do you guys know how many bottles of GM S/C oil you need to get to properly fill the supercharger?
» Lucas Oil Off Road Racing Series Short Course---USTREAM TV Live
» Melton 400m Series - 22nd & 29th July
» hmf swamp series exhaust
