texasfan010 Enthusiast
| Subject: Scan Wed May 13, 2009 12:48 am | |
| before i start getting too deep into building my car i want to scan for KR. Can autozone's or other parts stores scanners scan for KR? What would i ask for? | |
97rivsc Fanatic
Name : mike Age : 34 Location : appleton wisconsin Joined : 2008-09-28 Post Count : 437 Merit : 0
| Subject: Re: Scan Wed May 13, 2009 12:54 am | |
| I'm really interested in this also | |
nothincame2mind Aficionado
Name : Ryan Age : 38 Location : Columbia, Missouri Joined : 2007-01-19 Post Count : 1182 Merit : 20
| Subject: Re: Scan Wed May 13, 2009 1:46 am | |
| I'm fairly sure Autozone's only scans for codes. There isn't much functionality with them. I used to work there and never saw anything like that. | |
| Subject: Re: Scan Wed May 13, 2009 10:14 am | |
| Yeah, many scanners you buy can't read KR. It was a $100 option for the AutoTap I have. There are about 4 levels of scan tool:
1) codes only = cheap 2) codes + basic parameters = $100-200 3) codes + enhanced parameters (KR) + $200-300 4) enhanced codes & parameters + many additional scan functions = $500+
If AutoZone used the higher end scan tool, they wouldn't be doing it for free. They may be able to see some of the basic parameters at best. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Scan Wed May 13, 2009 10:21 am | |
| - texasfan010 wrote:
- before i start getting too deep into building my car i want to scan for KR. Can autozone's or other parts stores scanners scan for KR? What would i ask for?
They only don't "scan" - they can read stored codes. KR is not an error code, it's a function of driving. You need a scanner that can log parameters and record other meaningful parameters while doing so. You can't get that kind of scan from Autozone or a code reader. | |
| Subject: Re: Scan Wed May 13, 2009 10:47 am | |
| This gauge scans and allows you to read / clear codes.
http://www.aeroforcetech.com/index.html | |
