| Aurora/other V8 engine swap? | |
+41ghpcnm 97 park ave Riv6495 BlownRiv BrianEsser 7901mark Hometown Hero simba robotennis61 Abaddon KillaKeninaRiv Racewriter texasfan010 deekster_caddy turtleman 97rivsc L67 '96reese ewolfe0050 sqrivi TonySmooth89 vendetta IBx1 rivparadise newcastlefatz TType_Riviera 99Rivman zetabird SC95Riv nothincame2mind GothicVash 97rivman 1998 Riv palermocorey90 BigTexKahuna NO 4 EVR oldsman105 T Riley AA Jack the R jax95riv 45 posters |
T Riley Guru
| Subject: Re: Aurora/other V8 engine swap? Mon Oct 27, 2008 1:11 pm | |
| - sqrivi wrote:
- I think the sound from a v8 would be cool. I have also read about 400hp being fairly easy to achieve with the n*. Plus it would be something different.
GM made 2 riv's with N*...... it would be different but not crazy new....... | |
L67 Aficionado
| Subject: LS4 Swap Wed Mar 04, 2009 6:01 am | |
| Turtleman and I were discussing the possibility of an LS4 swap, which is the 5.3L V8 (303 hp, 323 lb/ft) found in the latest Impala and MC SS's, as well as the GP GXP. It's mated to the 4T65E-HD so it should bolt right in! Who's gonna do it? And furthermore how cool would that be?? | |
TonySmooth89 Aficionado
| Subject: Re: Aurora/other V8 engine swap? Wed Mar 04, 2009 1:29 pm | |
| Its been discussed before...
Its possible but so far no one has really tried. Its not like the 3800 can't produce a whole boatload of power anyway. | |
L67 Aficionado
| Subject: Re: Aurora/other V8 engine swap? Wed Mar 04, 2009 1:38 pm | |
| woops my bad | |
| Subject: Re: Aurora/other V8 engine swap? Wed Mar 04, 2009 1:40 pm | |
| I still think it would be cool if someone tried. Honestly though, I rented an Impala SS once - it didn't feel that fast at all. I'm sure the 300 HP was there, but something was missing from that motor. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
97rivsc Fanatic
Name : mike Age : 34 Location : appleton wisconsin Joined : 2008-09-28 Post Count : 437 Merit : 0
| Subject: Re: Aurora/other V8 engine swap? Wed Mar 04, 2009 3:29 pm | |
| I had one of those in my 2001 tahoe. loads of torque, even though it was a truck and I know its not that great to compare with but, didn't have that much upper rpm power imo. but its still a truck so I don't know if that helps. | |
L67 Aficionado
| Subject: Re: Aurora/other V8 engine swap? Wed Mar 04, 2009 3:47 pm | |
| - 97rivsc wrote:
- I had one of those in my 2001 tahoe. loads of torque, even though it was a truck and I know its not that great to compare with but, didn't have that much upper rpm power imo. but its still a truck so I don't know if that helps.
The LS4 has a little better breathing than the regular 5.3 due to the use of LS6 heads, but i agree it is more of a low end motor. | |
| Subject: Re: Aurora/other V8 engine swap? Thu Mar 05, 2009 1:59 am | |
- I still think it would be cool if someone tried. Honestly though, I rented an Impala SS once - it didn't feel that fast at all. I'm sure the 300 HP was there, but something was missing from that motor.
Excessive torque management. I've heard they have a ton of it. | |
nothincame2mind Aficionado
Name : Ryan Age : 38 Location : Columbia, Missouri Joined : 2007-01-19 Post Count : 1182 Merit : 20
| Subject: Re: Aurora/other V8 engine swap? Thu Mar 05, 2009 3:04 am | |
| - TonySmooth89 wrote:
Excessive torque management. I've heard they have a ton of it. Nothing a little tuning couldn't fix. | |
97rivsc Fanatic
| Subject: Re: Aurora/other V8 engine swap? Thu Mar 05, 2009 8:36 am | |
| it sounds like its not impossible. I would like to know how easy it would be to "bolt in" this engine, and how much these engines are going for. | |
| Subject: Re: Aurora/other V8 engine swap? Thu Mar 05, 2009 9:29 pm | |
| I bet if you keep your eyes open you can get one cheap from a yard. | |
97rivsc Fanatic
| Subject: Re: Aurora/other V8 engine swap? Thu Mar 05, 2009 9:44 pm | |
palermocorey90 Expert
| Subject: Re: Aurora/other V8 engine swap? Fri Mar 06, 2009 6:55 am | |
| - Jack the R wrote:
- I bet if you keep your eyes open you can get one cheap from a yard.
yupp the local pick and pull had one, go for 100 bucks. | |
| Subject: Re: Aurora/other V8 engine swap? Fri Mar 06, 2009 8:20 pm | |
| If it went that cheap its because there's plenty of them out there. Keep your eyes peeled!
FWIW a buddy of mine recently saw a 440 w/transmission, 30,000 miles, go for $600. People are hurtin'! | |
| Subject: Re: Aurora/other V8 engine swap? Fri Mar 06, 2009 11:48 pm | |
Excessive torque management. I've heard they have a ton of it. probably a very good reason for that if we can rip up those transmissions with our 280lb-ft motors... Anyone know if there's any worthwhile differences between these newer 4T65's and ours? Still no LSD in em? | |
L67 Aficionado
| Subject: Re: Aurora/other V8 engine swap? Sat Mar 07, 2009 12:02 am | |
| looks like only different ratios * 2.93:1 MN7 Pontiac Bonneville SSEi L67 Chevrolet Impala L67 Chevrolet Monte Carlo L67 Pontiac Grand Prix GTP Buick Regal GS Buick Riviera L67 (97-99) * 3.05:1 MN7 Buick Park Avenue Ultra * 3.06:1 MN7 Chevrolet Impala SS Chevrolet Monte Carlo SS * 3.29:1 MN7 Buick Regal GSX (SLP) Pontiac Grand Prix GTP Comp G Pontiac Grand Prix GXP | |
| Subject: Re: Aurora/other V8 engine swap? Sat Mar 07, 2009 3:25 am | |
| I also heard the GXP drive chains were a bit beefier...but beyond that i don't know what improvements were made , if any. | |
sqrivi Fanatic
Name : scott Location : madison, al Joined : 2008-03-15 Post Count : 375 Merit : 52
| Subject: Re: Aurora/other V8 engine swap? Wed Apr 29, 2009 5:00 pm | |
| How would the obdII work with the ls4 swap? Also does anyone know how much modification it would take to swap engine and trans? | |
| Subject: Re: Aurora/other V8 engine swap? Wed Apr 29, 2009 10:23 pm | |
| - sqrivi wrote:
- How would the obdII work with the ls4 swap? Also does anyone know how much modification it would take to swap engine and trans?
Besides fabbing up your own mounts and brackets and making your own CV shafts, you'll probably also need to take the wiring harness and PCM from the donor car. It's one of those things where if you have to ask these questions, this kind of swap is probably not for you? | |
| Subject: Re: Aurora/other V8 engine swap? Wed Apr 29, 2009 10:29 pm | |
| - deekster_caddy wrote:
Besides fabbing up your own mounts and brackets and making your own CV shafts, you'll probably also need to take the wiring harness and PCM from the donor car. It's one of those things where if you have to ask these questions, this kind of swap is probably not for you? If you use the stock trans, you're only shy one mount to deal with on the motor and still using the same cv shafts, unless I'm totally missing something? With the ls4 pcm and wiring, I could imagine there might be at least some touchup to do in the area of tuning and wiring to keep the stock trans, however. | |
sqrivi Fanatic
| Subject: Re: Aurora/other V8 engine swap? Wed Apr 29, 2009 10:34 pm | |
| I have seen several engines that come with the trans, PCM, and uncut harness. Just trying to get a feel for what might be involved in doing the swap. | |
| Subject: Re: Aurora/other V8 engine swap? Wed Apr 29, 2009 10:45 pm | |
Besides fabbing up your own mounts and brackets and making your own CV shafts, you'll probably also need to take the wiring harness and PCM from the donor car. It's one of those things where if you have to ask these questions, this kind of swap is probably not for you? If you use the stock trans, you're only shy one mount to deal with on the motor and still using the same cv shafts, unless I'm totally missing something? With the ls4 pcm and wiring, I could imagine there might be at least some touchup to do in the area of tuning and wiring to keep the stock trans, however. If you put the stock trans behind an LS4, you'll be buying a new trans soon enough... | |
| Subject: Re: Aurora/other V8 engine swap? Wed Apr 29, 2009 10:59 pm | |
| LS4 323lb-ft @ 4400rpm L67 280lb-ft @ 3600rpm
I wouldn't necessarily say that. The LS4 really just makes more top end than the 3800 which means with factory tuning, the LS4 might bite the trans a little more when shifting at WOT but that can easily be compensated for, via stock or LS4 programming.
Don't forget it's basically the same transmission. | |
| Subject: Re: Aurora/other V8 engine swap? Wed Apr 29, 2009 11:00 pm | |
| I'm trying to encourage this swap, Derek | |
T Riley Guru
| Subject: Re: Aurora/other V8 engine swap? Wed Apr 29, 2009 11:01 pm | |
| Subject: Re: Aurora/other V8 engine swap? | |
