 Write-Up: 95sc Changing the coupler in an Eaton m62
Merit : 122
Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 Empty
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptySun Jul 19, 2009 5:47 pm
and you will probally find that the m62 takes maybe a bottle and a bit of GM SC fluid. Holds much less of it than the m90.
(and +1 on the injector O rings, always a good plan)
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptySun Jul 19, 2009 8:14 pm
Yup, came with 2 yellow o-rings.
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyFri Jul 24, 2009 7:47 pm
Hey, question, when you reinstall the S/C, does it matter what position the lobes are in in relation to the rest of the stuff on/in the engine?
woggy
woggy
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyFri Jul 24, 2009 9:35 pm
please explain what you mean by "lobes" more than likely the answer is no
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyFri Jul 24, 2009 10:04 pm
Lobes on the rotors, I thought they might be timed with the engine, but my buddy Corey told me it doesn't matter.
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyFri Jul 24, 2009 10:12 pm
It doesnt matter. there is no way for the motor to know what the position of the rotors are at any give time.
Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 Dsc_0110
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyFri Jul 24, 2009 10:35 pm
Good, I didn't think so but if it was that'd be a pain to figure out.
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyTue Aug 11, 2009 5:35 pm
ud be amazed how amazingly hard it is to find a mechanic to replace a damn 95 coupler
KillaKeninaRiv
KillaKeninaRiv
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptySat Aug 22, 2009 7:10 pm
I changed my SC oil the other day and I used a whole bottle of GM's oil, which was totally different from gear oil, almost watery, like id heard someone else asking a while back. The old oil was blackish gray and smelled like a mixture of ass, feet, athletes foot, and locker room. I used a glass turkey baster, which turned out to be a bad idea, but it worked pretty good until it broke in the opening and then took 15 minutes to pry out the piece. So next, I used a spray bottle nozzle and tube and stuck the tube in and started pumping and that let me get all of the fluid out, which turned out to be one full bottle. After changing it, it ran alot better, smoother with better response, but I still have to change that coupler out, which GM told me they dont stock for some reason.
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptySat Aug 22, 2009 8:56 pm
The coupler is available through the aftermarket. Try ZZP or Intense Racing.
Their internet sites are listed here under vendors.
The GM bottle of SC fluid is only 4oz. The supercharger holds 8oz.(two bottles)
I recommend checking the level now that you've removed the old and put in some new. You could be very low on fluid.
Intense sells a whole kit for the coupler job. It includes the coupler, 8oz. of fluid and the proper GM sealant for the snout. It's actually cheaper to go that route and you'll have everything you need to start and finish the job.
NOTE: I just noticed this an M62. I don't know what the volume of fluid is in that unit.
I know the M90 takes 8oz. M62 = ???
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptySat Aug 22, 2009 11:26 pm
"save the whales!"
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptySun Jan 03, 2010 2:36 pm
I am about to replace the coupler in mine and will order the kit from Intense in a bit. The car is idling really rough and I hear the rattle of the coupler going along with the rough idle so I believe that the problem may be the coupler itself. Hopefully that is all it is.
This is on my 98. I believe AA answered it earlier in the thread, but I just want to be sure. Do I need to remove the SC on my 98 or can I do the job while leaving it on? Any help would be awesome!
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptySun Jan 03, 2010 2:49 pm
On your 98 the SC can stay on the car.
You will have to loosen and move the Alternator off to the side if I remember correctly.
All told, not a difficult job to do.
With 140K miles on your engine, have you ever had the fuel injectors sent out for cleaning and flow matching.
It is just around $100.00 including shipping. Could be the source of rough idling as well.
Also have you replaced all your vacuum lines recently, again another source of rough idle.
And there are all the usual suspects, Spark Plugs and Ignition Wires, MAF cleaning, TB cleaning, etc.
Where do you stand with all the preventive maintenance stuff. The reason I bring it up is you may find that after changing the coupler your rough idle may still be there.
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptySun Jan 03, 2010 4:17 pm
Zep, try removing the supercharger belt, tucking it safely out of the way and running the engine. Does it still idle rough? If yes, it's not the coupler causing the rough idle.
The coupler is an annoying sound, but shouldn't affect performance until it fails.
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyTue Jan 05, 2010 9:43 am
I'll work on these things today. I finally have some free time. The vacuum lines haven't been replaced and fuel injectors haven't been messed with. New spark plugs were put in 2k miles ago and new wires 10k miles ago. I may want to think about MAF and TB cleaning too. I'll look at the various write ups first.
Hard4unot2
Hard4unot2
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyTue Mar 30, 2010 9:48 am
You Guys are da Bomb!
http://hseintegrated.com
R1V13RA
R1V13RA
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyThu Apr 15, 2010 4:56 pm
ok....so im changing the coupler out on my 95 and im trying to figure out which gasket i need for the bottom of the sc to the engine and from the right side of the SC to the TB
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyThu Apr 15, 2010 5:18 pm
log onto autozone.com and you will find it there. thats where i bought mine. $12 bucks or so...
Merit : 122
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyThu Apr 15, 2010 7:02 pm
Plenum gasket:
CORTECO Part # 23977
FEL-PRO Part # MS95741
ROCK PRODUCTS Part # MG3180
TB gasket:
FEL-PRO Part # 61025
STANDARD MOTOR PRODUCTS Part # 2037
R1V13RA
R1V13RA
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyThu Apr 15, 2010 7:46 pm
thanx robot n karma....bout to go picc em up now... i went to auto zone earlier n the dude helpin me COULDNT help me...lol...said that the computer wasnt showing anything....
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyThu Apr 15, 2010 7:59 pm
i believe that capital punishment should apply to all wrong answers that are given to us by autozone workers. the wronged customer gets to pull the switch.
R1V13RA
R1V13RA
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyFri Apr 16, 2010 7:58 pm
i second that motion!!
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptySat Apr 17, 2010 7:01 pm
Fresno & Houston?
Hmmmm.... Were you actually attempting to make this transaction in English? headbutt
R1V13RA
R1V13RA
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptyThu May 06, 2010 3:58 pm
Eldo wrote:
Fresno & Houston?
thumbsup im sure u still understand wut im sayin...erybody else does. but i wuznt makin any transactions bonk and yes im n Fresno part of the yr and Houston part...Des Moines too...i go where the money is afro
kbuick95
PostSubject: temp   Write-Up: 95sc Changing the coupler in an Eaton m62 - Page 3 EmptySat Aug 31, 2013 1:17 pm
When you put the nose cone back on the sc is there any amount of tourque you need to use on the bolts to assemble it.
Page 3 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» Changing wheel bearings
» Purchase of a new jersey - Karlsson number changing?
» Converting a Vari-Drive to a 5 Speed Manual
» HID Conversion Kit Install Instructions
