 regal rims on riv
peev0021
peev0021
regal rims on riv Empty
PostSubject: regal rims on riv   regal rims on riv EmptyWed Nov 05, 2008 4:21 pm
PostSubject: Re: regal rims on riv   regal rims on riv EmptyWed Nov 05, 2008 4:30 pm
O please change the color of that link! I can't look at it.
PostSubject: Re: regal rims on riv   regal rims on riv EmptyWed Nov 05, 2008 4:31 pm
I think for $300/wheel, you can do a better wheel.
PostSubject: Re: regal rims on riv   regal rims on riv EmptyWed Nov 05, 2008 4:39 pm
It's for a set of 4 @ $299. I'd get something nicer instead of spending that much on them. Also, depending on your Riv, we have 16x7 stock rim size(not all of us). And there are no center caps or lug nuts included. Center caps are not cheap either.
peev0021
peev0021
PostSubject: Re: regal rims on riv   regal rims on riv EmptyThu Nov 06, 2008 6:26 pm
im only running stock size(225/60/16) how much of a difference will the 6.5 compares to my 7 inch rim be
PostSubject: Re: regal rims on riv   regal rims on riv EmptyThu Nov 06, 2008 9:19 pm
A wider rim can take a wider tire of the same aspect ratio (60). You can run the stock tire size on a slightly wider rim without any trouble. You could go to a slightly wider tire, but then you have to start playing with the aspect ratio and your speedo will be off a little one way or the other.
regal rims on riv
» Polaris tires and rims
» How to get rims and hubs off stuck axles.
» 2009 RZR LE black stock rims/tires
» Factory Rims WTB
» ATV rims for a Rhino?
