 Shifter Plastic Clatter
Orca
PostSubject: Shifter Plastic Clatter   Mon Mar 19, 2007 1:39 am
This may sound odd, but I was wondering if you guys had the same thing happen to you. Down by your shifter you may notice there are some plastic pieces that slide back and forth when you shift into gear. Mine slides forward and back when I slow down for a light and/or take off from one. I usually listen to talk radio, so it might be a little more pronounced with my car since I'm not jammin' out all the time.
Have you guys noticed this with your cars? If so, do you know of any way to keep it from making any noise?
Merit : 83
PostSubject: Re: Shifter Plastic Clatter   Sun Apr 08, 2007 1:51 am
No problems here. Your's must be broken. The good news is, you can likely pull it off any Riv out there unlike other interior parts that are colored.
NO 4 EVR
PostSubject: Re: Shifter Plastic Clatter   Sun Apr 08, 2007 2:57 pm
Hmm. Never heard that. You can get a better look in there by taking some things out. The large plastic piece that covers that area can be pulled out, at least mine did. Just held in by a bunch of cheap metal clips and some some stick stuff.
PostSubject: Re: Shifter Plastic Clatter   Sun Apr 08, 2007 5:19 pm
Mine stays in place also. Never had it making any noise besides when shifting.
