jase386 Amateur
Name : donovan Age : 46 Location : Greenville SC Joined : 2008-11-04 Post Count : 22 Merit : 0
| Subject: 1990 Console Help Mon Nov 10, 2008 2:37 am | |
| Does anyone know how to get the 'wood' part of the console out of a 1990 Riviera? Its filthy in all the cracks, and the change holder and i want to clean it. the previous owner had kids or something. Also the viewing glass for the transmission indicator is cruddy underneath, i need to get that out so i can clean the Coke from under it. | |
| Subject: Re: 1990 Console Help Fri Nov 14, 2008 1:04 pm | |
| Sounds like you need to search EBay for a service manual.
In teh meantime, if you are gentle with it you can use a SOFT toothbrush and a vacuum cleaner to get the crud out of the filthy cracks. May need to spritz a little furniture polish on it to act as a solvent to wet the crud so that you can indeed get it out with the vacuum cleaner (a canister or wahtever with a hose and brush or nozzle attachment).
99Rivman Aficionado
| Subject: Re: 1990 Console Help Fri Nov 14, 2008 4:41 pm | |
| My '92 is gone now but if I remember correctly ... there are screws under the lid that you remove, and then the rest of it is just held in with clips. You would just pry up on it to get it out. I would have to look in my service manual to be sure but I think thats it.
HTH | |
| Subject: Re: 1990 Console Help | |
