 need tranny for 95?
hworr
need tranny for 95? Empty
PostSubject: need tranny for 95?   need tranny for 95? EmptyWed Nov 12, 2008 4:09 am
My tranny will not shift from 3rd to 4th after it gets warm.
PostSubject: Re: need tranny for 95?   need tranny for 95? EmptyWed Nov 12, 2008 5:20 am
Ummm Ok...... AND???
PostSubject: Re: need tranny for 95?   need tranny for 95? EmptyWed Nov 12, 2008 7:19 am
Have you checked the fluid level? ALL the vacuum lines? Is it S/C or NA? Help us help you. Give us a little more info to go on.
Redline
PostSubject: Re: need tranny for 95?   need tranny for 95? EmptyMon Dec 29, 2008 2:02 pm
Did you find the parts you were looking for??
Mike
mcmillen@pushcorp.com
1995 Riv
PostSubject: Re: need tranny for 95?   need tranny for 95? EmptyMon Dec 29, 2008 8:57 pm
Pull site cover off of top of engine you will find cracked vacuum lines left side of throttle body probably about three. Look down to transmission and check rubber line at transmission modulator.
jamie
jamie
PostSubject: Re: need tranny for 95?   need tranny for 95? EmptyMon Dec 29, 2008 9:10 pm
Quite likely, mine suffered from this as well.
Merit : 154
PostSubject: Re: need tranny for 95?   need tranny for 95? EmptyMon Dec 29, 2008 10:12 pm
So, Wayne, did you take the advice and what did you find?
randall strawn
PostSubject: Re: need tranny for 95?   need tranny for 95? EmptyThu Jan 15, 2009 10:27 am
[quote="98riviera98"]
Ummm Ok...... bonk I have a rebuilt tranny in the car if you need one. 3000 miles on rebuild. Still in car.
randalls3332003@yahoo.com
need tranny for 95?
» what kinda oil do you use in your tranny?
» tranny question
» Help! Tranny moaning and groaning
» EMP Tranny Saver
» Cracked tranny case
