 Switch on mirror
cragmor
Switch on mirror Empty
PostSubject: Switch on mirror   Switch on mirror EmptyMon Mar 19, 2007 4:06 pm
I am wondering what the switch on the mirror is for. I have done a little looking, but have not come up with much. Is it to dim the mirror for when bright lights are behind you, or is it for the twilight sensor for the headlights? dunno
PostSubject: Re: Switch on mirror   Switch on mirror EmptyMon Mar 19, 2007 4:12 pm
you answered your own question man YESSSSSSSSSSSSS thats the dimming switch whip
NO 4 EVR
NO 4 EVR
PostSubject: Re: Switch on mirror   Switch on mirror EmptyMon Mar 19, 2007 4:49 pm
I don't know if mine don't work well or these dimmers don't work well in general, but they don't work like my bonneville dimmer did. The bonneville dimmed very quickly when set to high and I could really see a difference between on and off. The Riv is harder to tell. Is this normal?
PostSubject: Re: Switch on mirror   Switch on mirror EmptyMon Mar 19, 2007 5:12 pm
Mine works pretty well. Gets green & dim when lights are behind.
PostSubject: Re: Switch on mirror   Switch on mirror EmptyTue Mar 20, 2007 10:02 am
it depends on how much your windows are tinted b/c the sensor is on the rear view mirror. mine worked faster and better before i had the windows tinted, it still works great now and dims just fine, but it takes a little bit more lights to make it kick on
Switch on mirror Dsc_0110
PostSubject: Re: Switch on mirror   Switch on mirror EmptyTue Mar 20, 2007 10:35 am
But when you think about it, that might not be an issue. It's all relative, because in the end the sensor needs the same amount of light in order to do its job, so it still works, just doesn't need to as much because there's less light coming in.
Switch on mirror
» Mirror lights
» Radiator Thermo Switch
» Does anyone know of an external speaker with a switch?
» Mirror Light Conversion to Amber LED
