 Burning rubber smell
Steve98
Apprentice
Merit: 2
PostSubject: Burning rubber smell   Fri Nov 14, 2008 1:04 pm
I smell burning rubber when I drive my Riv. When I park it, I can see very thin misty smoke that smells like burning rubber coming from the engine bay. Apparently I have some belts that are slipping or something. Has anybody experienced the same thing?
captshiner
Merit: -1
PostSubject: Re: Burning rubber smell   Fri Nov 14, 2008 1:10 pm
The next time you see the smoke, open the hood and you should see where it's coming from. If it's the belts, I'd imagine the would be chirping or squealing.
http://www.facebook.com/profile.php?id=572362129
Steve98
Apprentice
Merit: 2
PostSubject: Re: Burning rubber smell   Fri Nov 14, 2008 1:22 pm
I've opened the hood. The smoke is too thin to trace the source. I can only see it in the glare of the headlights. There is no squeeking or chirping from the belts. When I'm driving, I usually smell it only when I'm idling at a light. Maybe that is a clue.
captshiner
Merit: -1
PostSubject: Re: Burning rubber smell   Fri Nov 14, 2008 1:26 pm
Are you sure it's burning rubber, does it smell sweet like maple syrup at the same time? Check out your cooling system, especially hoses. Make a signature with some basic info on your Riv so we have an idea what you're dealing with.
Merit: 83
PostSubject: Re: Burning rubber smell   Fri Nov 14, 2008 1:29 pm
I would tilt my educated guess at leaky valve cover gaskets here. trace amounts of oil is kind of like a burnt rubbery smell.
captshiner
Merit: -1
PostSubject: Re: Burning rubber smell   Fri Nov 14, 2008 1:31 pm
I was just thinking, when rubber burns it makes really thick smoke. The valve cover gasket is another good place to look.
Merit: 96
PostSubject: Re: Burning rubber smell   Fri Nov 14, 2008 2:43 pm
FWIW, I had a similar experience with the smell of burning rubber, (or so I thought) and seemed to be coming from under the car. After taking temp measurements with an IR thermometer I found it to be actually coming from the left rear wheel. Rotor temp was about 400* F. Prior to looking for the problem it would only happen occasionally then progressed to every drive. Had sticking caliper, replaced both rears with Reman units, checked runout of nearly new EBC rotor and all was good.
If I had cheap Chinese rotors on it I'll bet it would have been trashed.
Anyway, you probably don't have same problem if your seeing smoke, though. Just thought I'd throw my 2 cents in.
Steve98
Apprentice
Merit: 2
PostSubject: Re: Burning rubber smell   Fri Nov 14, 2008 3:01 pm
I am not sure it is burning rubber, but I am sure it is coming from under the hood. I like the leaking gasket idea and will check that out.. Thanks for the feedback everyone. It is very appreciated.
P.S. I created a signature for myself, but it never shows up for some reason.
vendetta
Merit: 0
PostSubject: Re: Burning rubber smell   Fri Nov 14, 2008 3:30 pm
^ you have to check the box that says "show signature"
Steve98
Apprentice
Merit: 2
PostSubject: Re: Burning rubber smell   Fri Nov 14, 2008 3:36 pm
Thanks. Hopefully my Riv issue will be just as easy. smile
» Rubber for a sluice?
» throat burning
» Burning rubber smell
» noise from clutch area
» Scotland trip
