| Write-Up: Yellowed Corner Lenses | |
+57IFallsRon h20man joshuadalegrimes Sir Psycho Sexy llamalor2112 matt270avian charlieRobinson ALR37115 HeartBeatRivi c0reyl Jelorian gmann3001 96riv BMD jlaw ghpcnm IBx1 nebstewart07 bigdave GMFreak8 Steve98 robotennis61 steve s 1wickedninja #1BearsFan woggy dnyce200 DEMonte1997 Eldo Rickw ibmoses albertj Sweepspear sburch23 curious riv deekster_caddy KillaKeninaRiv TonySmooth89 Shintsu manofmany nothincame2mind palermocorey90 Jack the R jimmyriv Buapo SpaceBar 97Riv-Jon turtleman Rivgirl06 Mr.Riviera 99Rivman Andysdorm jax95riv 1998 Riv AA xxsupergman25xx T Riley 61 posters |
ghpcnm Aficionado
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed May 25, 2011 4:25 pm | |
| Thanks for the info, ILAN. That's my next project for the weekend,. As you can see in the pic, my corner lamps need some work. I'll let you know how it comes out. | |
IBx1 Expert
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed May 25, 2011 4:50 pm | |
| You'll have to work on the corners a bit to get it right. The directions are on the box, but keep hitting it with the spray lubricant while you're sanding it with the first of four pads, give it a really quick wipe with a cloth to dry it, then keep going until the liquid goes from gray to more of a white/clear color.
I only had to use the sandpapers for the passenger's side light, but that was only 5 minutes of it. | |
ghpcnm Aficionado
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed May 25, 2011 5:01 pm | |
| - IBx1 wrote:
- You'll have to work on the corners a bit to get it right. The directions are on the box, but keep hitting it with the spray lubricant while you're sanding it with the first of four pads, give it a really quick wipe with a cloth to dry it, then keep going until the liquid goes from gray to more of a white/clear color.
I only had to use the sandpapers for the passenger's side light, but that was only 5 minutes of it. Will Do...THANKS !!! | |
ghpcnm Aficionado
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed May 25, 2011 6:28 pm | |
| Just Curious before I start on the corner lamps...Has anyone tried this product ? http://www.glassyliteusa.com/ | |
IBx1 Expert
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed May 25, 2011 10:55 pm | |
| Looks sketchy considering the grammar and that it's a one step deal. I'd go with what every other headlight kit does which is a polish, lube, and different levels of sandpaper. The TurtleWax kit I got is all done by hand, too. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Thu May 26, 2011 10:15 am | |
| I wouldn't dismiss the GlassyLite product simply because the description feels it was written in another country. It is in fact an Australian product. See reviews from people who've actually ordered and used the product:
http://www.amazon.com/GlassyLite-Premium-Headlight-Restoration-Treatment/product-reviews/B001CYC2ZY/ref=pr_all_summary_cm_cr_acr_txt/186-9261451-6272430?ie=UTF8&showViewpoints=1
(Lots of good reviews, and the negative feedback I'm reading doesn't hold a lot of credibility. The biggest complaint is they don't provide enough sandpaper in the box! Seriously people?) _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
IBx1 Expert
| Subject: Re: Write-Up: Yellowed Corner Lenses Thu May 26, 2011 10:20 am | |
| If it's cheaper I guess it's worth a shot, but it's hard to beat the prices of the other kits. All I know is the one I got worked really well. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Thu May 26, 2011 10:30 am | |
| The GlassyLite kit costs $35. If an $8 Turtlewax kit works really well, I'd be pretty angry if the more expensive kit didn't work. But most who use it seem impressed.
These products are hard to evaluate because the immediate results are all the same. They all make the headlamp appear nice and clear. I can get the same result with a simple polishing compound and small buffer wheel. I've had good luck with Scratch-Ex on a rag, too. But the key thing is what will happen over time. How long does the product protect? Do the symptoms return, and to what extent? A good product in this category should offer extended protection, and that's tough to know until a year or so down the road. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
IBx1 Expert
| Subject: Re: Write-Up: Yellowed Corner Lenses Thu May 26, 2011 11:34 am | |
| Actually, that's a good question, what happens down the line? The kit I got has a UV sealant wipe which is the last step to restoring the headlights. When you sand the headlights down, you remove the UV coating which keeps the headlight from hazing and yellowing right back up. If you don't use the sealant wipe, your headlights turn yellow in about 3 weeks of sunny days' time. When you use it, it's basically turning the clock back to factory stock. | |
ghpcnm Aficionado
| Subject: Re: Write-Up: Yellowed Corner Lenses Thu May 26, 2011 11:49 am | |
| ILAN: I think I'm gonna go with the Turtle Wax product for now. Simply because it's available locally and I'm wanting to get 'r done this weekend. That is, IF I get my car out of the body shop. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Thu May 26, 2011 12:01 pm | |
| Agree, so the basic concept is: abrade + polish + protect. All the kits (should) do these things in some way or another.
Abrade: this is the use of fine sandpaper, and/or abrasive compound to remove the oxidation. Sometimes the compound is also a polish at the same time. This isn't complex science. Steel wool will also work in theory.
Polish: after roughing up the surface, it needs to be smoothed back to a shine. Again, this isn't much different than what autobody workers have been doing for 100 years to bring paint to a mirror gloss. It's also one reason we use toothpaste on our teeth. In fact, builders of plastic model cars know that toothpaste is an excellent compound for giving the plastic an amazing shine.
Protect: I suspect this is the step that makes the difference between lesser kits and the ones that really protect over time. The protective coating must go on evenly, dry quickly, and not scratch, chip, or discolor over time. Good UV protectants are expensive, and so add to the cost of the product.
A note about glass - these headlamp restore kits should never be used on glass lamps, because glass doesn't break down or discolor from UV light like the plastics can. There is just no need. Glass is also a harder surface, so it doesn't scratch or fog up like plastic does when subject to high speed wind, particles and debris on the road. Only use these kits on the plastic lens pieces. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
jlaw Member
Name : Jay Location : Vancouver Island, Canada Joined : 2011-04-19 Post Count : 70 Merit : 2
| Subject: Re: Write-Up: Yellowed Corner Lenses Sat May 28, 2011 8:57 pm | |
| Just used the permatex on my corners - they were very yellow. Doesn't look like a million bucks, but certainly looks worth the 15 bucks I spent. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Sat Oct 15, 2011 12:33 am | |
| Been meaning to post this for some time now. I wet sanded my corner lights in my riv back in January. Used 1500-2500 grit and finished with some compound/plastix. They looked pretty good after. THEN i waxed the left hand side and used auto clear coat (from Autozone) on the right side. After applying 3 thin coats i buffed it to a shine. Here is the left side after 6 months: And here is the right side: _________________ 1996 with 254k miles, L32Â 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
BMD Aficionado
| Subject: Re: Write-Up: Yellowed Corner Lenses Sat Oct 15, 2011 9:50 am | |
| Great results Matthew, looks like you have found a solution for those corners, let us know how long they last. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Sat Oct 15, 2011 11:05 am | |
| Is this auto clear coat the paint or the turtle wax clear coat polish? Please clarify, thanks.
| Subject: Re: Write-Up: Yellowed Corner Lenses Sat Oct 15, 2011 11:12 am | |
| This is the product i used. _________________ 1996 with 254k miles, L32Â 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Sat Oct 15, 2011 11:14 am | |
| - Mr.Riviera wrote:
- This is the product i used.
OK it's the paint. I use Turtle Wax ICE (an armor-all-type spray) on the lenses when I wash the car. I should post a picture. Albertj | |
96riv Fanatic
| Subject: Re: Write-Up: Yellowed Corner Lenses Mon Oct 17, 2011 6:38 pm | |
| A friend let me use his CCP headlight restoral product. he got it at Harbor Freight. Connected the pad to a drill put some solution on pad and buffed the cornering lamps. Took me less than 5 minutes and most of the yellowing is gone. Another friend told me to use the stuff you clean your flattop stove with, he claims it works.. | |
gmann3001 Fanatic
Name : Glenn W. Peck Age : 50 Location : Orland Park, IL. Joined : 2011-11-16 Post Count : 389 Merit : 9
| Subject: repolishing marker lights Wed Feb 15, 2012 12:44 am | |
| Today I went to the chicago auto show. I looked at all the crap they try to hock out to people... and it was all crap! except for this polish at an small little table. just one guy, and some shinny soda cans and a foggy headlight. WOW!!! it took off all the yellow- white fog on the lens! I said good buy to my money and came home and tried it on my Riv. Marker lights, here are some pics Before After The product I used | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Feb 15, 2012 1:07 am | |
gmann3001 Fanatic
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Feb 15, 2012 4:02 pm | |
| I want to take the lens off now and get the edges... I think that will get rid of the rest of that Yellow discoloration. | |
| Subject: Re: Write-Up: Yellowed Corner Lenses Wed Feb 15, 2012 10:06 pm | |
| They look better. Not like new though. My new ones are just as clear as the headlight lenses. Of course they also cost a bit more than the lens polish products.... | |
DEMonte1997 Aficionado
| Subject: Re: Write-Up: Yellowed Corner Lenses Fri Feb 17, 2012 5:15 pm | |
| It's tough to get them looking perfect without sanding them down with 400 grit and then clear coating them. Even then, the flap that fills the gap between the corner housing and the headlight sees weather on both sides of that lens. It's tough to get that piece to stay clear looking. I just clear coated both sides of that on mine. Looks way better now. | |
Jelorian Amateur
Name : Jel Location : SF Bay Area Joined : 2011-11-18 Post Count : 38 Merit : 5
| Subject: Re: Write-Up: Yellowed Corner Lenses Mon Mar 05, 2012 6:34 pm | |
| I used 3M's solution which attaches to a drill (like some of the others) http://www.amazon.com/3M-39008-Headlight-Restoration-System/dp/B001AIZ5HY Here are the before and after pics. | |
ghpcnm Aficionado
| Subject: Re: Write-Up: Yellowed Corner Lenses | |
