| | Balance Shaft - What is this? | |
| Author | Message |
ricos20002 Apprentice
Name: Robert Age: 28 Location: Copperas Cove, Texas Joined: 2008-10-21 Post Count: 82 Merit: 1
 | Subject: Balance Shaft - What is this? Mon Nov 17, 2008 9:45 pm | |
| What is this for???  sorry so small |
captshiner Enthusiast
Name: Andrew Age: 25 Location: Cincinnati, OH Joined: 2008-07-23 Post Count: 761 Merit: -1
 | Subject: Re: Balance Shaft - What is this? Mon Nov 17, 2008 10:28 pm | |
| That's so small I can't tell. Was it a cell phone pic or something? Is it in the LIM? |
TonySmooth89 Addict
Name: Anthony Age: 23 Location: Florida Joined: 2007-11-14 Post Count: 2411 Merit: 16
 | Subject: Re: Balance Shaft - What is this? Mon Nov 17, 2008 10:49 pm | |
| I'm guessing youre talking about the balance shaft?
It does what it sounds like it would. Balances the engines rotating mass more giving it less vibration. In a nutshell of course. |
Mr.Riviera Aficionado
Name: Matthew Age: 25 Location: Florida Joined: 2007-01-17 Post Count: 4008 Merit: 82
 | Subject: Re: Balance Shaft - What is this? Mon Nov 17, 2008 10:55 pm | |
| | TonySmooth89 wrote: | I'm guessing you're talking about the balance shaft?
X2_________________  |
deekster_caddy Guru
Name: Derek Age: 40 Location: Reading, MA Joined: 2007-01-31 Post Count: 6091 Merit: 83
 | Subject: Re: Balance Shaft - What is this? Tue Nov 18, 2008 9:33 am | |
| Tony's right if that's what you are pointing at. It's a vibration reducer. |
albertj Aficionado
Name: Location: Finger Lakes of New York State Joined: 2007-05-31 Post Count: 4901 Merit: 100
 | Subject: Re: Balance Shaft - What is this? Tue Nov 18, 2008 11:56 am | |
| In the 3800 engine the balance shaft is an absloute necessity. Without it not only does it lope like a limping donkey but the engine shakes itself apart in relatviely short order.
If you search the web you should find a nice article about the balance shaft, why it's in there (it was not in the early 3800s) and how it makes the engine purr so nice at idle you can set a (pretty) full glass of water on the top w/o incident. To learn more specifically about the 3800 engine's inherent first-order imbalance, see:
http://engine.firebirdv6.com/3800history.html
and for more about engine balance shafts in general see:
http://en.wikipedia.org/wiki/Balance_shaft
Happy reasing,
Albertj |
deekster_caddy Guru
 | Subject: Re: Balance Shaft - What is this? Tue Nov 18, 2008 12:01 pm | |
| Actually, it's not completely necessary - If you 'upgrade' to a double-roller timing chain, you have to leave the balance shaft disconnected. I would never do this on a street car, I have driven a few and the vibration, although not horrible, is... pretty bad. |
 | Subject: Re: Balance Shaft - What is this? Tue Nov 18, 2008 7:23 pm | |
| yea thats what I thought it was, again sorry about the size and thanks for the info |
albertj Aficionado
 | Subject: Re: Balance Shaft - What is this? Tue Nov 18, 2008 8:43 pm | |
| Completely necessary = no. Derek you're right - the engine willrun for some number of hours without one.
Desirable and useful = yes, even though it drags off some horsepower.
Albertj |
Rickw Expert
Name: Rick Age: 53 Location: Lancaster, MA Joined: 2008-09-13 Post Count: 5957 Merit: 96
 | Subject: Re: Balance Shaft - What is this? Sat Dec 05, 2009 9:48 am | |
| By disabling the Balance Shaft, do you have to remove it completely? If so, what does it involve. Are there plugs or something that go in it's place or is nothing necesary other than just removing it. I understand if I want to change my Timing Chain to a heavier duty one, I have to remove the balance shaft and was wondering what's involved. |
98riviera98 Aficionado
Name: Travis Age: 22 Location: Passing you Joined: 2007-02-08 Post Count: 4773 Merit: 7
 | Subject: Re: Balance Shaft - What is this? Sat Dec 05, 2009 9:55 am | |
| | Rickw wrote: | By disabling the Balance Shaft, do you have to remove it completely? If so, what does it involve. Are there plugs or something that go in it's place or is nothing necesary other than just removing it. I understand if I want to change my Timing Chain to a heavier duty one, I have to remove the balance shaft and was wondering what's involved. |
Mine was diabled prior to installation IIRC you have to remove the rear cover.. to disable it. not sure though.. |
robotennis61 Junkie
Name: robotennis Age: 50 Location: las vegas Joined: 2007-12-17 Post Count: 3865 Merit: 72
 | Subject: Re: Balance Shaft - What is this? Sat Dec 05, 2009 6:12 pm | |
| rick, do a search on "disabling the balance shaft on a 3800 motor" and you will find lots of interesting info on how to. it sounds like a good mod with little consequence just a little more vibration. i like the idea but is a pia to do.... |
Rickw Expert
 | Subject: Re: Balance Shaft - What is this? Sat Dec 05, 2009 6:35 pm | |
| Thanks for the info. I'll do some research and see if I want to do it along with doing the LIM gaskets and new L32 Lim and Gen 5 SC next spring. Because I've already installed the 105# valve springs I'll be able to get a look at the timing chain and tensioner and see how much wear the springs caused if any. I'm curios after reading so many warnings about doing what I did. I'll probably have about 5 - 6,000 miles, maybe more, on it with the new springs before i get to pull the timing cover. Will be a good experiment. If there is heavy wear then I'd like to go with the double roller chain and new tensioner. Which will necessitate the removal of the balance shaft. Then if your going that far in might as well do a mild cam also. Ah, what the hell. This increase in Torque is addictive. |
Name: Aaron Age: 34 Location: C-bus, Ohio Joined: 2007-01-13 Post Count: 14467 Merit: 172
 | Subject: Re: Balance Shaft - What is this? Sat Dec 05, 2009 8:13 pm | |
| | Quote: | | I'll probably have about 5 - 6,000 miles, maybe more, on it with the new springs before i get to pull the timing cover. Will be a good experiment. If there is heavy wear then I'd like to go with the double roller chain and new tensioner. Which will necessitate the removal of the balance shaft. |
I wouldn't think this is a long enough period to really see any significant wear to the tensioner. Did you you open the cover and inspect before you installed the 105# springs? If not, how do you know if the wear is attributed to the new springs or the OEMs?
FYI, with 150,000 miles on 90# springs and 1.9:1 rockers, I've never inspected the tensioner, but I expect to see some wear when I do (planned for 200k). So far, no reason to suspect the chain has much slack - engine still runs and idles very smooth. _________________ "An intercooled, supercharged, 280 HP Buick Riviera with neck-snapping acceleration and precise handling that proves GM can make something really interesting and competent, if only they would build more than one at a time." - John R. White, Boston Globe
"I think that in any racing engine, the nearer you are to disintegrating, in general the better its performance will be." - Keith Duckworth, Cosworth Engineering
3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco F/Rsway bars • ES links/bushings • GM strut brace • Enkei 18" EV5s • Dunlop DZ101 tires F-body calipers • EBC bluestuff/Hawk HP plus • SS lines • slotted discs • ATE superblue fluid • DHP tuned • Aeroforce • Hidden Hitch
robotennis61 Junkie
 | Subject: Re: Balance Shaft - What is this? Sat Dec 05, 2009 8:34 pm | |
| does anybody here have the BS removed? and what do ya think? |
