 Write-Up: Installing the Optima 34/78 red top
Go to page : Previous  1, 2
Write-Up: Installing the Optima 34/78 red top - Page 2 Empty
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptyThu Dec 04, 2008 10:20 pm
You only paid $ 80.00, i was quoted at almost twice that @ $140.00 after tax.
That's why other options interested me.
I do agree with you though these battery's last a long time and I'm not concerned about saving weight. My car isn't on that big of a diet and i like the performance from the AC Delco.
Merit : 152
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptyFri Dec 05, 2008 12:40 pm
Derek - bought my replacement battery about the saem time and price forom the local Buick dealer. Wonder if they were blowing them out.
Aaron - if you have a few minutes might want to call dealers in your area (like 50 mile radius) in case any have the original battery (rather than the replacement) in stock.
good luck
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptyFri Dec 05, 2008 1:04 pm
This is the site link for the equivalent Interstate battery. Rated at 1000 amps and it is 840 cca. 48 lbs. for those concerned about weight.
85 month pro rated warranty. There is always plenty of Intersate dealers around if you can't find a good AC Delco. This one is equivalent to our original battery. Look at the Mega-Tron Plus the ninth battery down the page. Looks like same dimensions as original. When you do a search on their site for a Riv it brings you to that battery as exact replacement.
http://www.interstatebatteries.com/cs_eStore/Search.aspx?dsNavigation=Ns~product+Type%7c101%7c1%7c,Nrc~id-2147384817%7cid-17,N~21-4294493490&Catalog=RT&ProductID=MTP-79(Automotive%20Truck)
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptyFri Dec 05, 2008 6:18 pm
I'm wondering, it there are any of the original batteries left, how old are they, and what condition are they in? What is the shelf life of a car battery, anyway? It would seem if they are replacing it with a newer model, the old one is not being produced.
Rick, I like the I-Megatrons. I may look into that.
Checked Advance Auto today for an Optima - no dice.
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptyFri Dec 05, 2008 6:21 pm
I can pull the receipt to verify. The original from the 99 Riv was replaced in June of 07.
Bert tavis
Merit : 152
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptyFri Dec 05, 2008 9:59 pm
Aaron - it depends. Manufacture date is usually on the battery somewhere. Further - what *should* happen is the battery should be shipped dry to the parts store/dealer, who then fills the cells with the proper concentration of sulfuric acid and connects to a charger to ensure the battery is fuly charged.
By the way - if you ever need to store a battery - first, charge it fully and then drain it and immediately rinse it with distilled water. Ideally then you purge the oxygen by gassing it full of nitrogen. Should keep around 10 years I am told.
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptySat Dec 06, 2008 10:49 pm
Autozone has the 34/78 in stock: $189.99 + $12 core.
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptySun Dec 07, 2008 11:00 am
If you guys have a Interstate warehouse in your area, they sell batteries wholesale and they stock all the Optima batteries.
Bert tavis
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptySun Dec 07, 2008 12:05 pm
Thanks Bert,
I have a warehouse near me but I thought they only sold to dealers. I'll have to check them out for wholesale pricing.
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptyWed Apr 20, 2016 12:55 pm
Looks like ima need a new battery to resurrect my Riv. Shopping around now and looks like prices went up from what everyone was listing in this thread. $209 - $20 core charge at advance..
designer1962
designer1962
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptyWed Apr 20, 2016 1:58 pm
I bought one at Walmart. It was around $125, and has been just fine for the past couple years. My car has a parasitic drain in it somewhere and even with many "dead" battery mornings, and many hours on the charger, it still keeps on ticking.
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptyWed Apr 20, 2016 2:00 pm
Dang. how long ago was that? Cheapest I can find is ~$200
Merit : 91
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptyThu Apr 21, 2016 1:56 am
The security system will run the battery down over a matter of weeks. I learned to keep my Riv on a trickle charger after killing two batteries.
PostSubject: Re: Write-Up: Installing the Optima 34/78 red top   Write-Up: Installing the Optima 34/78 red top - Page 2 EmptyFri Apr 22, 2016 3:30 pm
Picked up battery today after work. Resurrection of Riv and motorcycle will take place tomorrow. jesus
» Installing Seizmik's Baja Light Bar!
» Bigger tires on your lawnmower
» HID Conversion Kit Install Instructions
