| ZZP PCM Question | |
gotboost? Amateur
Name : Brandon Age : 37 Location : Michigan Joined : 2008-11-12 Post Count : 25 Merit : 0
| Subject: ZZP PCM Question Thu Nov 20, 2008 2:04 am | |
| Hey all. I just bought a 96 riv. I want to do the zzp pcm upgrade. I think they call it version 1.0. I want to upgrade to a 3.4 pully size to up the boost, will this pcm work for my application? Thanks.
Brandon. | |
TonySmooth89 Aficionado
| Subject: Re: ZZP PCM Question Thu Nov 20, 2008 10:48 am | |
| No and No!
And welcome!
The only option for a 96 riv PCM is buying a used DHP powrtuner and having someone send you the 96 riv .bin file.
Second , you don't want to drop to a 3.4 without supportive mods in place. You should at a minimum have a 3" downpipe and an intake ( or gutted air box), AL104 spark plugs and a 180* tstat, And for many that isn't even enough. You should also have a scanner before you drop pulley sizes. Some cars have knock in stock form , so you'll wanna be safe. If you're knocking believe me you'll be slower with a 3.4 than you are now. | |
| Subject: Re: ZZP PCM Question Thu Nov 20, 2008 1:04 pm | |
| I couldn't run the 3.4 until I put 1.9 rockers in my car. I should have started with a 3.5. I strongly recommend an MPS with a 3.5 to start. Get the extra airflow mods in place before dropping pullies any further. I also strongly recommend scanning for KR BEFORE and after the 3.5 install. I've seen stock pullies running with KR at WOT. | |
gotboost? Amateur
| Subject: Re: ZZP PCM Question Thu Nov 20, 2008 5:54 pm | |
| alright. Good info. I do have a gutted air box, but great information. Is there a site I can visit that can help me with my pcm tuning? Thanks, and sorry for the n00b questions. | |
EASHER Member
Name : ERIK M. ASHER Age : 55 Location : BLOUNTSTOWN, FL Joined : 2008-10-24 Post Count : 85 Merit : 0
| Subject: Re: ZZP PCM Question Thu Nov 20, 2008 10:46 pm | |
| Intense Racing has pcm programming available and you can choose your options for the mods you have in place. | |
gotboost? Amateur
| Subject: Re: ZZP PCM Question Fri Nov 21, 2008 11:48 am | |
| Thats great. Thanks all for the help. | |
| Subject: Re: ZZP PCM Question Fri Nov 21, 2008 12:09 pm | |
| - EASHER wrote:
- Intense Racing has pcm programming available and you can choose your options for the mods you have in place.
again though, it doesnt work on 96 rivs, only 97+ 3800 cars. you could check around and see if someone can dyno tune it for you if you dont want to drop the $$ on the DHP unit. you can get a scanner easy, but actually tuning a 96 riv is difficult. sorry another option is to find someone on clubgp that is close to you and have them tune it once you send them the .bin for the 96 riv. _________________ 1996 with 254k miles, L32Â 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
gotboost? Amateur
| Subject: Re: ZZP PCM Question Sat Nov 22, 2008 9:21 pm | |
| Fuck it, ill leave it stock. This car wasn't ment to be fast anyway. | |
| Subject: Re: ZZP PCM Question Sun Nov 23, 2008 8:55 am | |
| This car has a lot of potential to go faster. It's not that hard, with a few bolt-ons, but you need to choose them with care, that's all. When it comes to PCM tuning, the basic PCM from Intense will crisp up your shifts and open up quite a bit of potential, even though it's not a complete 'custom' tune... To do more, you need a programmer of some kind.
I started with an Intense PCM as one of my early mods and was very happy with it. | |
| Subject: Re: ZZP PCM Question Sun Nov 23, 2008 1:39 pm | |
| Why get so discouraged? I've managed to do a decent bit of mods on my 96 , and i'm still going. ( though stopping soon because i've spent too much money already). With just a few bolt ons these things can really be much more fun than stock. And still drive like stock too. | |
curious riv Addict
Name : Chris Age : 44 Location : C'view FL Joined : 2008-10-20 Post Count : 521 Merit : 3
| Subject: Re: ZZP PCM Question Sun Nov 23, 2008 7:40 pm | |
| B.S. my friend. as with anything n life-if ur goin t do something, do it right. if you want t do it fast and cheap, ask shintsu's dad how to do it. if you still want t drive ur car- listen to these guys, read, study, take youre time and do it right. these cars were meant t b fast. but fast is not cheap. register t regalgs.(something) there is some good info, but u will still have t find, read and study how.
good luck & dont give up on ur riv- it really does have great potential. | |
curious riv Addict
| Subject: Re: ZZP PCM Question Sun Nov 23, 2008 7:48 pm | |
| my previous post was directed at gotboost?'s fuck it post. (i tried quote, and for some reason it posted my post twice and didnt quote you) | |
gotboost? Amateur
| Subject: Re: ZZP PCM Question Sun Nov 23, 2008 8:27 pm | |
| Thanks guys. What exactly is the difference between the 96's and the rest of the rivs? | |
curious riv Addict
| Subject: Re: ZZP PCM Question Sun Nov 23, 2008 8:40 pm | |
| got boost?, help us out, figure out how t put up a sig.the FAQ section will tell you how | |
| Subject: Re: ZZP PCM Question Sun Nov 23, 2008 8:55 pm | |
| The main difference is the transmission - it does not have nearly the computer integreation of the '97 and up. The engine is still the same, and the same mod info applies. There are those who say the '96's tranny can hold up to quite a bit though. | |
gotboost? Amateur
| Subject: Re: ZZP PCM Question Mon Nov 24, 2008 12:42 am | |
| Ok, so what is the most cost effective way I can run a 3.6 pully and still run a safe tune? I am not made of money, so I am looking for a inexpensive way to do this. Can I use a scan tool? What are other members doing for tuning with this size pully? I do plan on doing a downpipe in the near future. I can't justify spending 200+ on 2lbs of boost. SOMEONE PLEASE HELP ME! | |
| Subject: Re: ZZP PCM Question | |
